Question about ValuSoft Hard Truck: 18 Wheels of Steel for Windows
Installing game compatibility tab - ValuSoft Hard Truck: 18 Wheels of Steel for Windows
Games wont work on my computer
Have you tried running the application in compatibility mode? In some cases, it helps. Just right click o the icon, and select "Properties". Then Select the compatibility mode tab, ad try changing it to different versions to see if that helps. I attached an image of what you should see when you get to that tab.
Feb 24, 2016 | Cosmi 201 Solid Gold Games for Windows
MOST GAMES WON'T PLAY THEY WILL BE INSTALL BUT WON'T RUN
is it compatible?
Right click on the game icon and select properties. Click on the compatibility tab and tick the box in the compatibility mode section. Select xp and click apply.Start the game and hopefully it works.
Sep 26, 2012 | Video Game Consoles & Games
Backyard soccer won't work on my 64 bit windows laptop.
Are you using Vista or Windows 7?
As far as i remember Backyard soccer is kind of an old game. It likely only works on Windows XP
May 04, 2011 | Computers & Internet
I have bought e games MahJongg Master 6. Have run the disc to install but the game wont run, tells me Cannot initialise graphics and cannot install graphics device. My system is HP pentium 2.7GHz, 2GB...
Mahjong 6 was produced in 2004 and will likely not be compatible with your operating system, operating systems that are 64bit are often less compatible with software than operating systems that are 32bit, especially with older software. One solution you can try is to:
  1. Right click the desktop shortcut for the game
  2. Click "properties"
  3. Click the "compatibility" tab
  4. Check the box next to "run in compatibility mode for"
  5. Select Windows XP
  6. Click Apply
This may allow the game to run by emulating an older operating system.
Mar 14, 2011 | eGames MahJongg Master 6 for Windows
Deer hunter game didn't work at all
we want a serial number to install it.if you dont have it you must crack the game.the crack will get from internet
Jul 19, 2009 | Infogrames Deer Hunter 2003 Legendary...
CivilizationII test of time
If it doesn't work the regular way, try installing and playing in compatibility mode. To install in compatibility mode right click on setup -> properties -> compatibility tab -> check: run this program in compatibility mode; to play the game in compatibility mode do the exect same thing ond the game executable file
Mar 17, 2009 | MicroProse Civilization 2: Test of Time...
Video game will not install.
You're refering to your "Talonsoft Old alchemy game" post?
If so, here's a copy of my reply to that post.
Try this:
Right click on the D:/Poppack-setup.exe -> Properties = Compatability Tab.
There should be a box that says "Compatibility Mode" that you need to chek, and then select Win95 and hit OK.
Try installing again.
If it still gives the same error, go back to the tab and go lower than the Compatibility Mode box, to Display settings, and chek "Run in 256 colors" and "Disable Visual Themes"
Try again.
If it still wont work, please respond. If it gives a different error at any time or a different problem, please respond.
If it works, please rate. :)
Dec 14, 2008 | Video Game Consoles & Games
I am unable to install hunting unlimited 4.Is it vista compatable?
It seems that Hunting unlimited 4 is only for systems up to Windows XP....
Try installing the game in compatability mode...might work...
explore the game cd
look for the setup.exe or install.exe
right click and view properties
look for the compatability tab
under compatability click the box that says run this program in compatability mode ....make sure you choose windows xp then ok the window
now double click on the exe file that you´ve just changed and see if that works
Nov 26, 2008 | Computers & Internet
3D mazeman
The game was released in 1998, and was developed for Windows 95/98.
To make the game run on Windows XP, try the compatibility for the installation and after it is installed use the same steps for making the game executable file compatible.
Note: Some game ".exe" file (executable file) would let you make changes in the Compatibility option, whereas older games might not give that option at all.
You can still try to make the game compatible for installing it on the Windows Vista by following the steps below.
1. Insert the game disc in your CD-ROM drive, if the game setup or the autorun starts, exit it.
2. Open "Computer", Right Click the Cd Drive which has the game disk in it and select "Copy".
3. Go to your "Desktop" right click and then select "New" and click on "Folder" this should create a new folder on your desktop.
4. Open the New Folder and then Right Click and select "Paste".
6. After all the files are copied to the "New Folder" without any error messages then locate the file "Setup.exe" or "Setup" and right click and click on "Properties".
7. In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows 98/ Windows Me" and then click on "Apply". (You can also try "Windows 95")
8. After applying changes double click on "Setup.exe" or "Setup" to launch the installation.
You can delete all the files copied from the CD after completing the installation
After the game is successfully installed right click on the game shortcut or the game ".exe" in the root folder of the game and click and click on "Properties".
In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows 98/ Windows Me" and then click on "Apply". (Again, you can also try "Windows 95")
The game files need to be copied to the hard drive because the files on the game disk would not let you make changes while on the disk.
There are lot of files that need to be changed in order to get full functionality and to communicate with operating system and the hardware, hence there is no guarantee that the game might run even in cases where you will successfully install an older version of the game with the above mentioned steps.
Oct 24, 2008 | eGames 3D Mazeman Amazing Adventures for...
ValuSoft Hard Truck: 18 Wheels of Steel for Windows Logo
11 people viewed this question
Top ValuSoft Video Game Consoles & Games Experts
James Wishart
MegaByteMe
MegaByteMe
Charles A Stimeling
Are you a ValuSoft Video Game Console and Game Expert? Answer questions, earn points and help others
