Kyocera km-2020 error code a-3200 - Office Equipment & Supplies
  • 43 Answers
SOURCE: error code C-6 for kyocera km 1500
Fuser error,
may have either a blown lamp, blown thermo fuse or faulty thermistors, but more then likely a combination of at least two.
Posted on Mar 02, 2008
sir fixalot
  • 146 Answers
SOURCE: Kyocera KM 3050 - error C3300
Error C3300 is a CCD Automatic Gain Control issue.
It could be poor contact in the connector terminals from the SHD PWB to the CCD PWB.
It is more likely a defective exposure lamp or inverter board that powers the lamp.
Try lifting up the Document feeder so you can see the optics frame through the platen glass and turning off and then on, the main power switch to see if the green exposure lamp illuminates.
A better, but more complicated way to check the lamp is to enter the service mode and run the exposure lamp test simulation. I will outline this procedure below. BE SURE NOT TO MESS WITH OTHER THINGS IN SERVICE MODE OR YOU COULD RENDER YOUR UNIT COMPLETELY UNUSABLE.
To Enter Service Mode:
Hit the "Status" button
Hit the following sequence on the numerical keypad:
1 0 8 7 1 0 8 7
You should be in service mode.
Use U601 by typing 6 0 1 and then "Start"
U601: Turning the exposure lamps on
Description: Turns the exposure lamp on.
Purpose: To check the exposure lamp.
Display:
CCD: Main Exposure Lamp
CID: Document Processor Exposure Lamp (inside the feeder)
Method
1. Press the start key.
2. Select the item.
3. Press the start key. The selected lamp lights.
4. To turn the exposure lamp off, press the stop key.
Completion
Press the stop key. The screen for selecting a maintenance item No. is displayed.
After checking the lamp(s) operation hit "reset" a few times to back out where you can type 0 0 1 "Start" to Exit Service Mode.
Posted on Jun 03, 2008
SOURCE: KYOCERA KM-1820 COPIER
follw these steps, it should work
turn off copier.
open top toner cover.
turn copier back on.
when you see message "close top cover" press "system menu" button.
scroll up to "service setting" then press the # button, green "start" button and the "enter" button all at the same time.
then scroll down to "maint mode"
press "enter"
then enter 163
press" enter "
turn off copier then turn back on
close toner cover
you should be back in business
Posted on Jun 12, 2008
  • 126 Answers
SOURCE: KYOCERA MITA KM-1500 ERROR CODE C7980
C-7980 - Means that the waste tonerresevoir in the process unit is full with less than 100,000 copies onthe unit.
Clean/ empty the waster toner and vac.Also clean the sensor.
You may have to change the Process unit if cleaning does not work.
Posted on Mar 02, 2009
fsantello
  • 4 Answers
SOURCE: Error Code 2102
Change the SMTP port from 25 to 587
Posted on Aug 20, 2009
E32 error in kyocera
The toner container is not installed on the copier.
Mar 01, 2016 | Kyocera Mita 2 Pack Km 2020 2035 2050...
How do I fix error code C-6 with a KM 2020 copy machine
It is resettable to enter simulation so .....
Press and let down "Clear / Stop", "Start" button on the left to darken or clear, then "Stop / Clear" "U163", "Start" appears "CLE" and there you hit "Start" other time and now.
Feb 22, 2015 | Kyocera Office Equipment & Supplies
Why I cannot write 10871087to remove c_6050 from printer km 2020
Fixing thermostat triggered. Fixing heater M or S installed incorrectly
km 2020 error c-6050
Jan 01, 2015 | Kyocera Office Equipment & Supplies
Error code c6
heater problem reast 10871087 after selct 163
Aug 07, 2014 | Kyocera Mita 2 Pack Km 2020 2035 2050...
Kyocera eroor code c-6000
Works with ERROR C6000, C6300, C6400
Switch off
Open Toner Cover
Switch on, holding "System Menu"
Go to "Secure Setting"
"Enter"
Hold "Start" "#" "Enter"
Scoll down to "Maintenance Mode"
"Enter"
Scoll down to "U163"
Scoll do "Execute"
"Enter"
Close Toner Cover
Leave run for a few seconds
Switch off
Switch on....
May 04, 2014 | Kyocera Mita 2 Pack Km 2020 2035 2050...
C-6 400 what does it mean on kyocera KM-2020 photocopier machine
Hi my Kyocera KM2020 is showing an error code C-6 400, what does it mean and how do I fix it? Thanks
Jan 29, 2013 | Copystar CS-1650 All-In-One Laser Printer
Error C-0150 back up memory of kyocera KM-3540
http://www.eserviceinfo.com/downloadsm/15534/kyocera_km1620/2020.html
http://www.fixdevice.com/smanuals/file/34223.html
Repair manual above.
http://www.fixdevice.com/smanuals/file/34229.html
You mention two, KM-1505 & KM-3540 here is the generic manuals for both.
www.feedroller.com/Store/Service%20Manual/KM_1505P.PDF
Service manual above this is the fix manual above.
Backup memory read/write problem
(engine PCB)
• Read and write data does not match. Defective engine
PCB.
You have a bad board in the printer it must be replaced.
Apr 08, 2010 | Kyocera KM-1505 Copier
My kyocera km 2020 has a j00 error how can i clear
Find the jammed paper in the paper tray.
Mar 10, 2010 | Kyocera KM-1510 Copier
Kyocera mita error codes of KM 1500
Hello sir; The error code you display A3200 is not available in our menual, we do have C3200 , if that's correct, it means exposure lamp burn out ( not on), replace it, or thermos fuse out.
May 13, 2009 | Kyocera KM-1505 Copier
123 people viewed this question
k24674
jasbo
jasbo
