Question about Refrigerators
Maytag refridgerator model # mbl2258xes1
Ice build up in bottom freezer compartment
  • 1073 Answers
SOURCE: Maytag side by side refridgerator
the drain tube is clogged or maybe frozen, remove the restriction and you will have no more problem
Posted on Apr 10, 2008
  • 1462 Answers
SOURCE: Ice build up on bottom of freezer
remove back panel inside freezer. you will see drain tray at bottom with a drain hole in the middle - this is blocked usually with ice. melt off with a hairdryer and follow up with hot water till water flows away freely
Posted on Sep 25, 2008
  • 1462 Answers
SOURCE: MY MAYTAG REFRIGERATOR
remove back panel inside freezer and there is a tray at the bottom with a drain hole in the middle. this is blocked with ice. melt off with a hairdryer and follow up with hot water till it flows waay freely
Posted on Oct 02, 2008
  • 192 Answers
SOURCE: Build up of ice in bottom of freezer compartment
During the defrost cycle heaters in the wall of the freezer are turned on to melt the frost build up. This melted frost "water" is supposed to run out a drain in the bottom of the freezer and collect in a pan under the refrigerator/freezer where it will eventually evaporate. If this drain is blocked it will cause a lot of water to collect in the bottom of the freezer and that water will eventually turn back into ice. I recommend defrosting the freezer manually, removing all the ice/water buildup in the bottom, and trying to unplug the drain line to the pan underneath. Also check the seal on the freezer door. If it's not sealing well it could be letting a lot of moisture enter the freezer which would lead to more frost buildup and more water during the defrost cycle.
Posted on May 22, 2009
woodchuck789
  • 4070 Answers
SOURCE: I have a 1999 Maytag Plus side by side
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
If the ice is on the floor of the freezer
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
OR
If the ice is on the back of the freezer
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Posted on Oct 13, 2009
How to access drain hole for maytag model mf12269vem3
please check your ice maker to make sure it is not jammed up water can leak into fridge
Nov 01, 2013 | Freezers
Maytag model MSD2351HEQ freezer side is not working, refridgerator is cold
f1cdedb3-5e7c-47c1-8d68-7566d4da0a75.jpgSounds to me you may have a defrost failure. In most cases the fresh food compartment will show signs first but your model has an auto damper that may be causing the fresh food section to remain cold. Do you notice frost build up on the rear inside back panel of the freezer? Example HERE. If you do you will need to manually defrost the freezer, remove the rear panel of the freezer and use a hair dryer to melt the ice covering the evaporator coils. Example of ice/frost build up on the evaporator coils HERE The most likely cause for the problem is a defective=> 12002495 Defrost Control Board The defrost board is found inside the fresh food section and inside the control panel. Item 12 in this photo HERE is the defrost control board. Second possibility is the=> 67004948 Defrost Heater Item 7 in photo HERE and is the 67004757 Defrost Thermostat and that item location 3 HERE First the defrost control board needs to be checked for burn marks or signs of heat damage. I am here if you would like me to help you get to the parts I listed above, Thanks Sea Breeze
Aug 09, 2013 | Maytag Refrigerators
My freezer on my Frigidaire is not fully freezing?
Take the back panel off inside your freezer compartment and check to see if the defrost coils are frozen over. If they are, you can use a hair dryer to defrost them or just let it sit for a day with a fan blowing on them.
Sep 21, 2009 | Refrigerators
Refrigerator side not cooling
The fresh food section is cooled by the freezer section by forced air supplied by a fan. If you have air flow, check the temp inside the freezer. It should be between 0 and -10. If not look inside your freezer and see if you have ice built up on the back panel. If so you have a defrost problem that is most likely a bad defrost heater, a bad termination thermostat or timer. If ther is no ice then check your fan under the refrig. If you can hear the compressor running it should be turning. If this all checks out then you have a freon system problem like. Low Freon pressure or a restriction.
Aug 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a Maytag plus side by side refridgerator-freezer. The freezer works properly, but the refridgerator temperature is to high.
While you look into the back of the freezer compartment to look for ice or snow collecting on the back panel of the freezer. Let me know what model you have and I will be able to help you with part numbers what you need to do next. Let me know the model number listed most likely in these places, Thanks Sea Breeze
Jul 20, 2009 | Refrigerators
Freezer compartment ice build-up
too defrost just open the doors for a day with the unit unplugged. as far as why it is frosting up check door seals make sure they are all good and seal it up well and that should take care of it.
Jun 26, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water on the bottom shelf of the Refridgerator
Has the refrigerator got a wet inner back?
Ff this is wet, adjust it until this solid ice 'blobs', bt not encrusted, like in a freezer
The refrigerator may not be cool enough and the natural warm moisture allowed into the cool compartment when the door is open is condensing into fluid before it is cooling sufficiently to suspend the moisture as a vapour. If the cool compartment is cool enough, any warm air admitted ill be chilled before it is allowed to condense, keeping the refridgerator dry.
However, the only drawback is that you will have to monitor it to prevent the build up of excesive ice.
Also, whether the refridgerator is either empty of full willaffe the day to day operation.
Hope this helps.
Oct 20, 2008 | Whirlpool ET1FHTXM Top Freezer...
Sep 25, 2008 | Maytag MSD2732GR Side by Side Refrigerator
Refrigerators Logo
32 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
