Question about Frigidaire 30 in. Electric Double Self-Cleaning Wall Oven
Frigidaire oven will not get all the way hot
My Stove burners and broiler comes on with no problem. But when I turn on the oven it only gets warm and never reaches the desired temperature.
  • Official Brand Answer
  • 4,342 Answers
Good Afternoon Tasha - There could be
a number of any one of several underlying causes in why the oven is
experiencing this particular issue:
Convection
heating element
Thermal cutout
Thermal oven
sensor
EOC
(electronic oven control)
Ignitor
Bake or broil
element
All wired
connections
The parts above will need to be assessed for further
evaluation. Lastly, the oven cavity and insulation should be checked to ensure
there are no gaps or damages that will leak out the heat. At t his time, I
would recommend contacting a professional to assist you further since it is always
a good idea to get the appropriate diagnosis prior to making any unnecessary
part replacements.
Posted on Jul 12, 2013
3 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: I have a gas stove - Frigidaire model FGF326ASA.
You probably have a weak ignitor. To operate properly it should draw 3.5 amps or better. The ignitor must be bright. If it is dim it is weak.
Some repair pix
Posted on Aug 29, 2009
Testimonial: "Thanks for the help, much appreciated. Ignitor was coming on but not pulling full amperage. Am going to replace ignitor."
oldTech2332
  • 2341 Answers
SOURCE: My gas oven (Frigidaire Gallery)
Most probable cause is a weak bake burner ignitor,if you can remove the floor of the oven and see a orange glow but within one minute thier is no flame the ignitor that glows is weak and needs to be replaced,if no glow at all ,if your capable find the 2 wires to the bake ignitor,using a volt meter set to AC volts there should be 120vac to the ignitor. If their is 120 vac and absolutly no glow the ignitor is cracked and needs to be replaced,if their is not 120 vac it could be the gas safety valve or control
Posted on Jul 18, 2011
Testimonial: "I didn't expect a response from anyone; pleasantly surprised that I received a helpful reply!"
Frigidarie stove model#PLGFZ390ECB burners and broiler works oven dont replace iginitor still do not work.
Good Afternoon Cheryl,
I understand that the burners and broiler are working in your Frigidaire range, model# PLGFZ390ECB, but the bake element does not work. I also see that you have replaced the igniter and it is still not working. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine why your oven will not come on. Hope this is helpful.
-Best Regards-
WP
Jul 01, 2014 | Frigidaire 24" Built-In Single Gas Wall...
Oven burner and broiler burner don't warm at all. Stove top burners work. Clock display normal. When turned on lights indicate oven on and preheating (normal). I have reset the main circuit breaker with no...
Hi Brian, thank you for your post!
Sounds like the either both bake and broiler element may be faulty or a potential wiring failure to the elements. You may want to connect with a local servicer who will be best equipped to pinpoint the problem. If you don't know a qualified technician, you can use the service locator option on the manufacturer site to find one near you.
Sep 15, 2013 | Frigidaire 30 in. Electric Gallery Series...
MY MAYTAG OVEN WILL NOT TURN ON WHEN I SET THE ELECTRONIC DIGITAL THERMOSTSTAT LIKE SAY I PROGRAM IT TO 350 DEGREES,,, NOTHING HAPPENS,,, BUT WHEN I GO TO SET THE BROILER THE BROILER WORKS JUST FINE,,, I...
First I want to commend you for your giving us good information to start with!
So-- we know we have gas, and we know the Broiler Valve and ignitor works-- Good observation!
However-- we have no ignitor (No bright red/Yellow glow)-- like you go for the Broiler-- right?
Well, we can NOT get ignition on the main burner-- unless we have the ignitor for the main burner getting hot, and then the gas valve to that burner can light, and give you heat...
Soo-- Likely we have an ignitor failure for the Main burner---
Do you have a warranty on the stove?
Do you have a service person qualified to tackle this job?
There will be electrical work, and parts obtainment issues to deal with now---
I suggest you call the local service people for this stove, and tell that that you need to have the main gas burner ignotor replaced for this stove model number-- and see what they tell you.
Let me know if I can help more--
Mack B
Dec 30, 2010 | Maytag Ovens
Ge profile gas oven broiler works but bake wont light
The ignitor for the oven burner is bad...
Here is a tip that I wrote about that...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Mar 30, 2010 | Ovens
Oven won't get hot
If your oven still uses a pilot light, it also probably has a thermocouple positioned in the pilot's flame path to detect whether if is safe to turn on the main burner. When the thermocouple fails, the oven thinks the pilot light is not lit and will not let gas flow to the primary burners. The part isn't costly (should be <$20 US) but replacing it may require some expensive labor.
Feb 11, 2010 | Frigidaire 30 in. Electric Gallery Series...
MY OVEN DOES NOT GET HOT, THE BROILER WORKS AND
If we are talking about an electric oven. The oven coil is probably bad. Easy to test remove it and check for continuity. If it shows open cicuit them the coil is burned out.
Oct 04, 2009 | Frigidaire Ovens
My Oven and broiler won't heat but stovetop burners work
I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
Dec 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Broiler won't turn off. Error code F-3
hi there,
can you provide the model # off your stove please?
Sep 15, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
WHY WON'T MY OVEN HEAT UP?
Most modern gas ovens and many broilers use a "glow-bar" style of igniter that glows red-hot to ignite the gas. If the igniter doesn't reach the proper temperature, the gas valve won't open. You may need to replace the igniter.
Oct 30, 2007 | Frigidaire FEB27S5A Electric Single Oven
Frigidaire 30 in. Electric Double Self-Cleaning Wall Oven Logo
105 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
