Question about Ricoh Aficio 1515MF All-In-One Laser Printer
Photoconductor replace How can I replace a photoconductor on a ricoh aficio 1515mf?
  • 31 Answers
I realy hope you changed the damaged/used drum , cleaning blade and developer, for your machine sake!
In reality, all this should be replaced at same time, as the blade is already scratched by old drum and developer have a life time defined. Reseting a drum just "in software" change all parameters, developer will no longer be adjusted to the charges applied to "new drum" and then, problemes will start to show up. In this machine, a full image kit is available, but (i do the same) people just rebuild it.But you have to replace that 3 parts. Another advise. You should not rebuid it more than one time as the gears inside the unit dont last that amount of time, i speak by xperience.Spending money in rebuilding and then the gears go off its more annoying than buy a new image unit every two times. The main reason is that the damaged seals inside the unit allow the developer to go to the gear compartment (back of the unit) and damage them. ah, the developer for this machine is type 28 but pay attention to the amount of it, not a full bag, hehehe! More info is available even here, Fixya, but you should not "go with the others". Read a specified solution in a service manual and post it here is not the same as ask someone that REALLY works with it, remember this and avoid headaches. Aldo
Posted on Feb 13, 2015
You mail us inafrica27@hotmail.co.za - we also suplly and fit pcu's
Posted on Nov 01, 2013
5 Suggested Answers
  • 400 Answers
SOURCE: Ricoh aficio 1515mf photoconductor reset
Found some information here:
http://www.fortc.com/2007/06/17/ricoh-cl4000dn-error-code-sc542/
Try the following
press the yellow “C” button
enter 107
press the red “C” button and keep it hold till the display changes
turn the power off with the big red switch on the front side
turn power on again.
OR
  • Press and hold online + escape, then power on.
  • Use up and down arrow keys to select SP2
  • Press Enter
  • Use up and down arror to locate SP5
  • Press Enter
  • Use up and down arrow keys to select 810
  • Press Enter
  • Confirm the selection
  • Power off and on.
Posted on Jun 01, 2009
newport74
  • 58 Answers
SOURCE: HOW TO REBOOT RICOH AFICIO 1515MF??
need to enter service programs print out 5990-2
then exe 5801 memory all clear
put all the settings back to where the were set
the printout will show you default and current settings
Posted on Feb 27, 2010
  • 232 Answers
SOURCE: necesito los drivers para la impresora Ricoh Aficio 1515MF
http://support.ricoh.com/bb/html/dr_ut_e/ra/model/x15_15f/x15_15fen.htm
Posted on Mar 05, 2010
When copier turned on this morning, alternating with the Ready signal, it said Replace Photoconductor. What does this mean?
Hey!
The photo conductor is your machines drum unit!!Its easy to replace and should be available for purchase at your nearest dealer!!
Good Luck!
Feb 10, 2011 | Ricoh Aficio 1515MF All-In-One Laser...
My Ricoh aficio 1515 printing and copying with background
If background is appearing on your copies, the problem is most likely the photoconductor unit (PCU) which houses both the drum and the developer. It comes as one piece, and you can easily remove the old one and slide the new one in.
The PCU is located to the right of the toner bottle, and the new PCU will come with instructions for replacement, but it is a simple procedure.
If you don't have a local dealer or supplier, you can purchase a PCU online just about anywhere that sells copier toner.
Aug 30, 2010 | Ricoh Aficio 1515MF All-In-One Laser...
Necesito los drivers para la impresora Ricoh Aficio 1515MF
Mar 05, 2010 | Ricoh Aficio 1515MF All-In-One Laser...
WHAT RICOH PRINTER IS COMPATABLE TO THE RICOH AFRICIO 1515
The 1515 is compatible to the 161 and the 171, the two newer generations of similar printers. All three use the same toner and photoconductor units, and are set up almost identically.
Nov 20, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
We have message to Replace Photocondutor. Is that toner? If not, s it self-install or do we call for Tech?
Most photoconductor assemblies are what they call "CRUs". That means that they are Customer Replaceable Units.
Check with the Ricoh web site "Support" to verify the installation process and order the part.
Don
Nov 19, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Aficio 1515MF knocking when printing
Hello sir;Pull out drum unit re-assembly image cleaning roller I believe thatis the problem coming from.
Aug 10, 2009 | Ricoh Aficio SP-C210SF Printer
AFTER PHOTOCONDUCTOR REPLACED PAGES ARE BLANK
IF you replaced the entire PCU, make sure you pulled the plastic tabs from the unit and removed the protective paper from the drum area. I don't remember if the new PCU comes with developer pre-installed.
If you replaced the drum/developer, it is common for the lower developer unit drive gears to wear down and break off some of their teeth.
Hope this helps.
Jun 30, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Try the following
enter 107
OR
  • Press Enter
  • Press Enter
  • Press Enter
  • Power off and on.
Jun 01, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Replace photoconductor message keeps appearing
Reset it .
If you are enter service mode 5-912 default 60K just input Zero "0" this will deactivate the PCU counter.
If it is bad you will have to replace it. It is the Photoconductor(Drum / Developer) Cartridge
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Aug 26, 2008 | Ricoh Aficio 1515MF All-In-One Laser...
RESET THE PHOTOCONDUCTOR
you need to deactivate the pcu alarm.for a detailed explanation let me know if you still need to know how to do it
Mar 13, 2008 | Ricoh Aficio 1515MF All-In-One Laser...
Ricoh Aficio 1515MF All-In-One Laser Printer Logo
88 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
