Question about Measuring Tools & Sensors
What size is the bolt that holds the pulley to engine shaft on a 11hp briggs and stratton engine
  • 376 Answers
SOURCE: Stratton Briggs Stratton Intek V - Twin Engine 21
The oil is contaminated with water. Change oil and filter, if it has one.
Posted on Jun 14, 2009
  • 583 Answers
SOURCE: Briggs & Stratton Briggs Stratton Intek V -
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
Posted on Oct 25, 2009
kel1guy2002
  • 3740 Answers
SOURCE: How can i remove the drive pulley on the 12.5 briggs and stratton
Hi Steve, There should be an allen head set screw (Sometimes 2) that has to be removed before the pulley will come free. One set screw should be directly above the key way "key" and the second one (If installed) will be within 90 degrees of the one securing the key. Also take a piece of 100 or 120 grit sand paper and sand off the rust areas on the old crank shaft. Occasionally it does require a puller to get them off but usually you can tap gently the pulley every 90 deg (not on the pulley V belt drive area) and it will come free.
This should be a 13HP 2 cyl engine.
Depending on the type pulley they are using. Some of them have a collar on the crankcase side of the pulley that will also have to be removed. (again secured with a set screw possibly 2)
If it is really stubborn you can and should use a puller to remove the pulley. Be very careful if you do have to use a puller; not to damage the V-belt drive area of the pulley.
Thanks for using FixYa.
Kelly
Posted on Apr 29, 2010
  • 5 Answers
SOURCE: Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1: LOOKING FOR A DEW CROSS REF OIL FILTERS TO REPL. C...
motorcraft fl-400 can buy at walmart
Posted on May 23, 2010
SOURCE: Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1: will only start with choke on and after warm (chok...
If it has a plastic intake manifold there is your culprit. The flanges warp and produce vacuum leaks and all three.
Posted on Nov 06, 2010
What is proper procedure for replacing all 3 pulley/ blade drive assemblies. Had trouble getting blade mount plate off of bottom off spindle shaft.
OK I HOPE THIS WORKS I HAVE A T-13560 GUESSING THEY'RE CLOSE, I HAD TO PULL OFF THE TOP COVERS SHAPED LIKE A "V" WITH ONE NUT HOLDING IT ON ,FIRST REMOVE THE CENTER BLADE BOLT UNDERNEATH ...THEN YOU'LL SEE THEIRS 4 1/4-20 HOLDING THE BLADE DRIVE ON BUT FOR ME I ACTUALLY TOOK THE FOUR BOLTS OUT HOLDING THE ENGINE MOUNT OUT IE. THE CENTER OF THE DECK TO EXPOSE THE TOP OF THE CENTER PULLEY (MY BAD ONE) AT WHICH POINT I COULD TAKE AN IMPACT WRENCH TO REMOVE THE PULLEY NUT ...THEN UNDERNEATH REMOVE THE BLADE MOUNT ....MY BOTTOM BEARING FELL APART SO I COULD PUT THE SHAFT IN A VISE , HEAT IT UP AND TURN IT COUNTER CLOCKWISE ...THEN REASSEMBLE GOOD LUCK
Jul 07, 2015 | Swisher T14560 T - 60" Trailmower with 14...
How to adjust the governor on 13.5 briggs & stratton intek engine?
First make sure the throttle lever is on full speed position then unloosen the bolt that holds the governor lever to the shaft which protrudes from the engine then with plyers turn the shaft the same direction that the spring pulls the governor lever until it stops then tighten the bolt the holds the governor lever to the shaft. Sometimes the governor shaft might have a screwdriver slot in it to turn it.
Jul 11, 2014 | Briggs & Stratton Governor Spring 691817...
Removal of carburator from model 303447-0446-01 engine
How can I remove the drive shift pulley on a18hp Briggs & stratton engine
Feb 05, 2014 | Briggs & Stratton Briggs Stratton Intek V...
Briggs
the pulley just bolts on
9/16 i think
may have to use pipe wrench to hold shaft of pulley
spray top of pulley with PB blaster should slide off might have to tap it some
May 01, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Torque specs. for a briggs @ stratton 24hp. head bolts
WHAT IS THE VALVE CLEARANCE ON A 23 HP. BRIGS MOTOR AND THE TORQUE ON THE HEAD BOLTS?
Jul 17, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Jd tractor 11hp briggs engine has no stark
I would check the stator which is located on the top or side of the motor, this is what produced spark and if there is rust on it it will lose spark. so basically remove the fan housing the top of the motor and you should see it either on top or directly on the side i believe it has one wire going to it green in color and is held down by two bolts. good like look out for the rust
Apr 17, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Need over size exhaust seat for 11hp model253417
Go to the Briggs & Stratton web site. Put in the model, type, and code numbers off your engine. You can download the IPL (illustrated parts list), which will give you the part number of the seat - IF available. You can then order the part, but it will be a machine shop job to fit it.
Oct 06, 2009 | Cub Cadet Street Sign- tractor lawn riding...
I need to know how to remove the shaft with pulleys on it that comes out the bottom of the engine
the shaft you are talking about is the crank shaft. in order to remove it you must first remove all pulleys, drain oil, then remove the case bolts. slide case off of shaft then remove the connecting rod bolts. crankshaft should come out hope this helps
Jul 09, 2009 | Briggs & Stratton Garden
I am trying to get the 11 hp Briggs & Stratton engine out of my Toro tractor to replace the gaskets, since it is using & throwing oil over abundantly. How do I get the drive & mower pulleys from under the...
On the end of the shaft that comes from the motor there should be a bolt that holds the pulley in place. You will need to remove the bolt in order to get the pulley off. If you can lift the front end onto a couple of blocks it will make the job easier to do. You may have to place a screw drive in between the belt and the pulley. A wood wedge the width of the belt would be better as it would be less likely to damage the pulley. Depending on how old the tractor is, you may have to spray the bolt with a penetrating oil first to help loosen the bolt.
Hatter1
Mar 14, 2009 | Briggs & Stratton Garden
Measuring Tools & Sensors Logo
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
