Question about Sony VAIO Computers & Internet
I Have a Sony Vaio, when I turn my computer on I get weird dots and lines all over the screen
I have an Intel core 2 Duo CPU T7250 with 2.00 GHz 2.00 GB RAM 32-bit Operating System Windows 7 SP1
    Top Expert:
  • Sony Master
  • 12,223 Answers
Restart the computer HOLD the keys fn or CTRL + f11 or f12 depend of your mark, and go to restore factory default and fix it.
If this fail, the screen is faulty, and you must go to the repair shop for fix it.
God bless you
Posted on Jul 11, 2013
3 Suggested Answers
puertobori
  • 7733 Answers
SOURCE: I want to restore my Toshiba Satellite Pro to
Set BIOS defaults
  1. Press the [F1] key.**** Bad RTC battery ****
    **** Bad Checksum (CMOS) ****
    Check system, then press [F1] key
  2. In the BIOS setup screen press the [Home] key to restore the default values, then press the [End] key to save and exit, then the [Y] key to confirm and restart the system.
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Nov 27, 2010
  • 223 Answers
SOURCE: Hi, I use asus Pro T5750
Hi Trifon,
you are detecting a known problem for 32 bit operating systems.
The problem for those system is that they can manage maximum 3 Gb of RAM.
If you want all of your RAM used you have to install a 64 bit operating system. Windows 7 has also a version for 64 bit as well as windows xp (but is not good supported) and windows vista.
Posted on Aug 22, 2011
Intel core tm duo cpu e4500 motherboard
Intel = Processor (CPU ) manufacturer
Intel Core tm = Trademark. The Intel Core is a Trademark from Intel
CPU stands for Central Processing Unit. Another term used is Microprocessor, or simply - Processor for short.
e4500 is an Intel Core2 Duo processor.
Maximum frequency rate ('Speed') is 2.2GigaHertz.
2MegaByte of L2 Cache. (2MB of L2 Cache)
800MegaHertz Front Side Bus. (800MHz FSB)
Tells me Nothing about the actual motherboard. Look on the motherboard for a Model Number. May be in center of motherboard. May be on edge of motherboard. May be in-between one of the expansion slots, on motherboard.
Post back in a Comment.
Also post what the problem is, in your best description.
Computer does not turn on. (Power Supply does not turn on)
Computer seems to turn on, but get No Signal on monitor, or Sleep Mode on monitor, or Power Saver Mode on monitor.
LED lights light up, and fans spin.
Regards,
joecoolvette
Apr 23, 2013 | Computers & Internet
How much memory can a ASUS K501P accomodate?
ASUS K50IP vs SONY VAIO Sony Vaio VGN-SZ44GN? Sony: Processor Speed: 1,800 MHz
Hard Drive Capacity: 100 GB
Memory (RAM): 1,000 MB
Chip Type: Intel Core 2 Duo
Primary Drive: DVD+/-RW
Laptop Size: 13 inches
Features: 10/100 LAN Card, Firewire, Modem, USB, Wireless Network Card
ASUS:
Processor Speed: 2,200 MHz
Hard Drive Capacity: 320 GB
Memory (RAM): 2,000 MB
Chip Type: Intel Pentium Core 2 Duo
Primary Drive: Dual Layer DVD
Laptop Size: 15.6 inches
Features: 10/100 LAN Card, Carrying Case, Modem, Operating System, USB, Wireless Network Card
Mar 19, 2011 | Computers & Internet
My Core 2 Duo CPU Fan has got a problem recently. Would any replacement of the Original CPU Fan be harmful to the computer? If there is any such problem, please let me know. Please suggest any CPU...
Try newegg.com, tigerdirect.com,directron.com,geeks.com. You want a Core 2 Duo cpu fan oem (socket LGA 775). Should be able to get one around 10 dollars or so plus shipping. You can pay more for a bigger fan but you really would not need it. OEM will be just fine.
Jan 11, 2011 | Intel Computers & Internet
What is the best?
Hi!
Thats not easy to tell....its all about money. But i will recomend you 3 verry good cpu:s that is not to expensive and worth the money.
1: Intel Core 2 Duo E6850 3,0GHz Box
2: Intel Core 2 Duo E8500 3,16GHz Box
3: Intel Core 2 Quad Q8300 2,5GHz Box
All of them are boxed, that means that you dont need to buy a separate fan
Nic
Mar 12, 2009 | Intel Core Duo T2600, 2.16 GHz Core Duo...
Upgrading the cpu and heat sink and fan
All the factory fitted CPUs are having such heat sinks as previously u were having.
Check on the backside there will be small plastic covers where screws fit these could be removed by screw driver but u can purchase that heat sink or can use previous heatsink as well if it is working.
Feb 26, 2009 | Intel Socket 775 Heat Sink and Fan up to...
I want to supress the password in the bios motherboard
Newer SONY VAIO LAPTOPS (Core Duo, Dual Core, Core 2 Duo) generates a 16 digit error code like this one: "xxxx-xxxx-xxxx-xxxx" after 3 wrong password attempt, its an alpha numerical code that can be used to generate a master password that can UNLOCK all BIOS settings and the Power ON Password when you turn on The Laptop I just Unlocked My SONY VAIO VGN - AR Model With this code at http://www.laptoprebirth.com Hope this helps for everyone
Sep 27, 2008 | Sony Vaio PCG-FXA Series AMD (A8058677A)...
Difference b/w Core to duo and daul core
Core 2 Duo is a Brand name by intel to identify his class of Dual core CPU
a Dual core CPU is basically two CPU in one package, which dramatically improves performance over previous architectures.
Pentium Dual Core is another brand name by Intel to identify his new entry level CPU offer.Basically Pentium dual-core are similar to Core 2 Duos except they(pentiums) are slower and cheaper.
they both are dual core CPUs.
I would prefer a core 2 Duo having to choose a laptop because of better performance, but the prize is different for the two solutions.
Jun 28, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Cpu enquiry
There really is no difference, there are differences in the E numbers though. Those are specificallt about it's GHz's, it L1 and L2 cache.
Though Intel Core 2 Duo is the same as Intel Dual Core. It's just a different name. This confusion is caused because of Intel changing the names of it's processors series. The Pentium brandname for example is gone. Intel Pentium Dual Core is now called Intel Core 2 Duo.
I hope this answered your question.
Greetings,
DarkNeogen.
Jan 25, 2008 | Intel Core 2 Duo E6600, 2.4 GHz E6600...
Are they compatible?
Hi, your cpu currently in the machine should be a 754chipset, only way you would be able to put a core duo processor in the machine would be to replace the motherboard, cpu, and probably the memory.. to DDR2
Have a good new year
John
Dec 29, 2007 | Intel Core 2 Duo E6600, 2.4 GHz E6600...
Computers & Internet Logo
27 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
