Question about Dewalt DW735 13 Inch 2 Speed Planer With 3 Cutters
Dw735 planner thickness
Planer wont pull wood through
    Sergeant:
  • 468 Answers
Is it cold in your shop? The rollers won't work if they're cold because the rubber gets stiff. Clean your rollers also with mineral spirits. Hope that helps.
Posted on Jul 11, 2013
Planner just stop running.power @ outlet.
It may have overheated. See if there is a reset button on the motor after it has cooled off.
Oct 11, 2015 | Dewalt DW735 13 Inch 2 Speed Planer With 3...
My dewalt planer dw735 just made a loud pop sound. Then, a piece of metal launched out of the dust ejector, a few sparks flew. I tool the top od and found a hunk of wood that broke of the board jamming the...
have you checked you have not taken a chunk out your blade. also you have to make sure the blades are set spot on. other wise it will affect the balance. good kuck
Dec 20, 2014 | Dewalt DW735 13 Inch 2 Speed Planer With 3...
Replace v belt on dw735 planer
REMOVE COVER SO YOU CAN SEE THE BELT, PULL THE BELT AS YOU TURN IT AND IT SHOULD COME OFF
Nov 07, 2014 | Dewalt DW735 13 Inch 2 Speed Planer With 3...
My planner won't draw the wood thru my planner.
check that blade is correct and guides correct
Mar 20, 2014 | Dewalt Planer (DW734)
Adjustment on dewalt planer
I don't know which planer you have, but if all the planing happens on the top side of your stock then all surfaces underneath should be at the same level.
If you have a fancy planer that cuts on the bottom side, then the outfeed table should align with the cutters and the infeed table would be adjusted below that by the cut thickness (like a jointer
Mar 17, 2014 | Dewalt DW7351 Folding Table for DW735
Plainer won't adjust up and down
Wood chips are probably jamming the height adjustment, and need to be cleaned out. Lubricate the machine once it's clean.
Feb 01, 2014 | Dewalt DW735 13-Inch Two Speed Thickness...
Manual for Ridgid thickness planner model TP13002
Here is a link for a PDF file of the manual (in English) on your TP13002 Planner:
http://www.ridgidparts.com/pdf/TP13002.pdf
Hope this helps.
Apr 24, 2009 | Ryobi Thickness Planer Blades
New DeWalt DW735 planner not pulling wood through machine
Planers were not designed to remove old finish, They were designed to plane new lumber which would be much softer., so likely the need for cleaning seems reasonable. I woudl think a wire brush on the serations of the feed rolers woudl serfice.
Jan 07, 2009 | Tools & Hardware - Others
I just bought a DW735 planer and ran a 6" x 24" piece of 3/4" poplar through it, with the planer set to remove 1/16" of thickness. I used the speed 1 (slow). It ran through fine, but...
where is the ridges happened at the begining of the board or at the end of the board. if its the middle of the board the problem is the roller sleeve may be worn.secondly the roller may have lots of sap from the wood/varsol can do job for cleaning the roller. 3. is the balde. see www.toolpartsdirect.com for the parts diagram,in large the picture
Jul 13, 2008 | Dewalt DW056 18 Volt Cordless Impact...
Dewalt DW735 13 Inch 2 Speed Planer With 3 Cutters Logo
118 people viewed this question
Top Dewalt Saws Experts
JOHN LAPIER
Craig Butler
Craig Butler
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
