Question about Exercise & Fitness
Speed sensor position
Year 2000
    Top Expert:
  • 12,223 Answers
See the image attached. God bless you
Posted on Jul 12, 2013
2000 volkswagon bettle 2.0 motor reason for transmission not shifting into passing gear between 50 to 60 miles per hour
Scan the car and check for transmission codes. Could possibly be a faulty Throttle Position sensor, Trans Temp Sensor or Speed sensor. etc.. The first step is to scan it.
Nov 11, 2014 | 2000 Volkswagen Beetle
If a trouble code on a 2000 vw shows speed sensor and the test comes out good what is the problem
engine speed sensor could be faulty.engine speed sensor provides the ECM with a crankshaft position signal.the ECM uses the signal to determine a crankshaft reference point top dead center and calculate engine speed. engine speed sensor like the crankshaft position sensor.if sensor faulty fuel system wont work. a bad engine coolant temperature sensor will cause engine shut off when hot.
Jul 28, 2013 | Cars & Trucks
2000 lancer cedia keeps going into 'limp home' mode!!??
Check for fault codes for the idle speed sensor,accelerator position sensor and crank position sensor
Feb 21, 2013 | Cars & Trucks
Rpm flucuate at highway speed on a 2000 dodge ram cummins
Sounds like your TPS (Throttle Position Sensor), if you have changed that it could be VSS (Vehicle Speed Sensor)
Sep 08, 2012 | Dodge Ram Pickup 3500 Cars & Trucks
Speed sensor
Hi Leon:
DTC P0725 - ENGINE SPEED SENSOR CIRCUIT
When Monitored: Continuously after a ignition key is turned from the OFF to RUN position and/or key is turned from the CRANK to the RUN position.
Set Condition: The code is set when the engine speed sensed by the Transmission Control Module (TCM) is different than the engine speed reported by the Powertrain Control Module (PCM) over the Communication Buss.
POSSIBLE CAUSES
- LOW BATTERY VOLTAGE
- BAD CONNECTIONS AT VARIOUS CONNECTORS
- CRANK POSITION SENSOR SIGNAL OPEN
- CRANKSHAFT POSITION SENSOR GROUND CIRCUIT OPEN
- TCM CRANK POSITION SENSOR MONITORING DEFECTIVE
The Crankshaft Position Sensor (CKP) is mounted to the transmission bellhousing at the left/rear side of the engine block. Engine speed and crankshaft position are provided through the crankshaft position sensor. The sensor generates pulses that are the input sent to the powertrain control module (PCM). The PCM interprets the sensor input to determine the crankshaft position. The PCM then uses this position, along with other inputs, to determine injector sequence and ignition timing. The sensor is a Hall effect device combined with an internal magnet. It is also sensitive to steel within a certain distance from it.
On 4.0L 6-cylinder engines, the flywheel/drive plate has 3 sets of four notches at its outer edge. The notches cause a pulse to be generated when they pass under the sensor. The pulses are the input to the PCM. For each engine revolution there are 3 sets of four pulses generated.
Additionally,
The speed control system is electronically controlled and vacuum operated. Electronic control of the speed control system is integrated into the Powertrain Control Module (PCM). The controls consist of two steering wheel mounted switches. The switches are labeled: ON/OFF, RES/ACCEL, SET, COAST, and CANCEL.
The system is designed to operate at speeds above 30 mph (50 km/h). When speed control is selected by depressing the ON switch, the PCM allows a set speed to be stored in PCM RAM for speed control. To store a set speed, depress the SET switch while the vehicle is moving at a speed between 35 and 85 mph. In order for the speed control to engage, the brakes cannot be applied, nor can the gear selector be indicating the transmission is in Park or Neutral.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Dec 01, 2011 | 2000 Jeep Grand Cherokee
I have 2 falt numbers po715 and po420
P0420 - Catalyst System Efficiency Below Threshold (Bank 1)
P0715 - Input/Turbine Speed Sensor Circuit Malfunction
Dec 24, 2010 | 2000 Chevrolet Tracker
Where is the idle sensor in the 2000 chevy impala
There is no idle sensor on the 2000 Chevrolet Impala, according to my online resource.
But, there is the following that senses rpm of the engine and thus the idle speed when the Throttle Position Sensor is at 5% or the accelerator pedal is not depressed:
Crankshaft Position Sensor Operation Engine speed is a very important input to the Powertrain Control Module (PCM). Crankshaft speed and position are the basis for many calculations made by the computer. Crankshaft position values are transmitted to the computer by pickup coils also known as Permanent Magnet (P/M) generators, Hall Effect sensors or optical sensors. The Crankshaft Position Sensor (CKP) also known as engine speed sensor is typically located in proximity to the crankshaft.
In addition, the PCM uses the CKP sensor in conjunction with the camshaft position sensor to calculate and perform misfire diagnostics.
Related Symptoms
  • A No Start / Intermittent Start condition - Can be caused by a faulty crankshaft position sensor due to loose connections, bad grounds, high resistance in the circuit, or opens in the circuit.
  • Engine Misfire Diagnostic Trouble Codes
NOTE: Engine Mechanical conditions can also create the same or similar symptoms. (Don't overlook basic mechanical integrity).
Nov 06, 2010 | 2000 Chevrolet Impala
Where is the crankshaft sensor on a v6 2000 chrystler sebring
CRANKSHAFT POSITION SENSOR - 2.5L
REMOVAL
Remove speed control servo from driver's side strut tower.
Remove crankshaft position sensor retaining bolt Crankshaft Position Sensor
Pull crankshaft position sensor straight up out of the transaxle housing.
(Disconnect crankshaft position sensor electrical connector from the wiring harness connector.
INSTALLATION - ADJUSTABLE
All vehicles will be equipped with an adjustable crankshaft position sensor. This can be identified by an elongated mounting hole in the sensor.
NOTE: If the removed sensor is to be reinstalled, clean off the old spacer on the sensor face. A NEW SPACER must be attached to the sensor face before installation. If the sensor is being replaced, confirm that the paper spacer is attached to the face of the new sensor Crankshaft Position Sensor and Spacer
Install sensor in transaxle and push sensor down until contact is made with the drive plate. While holding the sensor in this position, install and tighten the retaining bolt to 12 N·m (105 in. lbs.) torque.
Connect crankshaft position sensor electrical connector to the wiring harness connector.
Attach connector to heater tube bracket.
Install speed control servo. Tighten nuts to 9 N·m (80 in. lbs.) torque.
May 22, 2010 | 1998 Chrysler Sebring
Exercise & Fitness Logo
15 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
