Dx 32l150a11 wont turn on
2 Suggested Answers
  • 176 Answers
SOURCE: I need the remote control
10463 should work for both sets.
  1. Pressand hold the "Mute" button and the "Select" button untilthe visible LED blinks twice. Enter the 5 digit code above.
Good luck,
Robert
Posted on Feb 26, 2011
DYNEX MODEL DX-32L150A11 - when trying to turn off CCD choice is "greyed" out so it cannot be chosen. Tried to reset TV, unplugged it, etc.
If you are connected to a cable box the CCD is enabled by the cable box using the cable box remote or in the cable box settings,
Jan 18, 2016 | Dynex Televison & Video
.I have Dynex 32 lcd.
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Aug 05, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
Dx-800 wont work with answering machine. Tried all the fax settings to use with a tam. Tam picks up line then dx-800 drops out everytime.
Set the answering machine to answer on 4 rings and the fax to answer on 6 rings.Do this with answering machine menu.
May 15, 2011 | Panasonic Panafax DX-800 Plain Paper Laser...
I need the remote control codes for a Direct-TV remote: Models: DX-L22-10A and DX-32L150A11 Rev B Thank you
Good luck,
Robert
Feb 26, 2011 | Dynex Televison & Video
Why wont my Dynex DX-PMSE mouse not work? I plug it in and then the laser blinks and then turns off.
if you're on a laptop make sure you enable the "Disable touchpad when external pointing device available" option in your touchpad utility. I think the touchpad interferes with the dx-pmse. Should fix the problem, if on a desktop make sure you remove all pointing device from device manager and then plug in ur dx pmse
May 03, 2010 | Dynex DX-WOM20 Mouse
VESA Screws
I went to Lowes and found some 4mm .7 screws, 25mm long, and they worked like a champ. (get the lock washers too)
Apparently, most mounts include only 5mm and larger screws
Mar 29, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
I have a dynex 19 inch tv that wont turn on can you help
Look at the power supply first; look for burnt parts, bad capacitors, etc. Look for 5vdc, 12vdc, and 24dvc.
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Dynex+DX-LCD19-09+
Please post back what you find
Dec 18, 2009 | Dynex DX-LCD19-09 19 in. LCD TV
92 toyota corolla dx lights wont shut off
Headlights are wired to receive a constant "hot" even when your keys are out of the ignition. Your problem, more than likely, is in the switch. Depending on what type of switch you have, you can expect to pay between $20-$80 for a new one.
Jun 07, 2009 | 1992 Toyota Corolla
Dynex 37'' LCD TV (DX-LCD37-09) wont turn on
The registration card may help with warranty going through the TV company. But, that's the last option.
You can fix it yourself by replacing this board. The board number should be BA71G0F01043.
The 8 Inverter transformer are the problem. They are on many TV power boards that are causing the same problems.
Ebay is selling a couple for $49. Good price I think.
http://www.google.com/products?sourceid=navclient&rlz=1T4GGLL_enUS311US314&q=dx-lcd37-09+inverter&um=1&ie=UTF-8&ei=oRf9SYKIG5_aswOMoPTjAQ&sa=X&oi=product_result_group&resnum=1&ct=title
If you decied to throw the board in the trash, let me know. I maybe able to help you fix it so you can have a spare board. I fixed mine that way.
May 03, 2009 | Televison & Video
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
