Question about ASUS Computers & Internet
Bad charger contact
Recently my pc randomly turned off and it wouldnt start back up so quick, when it did i noticed that the battery charger gives a very bad contact with the laptop and i smelled something weird like burned chemicals so now i have to put the charger in all sorts of weird angles to let it charge,any solutions?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • ASUS Master
  • 1,001 Answers
Apple USB Charger Cable, Lightning Cable for Power Cord Connector with Nylon Braided Amazon com Charm sonic 2Pack 3 Meters Apple USB Charger Cable Lightning...
Posted on Dec 30, 2016
    Top Expert:
  • 12,223 Answers
The laptop must be turn on when you connect the adapter. If you feel that something is smelling again, is sign that the power supply inside of the computer is faulty, go to the repair shop for fix it.
However you can RUN the software diagnostic comign with the computer of download from the website manufacture supplier
God bless you
Posted on Jul 11, 2013
  • 163 Answers
SOURCE: Notebook smells like burning plastic.
The 700 Presarios were notorious for Trace shorts at the Jack and F1.. There is a work around but these were not a safe unit as they can arc and smolder burning a hole in the systemboard. We reapired a ton of them back in the day.
Posted on Jan 18, 2008
  • 236 Answers
cud be your onboard voltage regulator for the battery charging. if you remove the battery and use the external power source does it smell also?
if the battery charges normal out of the unit, and the laptop works well with the AC power unit without the battery, then it's your voltage regulator for the batt charging
Posted on Mar 18, 2008
farhangM
  • 64 Answers
SOURCE: Gateway Laptop not charging
It sounds like defective power jack. Bring it to a reapir shop.
Posted on Dec 01, 2008
FoxSysPCTech
  • 107 Answers
SOURCE: compaq HP 6715s Laptop not charging!
If you can determine that it is not the battery just going bad, then most likely it is a problem with the motherboard. I actually have this same problem, and have not been able to find a quick fix.
HP has a battery tester tool. If you are able to use this, then you are one step ahead of where my HP laptop is. I tried running this and it insisted that I did not have a battery installed, or that it was dead. If you have this same problem, then it looks like it might be time for a new motherboard.
In anycase, it might also be worth the time to try draining the battery completely and attempting to charge it back up. According to a few other sources, the laptop can sometimes get confused and think that a full battery is calibrated to be a low battery.
Posted on Jul 05, 2009
  • 193 Answers
SOURCE: Laptop Charger will only work is laptop is turned off.
it sounds like the charger does not have sufficient wattage for your machine. i would try getting a certified acer power supply.
Posted on Aug 14, 2009
Testimonial: "Confirmed my theory. ^_^"
Hi, I have a Harman Kardon Go Play 2016 version which I have owned for roughly 14 months (conveniently falls outside the warranty period). 5 weeks ago it started going off randomly during unplugged use,...
Sorry but we have no idea what might be at fault . they do not give us units to play with and figure out problems . try the manufacturer's website and technical support
Dec 26, 2017 | The Computers & Internet
My Fujitsu Lifebook AH531 won't start up all all, as if the battery is dead. I've bought a new charger and the problem remains. Can anyone help please.
you need to find out if you are getting voltage to motherboard may be a bad jack if you do not have the tools bring to a repair shop
Jan 19, 2013 | Fujitsu LifeBook AH531
I have a compac presario cq60, I've recently got a brand new charger and battery both from hp as they both needed replacing. I've put the new battery in and plugged the charger in but I noticed that the...
First thing to check is that the battery is inserted properly. Take the battery out, make sure there's nothing on the contacts, and then put it back in. The problem could also be that the charging jack on your laptop is loose. If you hold the charging cable plug in the laptop with a little (not a lot) force, or push it a little to the front or back, does it stay charging? If it does then the jack is loose. Your temporary fix is to hold it the way you did while testing to see if it was the problem. Be aware, this fix is strictly temporary, eventually the jack will get loose enough and not make contact at all. Consider calling Compaq customer service and checking to see if it's covered by warranty.
Mar 24, 2011 | Computers & Internet
I have a blackjack and it was working perfectly fine about fifteen minutes ago, i had it on the charger and it wouldnt charge, then it randomly started to charge then stopped and turned off by its self. I...
Try this:
1. Remove battery
2. Plug the charger or the USB Cable if you have it.
3. Place battery back in.
4. Let it charge (if it charges) all the way til you see green light.
5. Turn it on.
I hope that works.
Jan 05, 2011 | Samsung Blackjack SGH-I607 Smartphone
My huawei ascend m860 wont charge. when i plug in the charger nothing happens. it was working fine yesterday and last night it wouldnt charge up. today i bought a new phone charger and it still wouldnt...
This happened to me too, you have to take your phone back to who you bought it from so they can repair it. Its the chip inside the phone that is bad. Not the charger.
Dec 31, 2010 | Cell Phones
HP Pavilion dv7 Problem.
your laptop is hard wired to shut down when the input is to high into this port. You more than like have a damaged AC/DC converter box in the line (the little box on in the middle of the power cord). This handy little thing converts your powerful and destructive AC current to a DC range that is compatible with the delicate circuits of your system. I would recommend refraining from plugging this system in until the cable has been replaced as you may soon encounter catastrophic failure of key components. HERE is a link to heck out a few online purchase options.
GOOD LUCK AND PLEASE RATE THIS POST!!!!!! :D
Oct 14, 2009 | HP Pavilion dv7-1130us laptop
My toshiba satellite p200 keeps turning off randomly.
Often this indicates that the battery is nearing its end of life. Even when plug and using the AC adapter/charger, this would occur if the electrical consumption is always at its peak. Noticeable is especially when the built-in WiFi card is in use.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 22, 2008 | Toshiba Computers & Internet
Cell Phone randomly powers off
most cell phones have lithium batteries that only have a certain life span. It may be worth your while to buy a new battery for the phone
Nov 21, 2008 | Sanyo Katana SCP-6600 Cellular Phone
Battery exhausted
I found this happening until I decided to change to re chargeable batteries and havnt had this problem since.
Aug 19, 2007 | Nikon Coolpix 3200 Digital Camera
My PC won't run with ac /dc power!
Hello. There is a hardware failure with the laptop not the AC charger. AC chargers have some range of protections of their own. If the power requirements of the laptop are bigger then what the charger can handle, the charger will turn off. Also other parameters can bring the charger offline. In your case, you have a problem with a small chip, the battery charge controller unit, witch regulates the amount of current required to propperly charge the battery. When this thing fails, the charging requirements for the battery are reported rong and the AC charger is forced to give more power then necesary. This results in disconnection of the AC charger ( an internal fail safe of the AC charger) and the laptop to swich back to battery power. When the laptop is turned off, it can charge the battery because the power requirements are low, having all processor, main board, hard disk etc turned off. Therefore the AC charger can handle the load. However you will need to have it checked by a service center as it is a hardware fault. Both AC charger and laptop needs that check. The charge controll circuit needs to be replaced probably. It will be a somewhat expensive repair. Don't buy any other battery untill you have the laptop checked. For more aditional info please post back. PS. Sorry for my bad english, I am from Romania, it is pretty hard for me to explain tehnical stuff in english.
Feb 12, 2007 | Sony VAIO FRV28 Notebook
Computers & Internet Logo
70 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
