Question about 3Com Computers & Internet
Phone goes straight voice mail from outside calls
jncayo
  • 31 Answers
SOURCE: Calls go straight to voicemail
Your phone is fowarded to Voice Mail and do not disturb is on. Turn DND button off. If it is not the case on your phone press intercom # key 601 then hang up. Then do intercom #key 604, dial your voice mail extension numbe, r press the speed dial Select button, dial 16, press the redial button then hang up.
Posted on Dec 28, 2008
SOURCE: NEC Dterm 80 calls won't go to voice mail
for us i just found this out.
1.Fwd B/NA
2.1 - 1:set-0:cancel
4.200
5.speaker
after 4 rings it goes to voicemail
this works for us.
i hope it works for others too.
turn this feature off
1.hit fwd b/na
2.0:cancel
3.exit
4.exit
should see the normal display then.
Posted on Jan 16, 2009
atulbamne
  • 33 Answers
SOURCE: all incoming calls go straight to voice mail
Just go to call settings and then call divert. check settings. Maybe all calls are diverted to voice mails. Cancell all diverts. Then you are done.
Posted on Jan 21, 2009
SOURCE: my phone says no circuit channel available when I try to use my p
I had the same problem with my LG VU this morning and it got fixed after changing from 3G mode to 2G mode using these steps:
Press 277634#*#
Then go through the menu:
Modem Setting
Network Mode
Network Mode
2G only
Posted on Feb 11, 2009
  • 37 Answers
SOURCE: incoming calls go staight to voice mail
There are a number of reasons why this could happen.
1) The most common is you have call forwarding always. When you lift your handset do you hear stutter dial tone? if you do you have a feature active on your phone. To correct this you will need to turn the call forwarding feature off You will have to get the code from your system administrator or go through your superkey (the Blue Key) using the # until you find the call forwarding options and review and turn it off (Change).
2) It's possible you have Do not Disturb active.
3) its also possible you have Make busy active
2 and 3 can be removed by the clear all feature code but 1 must be cleared using the method I described. Get these codes from the system admin.
Posted on Mar 14, 2009
My calls go to voice mail
How to stop iPhone calls going straight to voicemail - iOS 7 tip
www.macworld.co.uk/.../how-stop-iphone-calls-going-straight-voicemail...
May 28, 2014 - Do your iPhone calls go directly to voicemail? ... I don't remember setting my iPhone to Do Not Disturb, and it appears nor do most people ...
iPhone 5 calls go straight to voice mail ' Apple Support Communities
discussions.apple.com > Support > Apple Support Communities
Apple Inc.Dec 25, 2013 - Madman, your advice solved the problem on my wife's phone. It wouldgo to voice mail very often, seemingly for no reason. When I'd call again, ... iphone 6 going calls going directly to voice mail
Jul 20, 2015
My iPhone doesn't always ring, why?
Oct 28, 2013
calls going straight to voice mail
Feb 24, 2013
Calls going Straight To Voicemail
Jul 3, 2010
More results from discussions.apple.com
Troubleshooting Calls going straight to
Dec 30, 2015 | Cell Phones
My motorola tracfone goes straight to a recorded messege when you call it...can i only use it to call out?
The reason your phone goes straight to the recorded message is because the voice mail of your phone is active.
To solve this is simple, all you have to do is to deactivate the voice mail.
To deactivate this, what you have to do is dial ##002# and send it.
Then try to dial your number again to see what happens.
Take care.
Jun 18, 2010 | Motorola Mobility TracFone w175 PayAsYouGo...
My Avaya phone on our Avaya system only rings
ask your local admin to remove your phone from coverage path
Apr 15, 2010 | Linksys SPA941 IP Phone
I have a KX - T7730, how to set voice mail and to forward calls to outside number? The manual instruction is too confusing...
http://www.walterbridge.com/manuales/KXT7720-User-Guide.pdf
Get that guide, it is very straight forwards.
Setting voice mail, is only done, through the phone, not by, the phone. page 6 shows you how to log/In out. You need to do this first to be able to access the voice mail. Again, in same page, it shows you step by step via a drawing of buttons, each row of words explains another way to call forward, you just press the corresponding numbered button
Mar 24, 2010 | Panasonic KX-T7730 Corded Phone
Avaya 6416D+M, rings half ring, then goes straight to voice mail
you might status the phone to make sure that send all calls somehow is not on. :)
Oct 28, 2009 | Avaya Definity 6408D Corded Phone
All incoming calls go straight to voice mail
Jan 21, 2009 | Motorola Mobility TracFone® V170 Cellular...
Inter-Tel Axxes phone outside calls don't go to voice mail
I had this same challenge with an InterTel 5000 system. Outside calls going right to the receptionist. My solution: You cannot fix this from a phone, you must open the DB Session Manager, move to Call Routing Tables (this is right above Voice Processor) and move all of your extensions above the "NO MATCH" and "EMPTY" lines on the bottom. Anything below those two lines will bypass the extension and go straight to the main attendant. At least in my configuration it does. See below...
bb752dc.jpg By just moving that last extension "5059" above the "NO MATCH" line, calls will now go to the extension from an outside caller. The trick is to hold your mouse on the pen icon and click several times to activate that line, then you can drag it to where you want. See below...
8e5e1dd.jpg Hope this helps someone?
vandata1
Sep 27, 2007 | Inter-Tel Axxess Corded Phone
Computers & Internet Logo
46 people viewed this question
Top 3Com Computers & Internet Experts
steve morris
steve morris
micky dee
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
