Question about Ricoh Office Equipment & Supplies
How to turn off "handset mode" in Ricoh Fax 4430L
Cannot figure out how to turn off "handset mode" on fax machine Ricoh 4430L
checkitright
  • 1362 Answers
SOURCE: how do i change the modem speed on ricoh 3900 fax machine
here is the manual
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=16cc4320e2ae38af56a141f15a196713&q=ricoh+3900+fax+manual
Posted on Dec 05, 2007
checkitright
  • 1362 Answers
SOURCE: Ricoh 3320l DTMF tones
here is the manual
http://www.retrevo.com/s/ricoh+3310++manual
Posted on Jan 22, 2008
blueydfox
  • 13 Answers
SOURCE: Ricoh 3900 L Fax Machine - Bottom Catch Trays (for receiving faxes)
Here the numbers.
H545 2130 Copy Tray 1
H545 2131 Copy Tray Extension
Posted on May 02, 2008
SOURCE: fax machine borther fax 565
change the distinctive mode to off.......menu-miscell.-distinctive
Abdalla Alyhabib
aalyhabib@yahoo.com
Posted on Feb 28, 2009
  • 398 Answers
SOURCE: Ricoh 5510L Network Setup
Go to user tools-key op tools-network-tcp ip- ip address put the appropiate info in.(including gateway address.) then type the ip address into the top portion of a web browser an you should be in web image monitor. you configure the printer there. User name is admin no password. -Carl
Posted on Jul 08, 2009
Ricoh fax 4430l how to reset the machine
two answers here -
http://www.fixya.com/support/t9775020-changed_pcu_in_ricoh_4430l_clear
Aug 07, 2014 | Ricoh 4430L Laser Fax
Tel/Fax/Answering machine keeps freezing
Dear mariss34
While receiving a fax you shouldnt pick up the handset, but if u pick accidently then u will not recieve fax and hence u will hear an engage tone. If you are using a single line for both tel and fax then the party who is sending the fax should pre-inform you that it is a fax call so that when it rings you dont pivk up the handset.
You can also check your line weather it is working properly by using a normal telephone. This should be the first step rather, make calls to confirm it.
The last option is Power off the tel/fax machine for 3min completely and then try again.Also make sure the tel/fax is in tel mode and not in fax mode. Try to assign it in both modes.
If still you are not clear then the mannual which comes along with should help you, If still you cannot figure it out, Then you can call your service provider for help, they should definetely help you out.
Thankyou
Feb 10, 2008 | Office Equipment & Supplies
How to send a fax while receiving at fax at the same time
You can't. You can set your docs in the feeder, and dial a number, then when receiving is over it will send what you have.
Feb 07, 2011 | Ricoh 4430L Laser Fax
Accidentally set the pulse/tone dialing feature to pulse for a Ricoh 4430L. How do I change it ?
Option setting within "Setup" menu (need access code of 2222) allows you to see advanced features not normally viewed after installation of fax machine is completed. Within these advanced features is a parameter to choose analog line setting of either tone or pulse.
Jan 09, 2010 | Ricoh 4430L Laser Fax
Error message -using handset (no handset on the machine. mfd - 1515
If this appear for the first time see the follow, if this started to appear after a time of usage you will need to call a Ricoh technician, sorry but i cannot gain some help in this type of problems.
see do you use a cord with two wires or four for Ricoh when using some telephone centrals like a Panasonic it's better to use a two wired cord for the line, if this still do not help, you will need to call the telephone central technician to set the line for the Ricoh fax.
Nov 17, 2009 | Ricoh Aficio 1515F Plain Paper Laser Fax
Ricoh fax 120 please let me know how to put ricoh on automatic fax receiving while not in the office also when someone rings i can hear the fax sound from my ricoh
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} - Follow the next instructions to change the reception mode :
1. Press the [F2] key. “ this key is located on the left side of the Control Panel next to the key [12] from the left side and next to the [Memory Trans.] key from the rigt side ”
2. Press the left arrow key to select the reception mode “ this key is located under the Display of the Control Panel”
3. Press the [OK] key when on the display is displayed the mode you want.
note:as you sad you want the machine to reaceive faxes when you are out of the office, so the reception mode [Auto Select] is the most compaible mode for you.
The machine can treat incoming fax
messages and telephone calls in three
ways.
1.Manual Receive
- Use this mode if your line is shared
by a fax machine and a telephone
but you wish to answer all calls
yourself and decide whether they
are fax documents or telephone
calls. You must manually press the
[Start] key to receive a fax.
The machine will ring continuously
until you answer the call, so you
have to be near the machine at all
times. The Manual Receive indicator
is lit when the machine is in this
mode.
2. Auto Receive
- Use this mode if you have a dedicated
fax line. The machine assumes
all calls are fax documents.
It will ring once to alert you of an
incoming call, and then starts receiving.
3. Auto Select
- In this mode, the machine rings a
number of times. You can answer
the call while the machine is ringing.
If you do not answer the call,
the machine automatically changes
to receive fax messages.
Jul 11, 2009 | Ricoh Office Equipment & Supplies
No fax tone giving if this fax mode only
Using "on hook" you should hear a dial tone, if you have one then dial a known good fax number. It could also be in manual receive mode. -Carl
May 05, 2009 | Ricoh FAX1900L Plain Paper Laser
Mode incorrectly switching to Handset
Hi Sue, Can you tell me if there is anything else conencted to your fax line? Most Ricoh products will display handset if the dialtone is not detected. It could be that something is using the line or is causing it to short. Another thing to check if the machine is an older 1515- if this occurs after you receive a fax and you are behind a PBX, there was a batch of modems in the Ricoh machines that had a problem with not disconnecting the line, resulting in the handset being displayed. Could be any number of items, normally I would start the troubleshhoting with line issues and go from there.. Brad
Aug 17, 2007 | Ricoh Aficio 1515F Plain Paper Laser Fax
147 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
