Question about Bose Companion 2 Series II Multimedia Speaker System (2-Piece)
Bose Companion 2 - Front grill has one dent - Bose Companion 2 Series II Multimedia Speaker System (2-Piece)
3 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: bose companion 3 series 2 multi media speaker system
Hi and welcome to FixYa,
Appreciate the direct "Ask Me".
Initially, the 14 seconds interval is significant. This is indicative that whatever fault it is, it is coupled to a time-based circuitry. The time-based circuitry need not be complicated. it can actually be a simple resistor/capacitor network. The capacitor takes a certain amount of time to charge and then discharge (14 seconds, 'whoomp'). Having said this, then the foremost suspect would be an electrolytic capacitor, probably low value (1~4.7uF), probably a coupler/decoupler. Of course the capacitor serving other functions could very well be the culprit as well.
Corrective measure would entail, identifying/determining which capacitor and replacement. Tedious as it may sound, each capacitor would then have to be tested for capacitance and leakage out of circuit or at least 1 leg un-soldered.
Good luck and Thank you for using FixYa.
Pls be informed that due to my current rank and rating, even a Helpful would be detrimental to my status. Should this solution not address your concern, it would be appreciated if you could just not rate it at all. Cheers.
Posted on Dec 27, 2008
  • 256 Answers
SOURCE: i got my bose Companion
Hi. Try a piece of wire, bend the end into a little hook, work the wire through the hole of the grill and give it a little pull. Hope this helps
Posted on May 25, 2011
Bose Companion 3 Series 2 Multimedia doesn't work.
Maybe a tranformer burnout, this is the most common cause, refer to a Bose service center
Jun 15, 2014 | Bose Companion 3 Series II Multimedia...
How does the Bose companion 2 come apart?
6 retaining plastic clips. Just opened these myself. Use a screwdriver at the retaining clip locations and turn it sideways; pops the front off, then there's just foam and the speaker inside.
May 06, 2014 | Bose Companion 2 Computer Speakers
Bose Companion 2 speakers and Windows 7
Scan your computer with RadarSync so that it will detect which driver updates are needed. It will grab the drivers and update them.
David
Jun 26, 2013 | Bose Companion 2 Series II Multimedia...
I got my bose Companion 5 woofer with small dent on the grill is there any way i can open just the front grill and just give a lil push form inside so it could be back to normal
May 25, 2011 | Bose Companion 5 2 Speakers
How to remove the grill of this box?
To my knowledge they are not designed to be removed and doing so would invalidate ANY form of warrenty. I would strongly advise against both from a safety angle, asthetic angle, maunufactuere angle, retailer angle and a common sense angle.
Dec 19, 2010 | Bose Companion 2 Series II Multimedia...
My Bose Companion 3 coputer speakers are 2 years
i hav the same problem but all three shut off ,and i have to shut off and turn on again
Jul 29, 2010 | Bose Companion 3 Computer Speakers
Would like to know how to open speaker cabiant.Bose companion 2.
currently trouble shooting Bose Companion 2 computer speakers, no sound from speaker, would like to know how to open cabinet to see if wires are attached to speaker?
May 24, 2010 | Bose Companion 2 Computer Speakers
Bose Companion II Computer Speaker: The AC power adapter burnt
My puppy chewed through the cord for my a/c adapter, I just took the speakers into Circuit City, and they found me a workable replacement (the replacement isn't BOSE, but it works just fine).  Hope that helps!
Feb 11, 2009 | Bose Companion 2 Computer Speakers
Bose COMPANION 2 Speaker case disassembly?
yes..the only solution is to pop the front panel with screwdriver...to do this more efficiently (without breaking the front panel) ...first insert the thin screwdriver in the gap in front lanel on side wall...and rotate the screw driver 90 degree..this will pop that side....repeat it on other sides too...i did it last night only.....
my problem was that when i dropped the speaker....its magnet fell down...and its no longer working...i am trying to find another broken bose speaker to replace mine...from e bay,,but no luck till now :(
Jan 06, 2009 | Bose Companion 2 Computer Speakers
Bose Companion 2 Series II Multimedia Speaker System (2-Piece) Logo
32 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
