Question about Acu-Rite Measuring Tools & Sensors
Acurite 00609a1 remote sensor schematic
Why can't I receive input from the outside sending unit?
Make sure that all the batteries are good!!
This procedure outlines the typical process to pair the sensor and base.
Base Station Battery Installation
·Remove the printed vinyl label from the LCD screen of the base station
·Position the remote sensor near the base station
·Open the battery compartment at the back of the base station and insert (2) AA batteries according to the polarity markings. Replace the battery compartment cover.
·Within a short time the RF signal icon (located to the left of the outdoor temperature channel indicator) will start flashing. This indicates that the base station is ready to pick up the RF outdoor temperature signal from the remote sensor. It will continue to flash for 3 minutes or until the signal from the remote sensor is detected.
Register the Remote Sensor
·Open the battery compartment at the back of the remote sensor and slide the channel selector switch to your desired channel. For the first remote you may select any channel, for additional remotes select any unused channel
·Insert (2) AAA batteries according to the polarity markings. Be sure to install the batteries in the remote within the time that the RF signal icon is flashing on the base station. 1541 WeatherGuide Wireless Weather Forecaster with Barometer
Jan 07, 2016 | Measuring Tools & Sensors
I have an Acurite 822-RX thermometer that shows HH as the outdoor temp, even after replacing the batteries in both the base and remote units. How can it be fixed or reset?
Usually those symbols mean your out of range of the instruments range . Do you have the sensor in direct sun light ? There may also be a defect I would try to contact them
Mar 10, 2015 | Measuring Tools & Sensors
How do I reset the remote after changing the battery life.
To reset your unit, please verify that you are using a good-quality, standard alkaline battery such as Energizer or Rayovac. Then, follow the steps below.
1. Bring both the sensor and display unit indoors and remove at least one battery from each.
2. Make sure the A-B-C switch on both units match. Sometimes changing to a different channel can help.
3. Reinstall the battery in the outdoor sensor.
4. Reinstall the battery in the display unit.
5. Let the units sit within a couple feet of each other for about 20 minutes to gain a strong connection.
If you need any further assistance, please contact AcuRite Customer Support at 1-877-221-1252 or info@chaney-inst.com.
Feb 21, 2015 | AcuRite Acu-Rite 00754 Wireless...
Need User manual
I cannot find your model L50668TX thermometer on Acurite's website. That said, you can search available product manuals here:
http://www.acurite.com/kbase
Alternatively, if you still need more assistance/User Manual information, you can contact them with these details:
Website: http://www.acurite.com/support
Customer SupportTel: (877) 221-1252
Mon - Fri:
7:00 a.m. - 7:00 p.m. CT
Sat - Sun:
8:00 a.m. - 4:00 p.m. CT (Oct - Feb)
spacer.gifWholesale(866) 249-1045
Mon - Fri: 8:00 a.m. - 5:00 p.m. CT
support-mail.jpgMailing Address
Chaney Instrument Co.
965 Wells St.
Lake Geneva, WI 53147
Email: info@chaney-inst.com
Apr 16, 2014 | Acu-Rite Acurite Wireless Indooroutdoor...
Acurite Manuals
Remove new batteries from the indoor station. Carefully remove batteries from the remote sensor, then reinstall. Reinstall new batteries in the indoor station. DO NOT TOUCH ANYTHING FOR AT LEAST 10 MINUTES. You should see the outdoor temperature displayed and can then proceed with other settings.
Nov 03, 2013 | Measuring Tools & Sensors
I WON'T TO KNOW HOW I CAN GET A MANUAL FOR ACURITE 00869
get the model and make of ur product go online to that website and request a manual.
Sep 19, 2013 | Klockit AcuRite 00869 Digital Remote BBQ...
How to reset my Acurite 1099rx after replacing battery
http://www.acurite.com/advancedsearch/result/?q=1099RX
There is no reset button, installing new batteries causes the sensor to reset itself.
Try removing and re-installing the batteries.
Good luck,
Steve
Jan 15, 2013 | Measuring Tools & Sensors
Acurite 1097-rx will not display outside temp or humidity. new batteries. Inside functions normal.
I had same problem. Take all batteries out of both units. Put the batteries in the remote sensor FIRST. Then put batteries in the main unit. Within five minutes, they will link up. Problem solved!
Feb 23, 2010 | Acu-Rite Audio Players & Recorders
Measuring Tools & Sensors Logo
43 people viewed this question
Top Acu-Rite Measuring Tools & Sensors Experts
windryder
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you an Acu-Rite Measuring Tool and Sensor Expert? Answer questions, earn points and help others
