Question about 2005-2010 Chevrolet Cobalt Turn Signal Switch AC Delco - OE Replacement
How to replace turn signal switch on 2002 buick lesabre ltd
    New Friend:
    Problem Solver:
  • 5 Answers
02 Buick LeSabre Ltd. Rear flashers work (blinking rapidly), front bulbs stay on, inside indicators also flash rapidly. Replaced control module under the dash. Did not help. What else could it be?
Hi there., when flashers/indicators work rapidly on the dashboard you should check whether it is the same on the actual bulds. Fadt flashing is usually a sign of a bulb failure somewhere. If everything is functioning ok externally I would consult a competent technician for a diagnosis.
Jun 08, 2015 | 2002 Buick LeSabre
Why wont the headlights and running lights work on my 2002 Buick LaSabre
Three possibilities. The fuses, the light switch, and the turn signal switch. Most likely the light switch, because the others have different fuses and run from different spots in the TS switch.
Mar 15, 2015 | 2002 Buick LeSabre
Front turn Signal blink fast but no back brake lights or turn signal
I would check the turn signal switch for power in and out of the rear circuits.
Mar 04, 2014 | 2002 Buick LeSabre
Replace the signal flasher for 2002 buick le sable
Looks like the same problem I had on my 2004 Lumina. If the brake lights all work but not the left AND right signals both do not work it is most likely the flasher which is under the driver side of the dash. If you barely move the turn signal lever and the right or left turn on briefly then it is the switch OEM part number 26093875 verify the numbers to match your vehicle. The switch is located in the steering column and can be changed out in about 30 min. Be careful on keeping track of how you take it apart and put it back together.
Mar 19, 2011 | 2002 Buick LeSabre
How do i replace the rear turn signal bulb on a 1998 buick lesabre?
There are usually only 2 ways to replace tail lights -- either unscrew the lens from the outside if there are screws showing, or, (more likely with this older model), open trunk, find the access panel and remove it, then reach in and unscrew the light socket by turning 1/2 turn counterclockwise.
Jan 25, 2011 | 1998 Buick LeSabre
Where is the lighting control module located?
Im not 100% sure but i belive it located under the rear seat or behind it.
Sep 14, 2010 | 2002 Buick LeSabre
02 Buick Lesabre turn signal issue
most likely a bulb. you should be able to get to it.
Sep 17, 2009 | 2002 Buick LeSabre
How do you replace the left front turn signal light on the 2002 Buick LaSabre ? robertwolf7614@comcast.net
their should be two white clips on the headlight you pull the clips up and the headlight comes out including the turn signal part.you open the hood of car and look behind the haedlight for clips hope thise helps
Mar 20, 2009 | 2002 Buick LeSabre
2005-2010 Chevrolet Cobalt Turn Signal Switch AC Delco - OE Replacement Logo
142 people viewed this question
Top AC Delco Turn Signal Switch Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you an AC Delco Turn Signal Switch Vehicle Part and Accessory Expert? Answer questions, earn points and help others
