Question about RTO Flux Wire Welder Dual Mig 131 Ti 1 Gas And No Gas
Where can i buy parts for my Dual Mig 131t/1?
The wire speed control circuit needs to be replaced and i cant find where to buy it.
A snap on mm250sl that i cant control the wire speed feed, from 4-10 on the dial it runs full speed, from 4 down it does nothing. ive had this welder for 20 plus yrs with no problems till now
The wire speed knob does more than control the wire speed. As the wire speed is increased the welding power must also increase and the circuitry to do this and keep things in sync is fairly complex. The fault is probably within that circuitry and the repair will require no small amount of skill and test equipment or a replacement circuit board.
Complex electronics can be fairly sensitive to high temperatures and voltage spikes and surges and apart from the natural sort that arrive along the mains electricity supply mig welding is an electrically noisy process that can be quite stressful on those electronics. 20 years of trouble-free operation is quite a good record...
Oct 28, 2016 | Welding Tools
Hobart beta mig 170 wire feed wont adjust
The variable speed motor runs on 0-24VAC controlled by the speed control dial. The dial may be toast. Replace this part first. You may verify the part failure by using a bypass wire to see if the motor runs at maximum speed without the control dial (rheostat or potentiometer).
Sep 02, 2014 | Welding Tools
I have a hobart Handler 135 and it won't feed the wire correctly. At first it will feed about 6 " of wire then it goes down to about an inch at a time then it will just click. If you wait awhile it will...
If you completely remove wire from unit does it still slowdown and stop when you pull trigger?
If yes, then 2 most common problems are
A. Thermistor @ position PTC1 on circuit board
B. Drive Roller Motor
To diagnose, locate thermistor @ position PTC1 in upper middle part of circuit board.
It's yellowish round and about 1/2" in diameter.
Jumper Accross the 2 leads, use a small insulated screwdriver or meter probe.
1. Pull trigger on gun, when motor slows or stops then jumper the leads, if it speeds back up then it's the Thermistor
Replace with a Raychem RXE 1.85A @ 72 v
Or comparable, try EBay
2. If no change, isolate motor by removing the 2 leads and connect a 9-12 volt DC battery source, does motor spin? If not then motor is problem. If motor spins and is constant then additional troubleshooting needed, next possible issues are bad resistor or scr
Jun 06, 2014 | Hobart Handler 140 Mig Welder
Snap on ya240a 117-036 mig welder Problem
I have an issue with this same model, I need help, Got scammed on craisgslist and was sold ya240a with burned up circuit board. I really need help with pics of the transistors on it, and numbers on it. Since mine are blown. I cannot find circuit board schematics. I found someone who can salder the parts on for me.
Aug 08, 2012 | Welding Tools
Have a Hobert handler 135 i can't control the wire feed speed it seems to run wide open.
Sounds like the restate that controls the wire speed is gone. Replace it.
Jan 05, 2011 | Hobart Handler 140 Mig Welder
Burned resistors
I have the same problem with the Mighty Mig...Did you find these resistor values?
Jan 23, 2010 | Welding Tools
Flux wire on Dual Mig Welder not feeding.
Change the contact tip.This is the most common problem. The tip gets burned and keeps the wire from feeding. You should always have extra tips on hand.
Aug 03, 2009 | RTO Flux Wire Welder Dual Mig 131 Ti 1 Gas...
Have a 110 volt mig wire feed. motor slows to a
To get parts for your welder you'll need to have the serial number off the tag on the case. This problem could have other causes, have you:
Checked the tension on the wire spool? You ought to be able to pull the wire by hand easily.
Checked the tension setting on the pinch rollers? Too much tension can drag down the motor speed.
You could also have a bad control card depending on which model wire feeder this is.
Regards,
Carl
Feb 28, 2009 | Hobart Welding Tools
RTO Flux Wire Welder Dual Mig 131 Ti 1 Gas And No Gas Logo
71 people viewed this question
Top RTO Welding Tools Experts
Bill Boyd
Are you a RTO Welding Tool Expert? Answer questions, earn points and help others
