Computer always shutdown - Computers & Internet
    Brigadier General:
  • 3,400 Answers
DETAILS,DETAILS.
Posted on Jul 12, 2013
Disable auto shutdown
Restart the Computer and keep tapping the F8 key till you see the advance boot options, You should be tapping the key as soon as you see the manufactures screen. Once you get the advance boot options -> Select the option which says Disable Automatic Startup on System Failure.
Good Luck!!!
May 16, 2013 | Toshiba Satellite Computers & Internet
Gateway MT6707 shutdown problem
Open the Control Panel, select Power Options, select High Performance, select Change Plan Settings, Under Plugged In, set time to Turn Off Display, set Put the Computer to Sleep to Never, select Change Advanced Power Settings, scroll through the settings , click on the + at Power buttons and Lid, set to shut down, Sleep and Hibernate to Never, adjust the rest to your preference. When you are not using the Laptop ALWAYS shut down and unplug to prevent damage due to power surges.
Apr 03, 2013 | Gateway Computers & Internet
Always shutdown"CPU Shutdown Temperature
Hello download a manual here:
http://www.ecs.com.tw/ECSWebSite/Downloads/Downloads_Driver_Detail.aspx?MenuID=61&LanID=0&detailid=1093
Check the bios for any cpu overclocking settings
and set it back to standard settings.
Renew also the thermal cooling paste between the cpu and the cooling fan.
See if the cpu fan is running when the pc starts.
Be VERY carefull when you remove the cpu cooling fan
and take care not to damage the cpu.
And take antistatic precautions when you work on the mainboard.
If you have not tryed this before let a expert do the job.
Hope this will help you
Nov 22, 2012 | EliteGroup Computer Systems Ecs...
Bios 500
Shutdowns can be caused by many things. If you have your pc setup for automatic updates, some updates require a reboot and will do that automatically. Normally you can prevent that from happening by changing the settings from automatically updating to notify me first before updating.
The shutdown can also be caused by the cpu overheating. Your computer will automatically shut down to protect itself.
Shutdowns can also be created by a infected computer. Malware can cause this.
With out further details, such as what you were doing at the time of the shutdown it's difficult to say why your system is shutting down.
I can say that normally if its a update your system will shut down and reboot, not always, but usually.
Not a lot of help but additional information is really needed. What you are doing, brand of pc, if you have loaded new software or hardware, as much information as you can provide would help.
Sometimes, just goggling you problem on line with the make of the pc will help you find the answer you are having. Many times the problem you are having has already been addressed and a solution provided.
Aug 02, 2012 | HEWLETT-PACKARD Hewlett Packard COMPAQ...
WidwsVista hw to exit from safe mode
If your computer always starts to safe mode, go through the following steps:
· press <windows kwy> + <R>
· type MSCONFIG then press enter. This will open the System Configuration window.
· click on the BOOT tab and make sure nothing is checked/ticked in all the boxes you see.
· click OK button
· check/tick the box that says "Don't show this message again..."
· press RESTART COMPUTER button.
Your computer should boot to normal mode.
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
Feb 22, 2011 | Computers & Internet
I always get this message on my computer desk top and dont know what it means..(The system process c.\windows\system services .exe terminated unexpextedly with status code -1073741819.T HE SYSTEM WILL NOW...
Scanning computer to eliminate malwares, spywares and the viruses from your laptop.
2- Repairing and cleaning Windows registry.
These two tips are found to be very helpful to fix the laptop shutdown problem. Almost all the computer users surf internet which could result in viruses attacking your system. Some of these infections are really pesky and cause the machines to shutdown randomly.
The registry errors, however, are the internal errors and can become a cause of system crashes and freezes. The registry keys shall be in good health to keep a system perfect.
When I noticed my laptop keeps shutting down everytime, I tested the Intel Software Partner, RegInOut to fix the random shutdown problem with my laptop.
Oct 06, 2010 | Microsoft Windows XP Home Edition
All lamps are blinking. I cannot shutdown the system with the on/off switch
you shouldn`t actually turn off computers whith their power button always just click start or on you windows icon in the bottom left corner then click shutdown
May 16, 2010 | HP PSC 1510 All-In-One InkJet Printer
Lenovo Y410 laptop is getting hot and shutdown automatically.
When systems power off suddenly, always suspect - the power first. I would then look at heat and physical connections next as culprits. Memory errors almost always show up as blue screens.
I say try a new power supply and see what it does. Its not a lot of money either way.
Run CPUID Hardware Monitor and watch your temps. You will have to turn logging on or you will lose the data in a crash.
Make sure your CPU heatsink is still connected properly. Things have a way of working loose.
Apr 21, 2010 | Lenovo 3000 Y410 Laptop
Recovery Commander Starts always and annoys me.
This problem usually happens, ehen you do not do the Shut Down process properly.
Close or save( if modified ) the document or spreadsheet. Then close the program before you shutdown the computer going through the Shutdown command instead of the OFF Switch.Hope this will solve your problem.
Apr 26, 2009 | Vcomm Recovery Commander (804526023624)
Always shutdown my IBM ThinkPad A21m 2628 PC Notebook
It must be a processor overheating problem, check the vents are not restricted and if the fan is always on or never comes on because of a faulty temp setting then theres a overheating problem and the processor will shut down before any damage.
Oct 02, 2007 | IBM ThinkPad A21m 2628 Notebook
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
