Question about ASUS Essentio CG5270BP003 PC Desktop
Fried motherboard when not in use the power button flashes and computer does not work right to use
    Brigadier General:
  • ASUS Master
  • 3,400 Answers
IT IS PROBERLY IN SLEEP MOODE.GO TO CONTROLPANEL ENERGY-SETTINGS AND CHANGE IT.
Posted on Jul 11, 2013
On start up it only has a flashing led which in Amber in colour
I'm assuming the flashing light is in the motherboard. If it will not boot at all you probably have a bad motherboard. Make sure your power cables are all on firmly. Remove the memory with the computer unplugged then hold the power button for about 30 seconds replace plug in and try. But more than likely you board is fried or a hard drive failure.
Feb 06, 2016 | Computers & Internet
I have a Dell Inspiron ONE 2305 All in One. The power supply tested bad so I replaced it, however the computer still will not turn on. When plugged in and pushing the power button, the power button flashes...
When a power supply goes it can do all sorts of other damage. You will need to get the system tested properly, to check the processor, RAM and drives. The PSU can also fry the motherboard. You could try some known working RAM in place of your own, This will eliminate at least one problem.
Sep 05, 2013 | Dell Inspiron One 2305 Desktop Computer...
My computer was on when i left the house and when i came home the computer is off and will not turn on. The little green light behind the tower is flashing showing that power is being recieved but the...
this happened to me as well once its one of two things:
1. your motherboard is completely fried or some power compnenets are fried
2. your power sequence might need to be adjusted.
Dec 09, 2010 | HP Compaq Presario SR1575CL (PX808AA) PC...
D945GCCR Motherboard: after a thunderstorm the psu got damaged so I repl...
Sorry, the motherboard has been fried - nothing you can do, it's dead. Replace it.
May 18, 2010 | Intel D945GCCR Motherboard
Fried mobo with new psu?
Yes, it sounds like the motherboard from the Dell machine is now ready for the recycle yard. My son had an old Dell that the motherboard failed, and one by one, all add on cards, and eventually the RAM stopped working. Those old Dell systems can only keep going for so long, and besides, why hang on to it? Get a new PC, they are low priced now, and you get such a faster, smoother running PC.
Jul 26, 2009 | Dell Computers & Internet
USB PROBLEM- NEED ATTENTION NOW
Here is another option: you can see if your computer has even recognized the device by going into the computer management again, accept this time check the "disk management" instead of device manager. You should see your hard drive listed and hopefully your flash drive is there as well. If it is try right clicking on the drive and select "change drive letter..."select something like "x" and see if that helps it to appear.
I know you may not want to hear this, but If this doesn't work you may need to resort to adding a PCI card with some new ports on it.
Jan 06, 2009 | Microsoft Windows Vista Ultimate Edition
SEROUSLIY NEED HELP USB PORTS NOT WORKING
restart the computer try that then get back to me
Jan 05, 2009 | Microsoft Windows Vista Ultimate Edition
Go to Regedit and type the following HKEY_LOCAL_MACHINESYSTEMCurrentControlSetServicesUSBSTORstart
change the value data from 3 to 2
Regards,
Meraj
meraj2k@hotmail.com
Jan 04, 2009 | Microsoft Windows Vista Ultimate Edition
I have a flickering amber light on the power button; replaced power supply and motherboard with no luck
FIRST IF YOU REPLACED THE POWER SUPPLY OF YOUR DELL PC,
MAKE SURE IS A RECOMMEND POWER SUPPLY FOR DELL COMPUTERS ONLY
BECAUSE DELL USE A DIFFERENT (NONSTARD) PS
AN PLEASE DON'T TURN YOUR PC ON, TILE YOU ARE SURE I'TS A DELL COMPATIBLE POWER SUPPLY
YOU CAN FRY YOUR COMPUTER
ON THE MOTHERBOARD I'T MAY BE THE BIOS (BIOS STANDS FOR INPUT /OUTPUT SYSTEM) I'T A CHIP ON YOUR MOTHERBOARD THAT CONTROLS THE SYSTEM HARDWARE AND ACTS AS AN INTERFACE BETWEEN THE OPERATING SYSTEM AND THE HARDWARE
I'T MAY BE FLASH
IF IS FLASH ,
YOU PROBABLY NEED TO REPLACE THE MOTHERBOARD
OR CALL DELL TO SEE IF THEY CAN FIX IT
Aug 20, 2008 | Dell OptiPlex GX520 PC Desktop
ASUS Essentio CG5270BP003 PC Desktop Logo
37 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
