Lg tv ic 9370 vertical line and no rastar & retrace what i do ?
    Top Expert:
  • 12,223 Answers
No raster sympton is rectifier faulty 2) filter leake 3) regulato ic faulty repair.
God bless you
Posted on Jul 11, 2013
4 Suggested Answers
SOURCE: TELEVISION CHASIS HAVING TDA 9370 SINGLE IC
Try zener from abl.
Posted on Sep 13, 2010
  • 68 Answers
SOURCE: I have a JVC AV-32F703 tv just replaced the
Chances are you should have checked some components related to that IC,namely an electrolytic capacitor.They tend to leak or short.That IC burned for a reason.
Posted on Sep 25, 2010
SD Tech
  • 14553 Answers
SOURCE: TOP RETRACE LINES
What did you use to check the caps?
retrace can also be caused by the master screen being set too high.
Posted on Mar 23, 2012
Absence of horizontal scan signal to the deflection yoke. Check all the connection to the deflection yoke. If found OK, the deflection yoke winding [horizontal] is open. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 26, 2015 | LG Televison & Video
Cross lines ontop of screen my G21 M1 tv.. pls tell me how to solve it
The vertical output section of your TV has the fault. Replace all the electrolytic capacitors there, including smoothing capacitor to supply line to IC. Check for any loose solder termianls too. The lines you are seing across the screen, on it tope side, about 2 inches might be due to this fault, and are technically called [vertical retrace lines].
Apr 26, 2012 | Sony FD Trinitron WEGA KV-24FS120 24" TV
TOP RETRACE LINES
Mar 23, 2012 | Televison & Video
Several lines run across the top of the screen
Several lines acroos the screen at the top along with picture is a typical fault. You are seeing vertical retrace lines. Either the supply smoothing capacitor to the power supply given to vertical output Ic or vertical output capacitor connected to the vertical output pin of that Ic may faulty. Usually the supply smoothing capacitor seen faulty. It may be over 1500Mfd eletrolytic capacitor used there. It may get value reduced by 40 percent or so, this falult will occur. Please replace the two capacitors together and will get the result.
Oct 15, 2010 | Toshiba 27A34 27" TV
I have a panasonic tv with retrace lines at the topI
If you can locate the vertical IC you are nearby!. You will have to resoder the grounds on the vertical IC and any cap in the immediate area of this vertical IC is weak. I would replace them all as they will pull each other down. There may be four caps and the largest one, possibly a 25 volt 2200MF would be the only good cap. I dont have the specs on this set, but this will surely lead to a good repair!
May 06, 2010 | Panasonic CT-32D31 32" TV
How do you repair or rather remove the retrace line on screen there is no picture
You have may the brighteness set up too high. if not retrace blanking is faulty. try turning the brighness down a bit.
Dec 19, 2009 | Daewoo DTQ-13P2FC 13" TV
Horizontal retrace lines at top of screen
Change 100uf 50-63volts capacitor next to the vertical output ic,if not solved check the vertical b+ filter on the 24volt line.If nothing else work try damping the vertical yoke with 2 300ohms resistors if in series or just one 220-330 ohm resistor if its parallel vertical yoke windings.
Nov 22, 2009 | Sharp 32J-S400 32" TV
Ic used in which section of philips TV kit
tv set no sound coming.i replce sound out put ic but not hasbeen coming .i think 9370/1665 ic in side a/f out put line is gone i have a this curcuit daigarm not avilable so pl help this point
Oct 10, 2008 | Televison & Video
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
Electro Med Services...
