Question about Cobra CXT390 Walkie Talkie Two Way Radios Rechargeable
Cobra CXT390 2-way radios find no noaa weather stations
Older models can find the stations with no problems.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 43 Answers
You might have to manually enter the frequency for your area. NOAA uses 6+ channels, so you may have to google the frequency for your area.
Tom
Posted on Apr 27, 2014
I can get signal from handset to hand set but no voice
Make sure both have the SAME CTSS tones one may wrong RX CTSS.
Apr 16, 2015 | Cobra LI-7200-2 WX VP Micotalk GMRS/FRS...
What mode do cobra micro talk walkie talkies charge on
the ones I have charge on their own charging stand, they are great radios for the $$ as compared to others I have
Dec 27, 2014 | Cobra LI6050-2WXEVP microTALK 22 Channel...
What mode do i charge my cobra micro talk walkie talkies on
the ones I have came with their own charging stand cup bases & rechargeable batteries, they are impressive radios as compared to others I have & they have NOAA channels as well
How do you get the cobra walkie talkie to say the weather
Provided that your 2-way radio has the feature, there should be either a dedicated weather button or somewhere in the menus. Not sure what model you have. If it is a more advanced radio where you can set the frequency, the list of weather broadcast frequencies taken from NOAA are listed below. Two way radios are normally automatically programmed to one of these frequencies and usually require a push of a button.
Nationwide Station Listing Using Broadcast Frequencies
162.400
MHz 162.425
MHz 162.450
MHz 162.475
MHz 162.500
MHz 162.525
MHz 162.550
MHz
Jul 02, 2014 | Radio Communications
Radiocheck shows rf output power failure
its an inside the radio fix mine is doing the same thing and I have had the time to get into it and fix it.
Jan 01, 2014 | Cobra 29 LX 40-Channel CB Radio with...
With my cobra 29 wx nw st I can not pick up any weather channels. I have the k30 antenna. Do I need a dual band antenna?
Do you hear static when you turn on weather? If so there are just none in range of you. There are not weather radio stations everywhere. You would not use a dual band antenna on any CB. Only an antenna designed for the 11 meter band. Which is the 27mhz CB radio band.
You can go here and see if you have NOAA All hazards weather radio coverage in your area.
If the CB radio is working otherwise it is most likely that there is just not a NOAA transmitter near you.
Aug 09, 2011 | Cobra 29 WX NW ST 40-Channels Base CB...
How canifixmyscanner,it scansbut doesnt pick up program stations
You didn't provide the make or model of your scanner, or any real specifics on your problem, but your first step is to make sure that you've programmed active frequencies into it. For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
For a functional check, you should first program and scan NOAA weather frequencies to verify whether or not the scanner is working properly. Many scanners have a WEATHER or WX band function that will let you check the NOAA broadcasts without any programming. If your scanner does not pick up the weather broadcasts you may have an antenna problem or an electronic problem that will require professional repair.
Bill B.
Listening in since the 60's
Jan 18, 2011 | Radio Communications
Can't get the weather report to come on-can't find my insructions to reprogram it to pick up local noaa
You can reprogram it by doing the following:
1. Turn switch on side of radio to "ON".
2. Press "MENU".
3. Press "UP" arrow until "CHANNEL" is displayed.
4. Press "SELECT".
5. Press "UP" arrow until you hear the broadcast of your station.
6. Press "SELECT" to save station selection.
7. Press "MENU" to close menu mode.
To turn Weather/Hazard broadcast on again, press "WEATHER/SNOOZE".
Jan 13, 2011 | Midland WR-100 Weather/RDS Radio
Screams
do you have weather bands on your cb ? you must turn it to the off position (weather bands) or you will here the test signal from
noaa . now you will not get weather alerts.
Jul 26, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
Cobra CXT390 Walkie Talkie Two Way Radios Rechargeable Logo
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
