Question about Pioneer AVH-P6500DVD Car DVD Player
Screen won't come out
Started out screen coming out of deck and clicking and jumping, not coming out or in smoothly. Now it won't come out of deck at all.
My display started clicking then finally stopped working and would not come out. I took it apart and found two teeth broken on a gear. i replaced the gear, now i works fine.
Posted on Dec 05, 2007
    New Friend:
Where you buy gear? please answer
Posted on Jan 02, 2013
I just pressed the reset button on the front of deck, had to use a pen to prees it in but screen came back out after that. Although i do still have stripped gears inside i think because it is still clicking coming out and in.
Posted on Sep 10, 2007
Your dvd player only need a clean all in
Focus 1.8 tdci 2009 won't start dash lights go crazy noise from fuse box
check your battery cables for corrosion clean them and start the engine
Mar 25, 2013 | Cars & Trucks
My computer screen keeps jumping or won't stay up
Your laptop screen refresh rate is low (Hertz). When your screen refresh rate is slow, it will flicker and stutter.
To fix this, right-click your desktop, and go to Personalize.
When you're there, go to "Display Settings" and go to "Advanced Settings", on the "Monitor" tab you'll see the screen refresh rate. Change it to the highest number you see.( min 65-70)
Although the change will shorten your laptop battery life, it will fix the problem. Just keep your charger on until it's fully charged, and it should be good.
Jul 22, 2012 | Computers & Internet
Computer screen jumps while scrolling up and down
This could be due to incorrect mouse settings. It may also be an issue with smooth scrolling in Windows. You can try both disabling and enabling smooth scrolling to see setting performs better.
Some related tips can also be found here:
Jun 15, 2012 | Gateway MX3228 Notebook
Lawn mower won't start with out being jump started . Changed battery. After jump starting mower and while mowing engine stalls while mower deck engaged . If mower deck is shut off before it looses...
Other possible causes include: Loose, Dirty or Disconnected Spark Plug in Your Lawn Mower: Check it out, clean off debris, re-connect and tighten. Fuel Not Reaching the Engine: Tap the side of the carburetor to help the flow of gas. If this doesn't work, you might need a new fuel filter.
Top 5 Mower Troubleshooting Tips ' Briggs & Stratton
Lawn mower won start Google Search
Nov 30, 2017 | Simplicity Vacuums
Mouse cursor jumping problem, how to fix it?
A mouse is a vital component of your computer and allows you to control certain functions on the screen. When the mouse is not functioning correctly, it can be frustrating. There are a few different reasons why your mouse pointer may jump on the screen. You need to work through the possible causes and troubleshoot the problems to fix your mouse and get it working properly again.
Examine the batteries if you have a wireless mouse and the cursor begins to jump. A low battery may be the cause. Change the batteries and check the mouse again. If it is still experiencing the same problems, proceed to the next steps to resolve the issue.
Switch the wireless transmitter to a different USB port on another computer if possible. There could be problems with the port, causing the cursor to jump. This will resolve the problem if the issue is with the USB port. If the mouse is still jumping, move on to the next steps.
Click on the "Start" menu in the bottom left corner of the screen. Right-click on the "My Computer" menu and click on "Properties." Click on the "Hardware" menu and click on "Device Manager." Locate the mouse entry in the list. Right-click on it and select "Update Driver" from the menu. Allow a few moments for the operating system to locate and install an updated driver for your mouse.
4. Remove dust or debris from the mouse pad and mouse with a soft cloth. Dust or debris could prevent the mouse from operating smoothly and cause the cursor to jump. Add a small amount of isopropyl alcohol to the cloth before you begin. Wait for the alcohol to dry on the pad and mouse prior to using.
5. Go to the "Start" menu and click on "Control Panel." Double-click on the "Mouse" icon and click on "Mouse Pointer." Decrease the speed of the mouse pointer. This could be causing the cursor to jump.
I hope you find it very helpful.
Thank you.
Aug 11, 2011 | Lenovo 3000 N100 0768 - Pentium Dual Core...
2004 BMW X5 4.4i Left lights on resulting in flat battery. Car was jump started from another vehicle (Ford Transit van). Everything fine for a few days. Now, intermittently the radio/sat nav goes haywire!...
sounds like your car has the multi function steering wheel, i know on the 7 and 5 series they come out of sync, im not sure why.
its about £75 to get plugged in at the dealers and they reprogram it, sometimes i have had the odd car with a damaged slip ring, it does all sorts of things, 1 in particular kept on beeping the horn,
i would say if u got 1 urs got upset when battery flat.
Apr 22, 2009 | 2009 BMW X5
Turn key and get a click
the started is probably jammed and needs to be unbolted and put starter bendix gear back in starting position turning over an engine too long on a jump start can cause this
Apr 02, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Pioneer AVH-P6500DVD Car DVD Player Logo
201 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
