Question about Samsung ST150F Smart Digital Camera Red
How to turn off ptp mode on a ST150F smart camera
It comes up as :ptp mode and I can't take photos, look at photos, and or do anything. !!!!!! HELP ME!!!!!
How do I disable the PTP mode in my Samsung ST150F smart Came
TO CHANGE THE PTP MODE OFF IN SAMSUNG ST150
1) Turn the camera off
2) Hold the zoom out (-), flash button( PHOTO TAKING) and the Menu button.
3) While holding, turn the camera on.
4) When the camera turns on, it will show a text screen
5) You can let go of the zoom out and the Menu button
6) Press the Menu button
7) Press left. This will turn PTP Mode off
8) Turn the camera off and on, and you're good to go
Aug 21, 2013 | Samsung ST150F Smart Digital Camera Red
Ptp mode
Turn on camera, press home button. Click to Main Settings 1 and then use down arrows to go to Main Settings 2. Highlight USB MODE PTP, and use right arrow to change setting to AUTO, and press Home button to exit
Jun 08, 2013 | Samsung S1050 Digital Camera
My xp computer cannot detect my canon camera
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Aug 28, 2012 | Canon Ixus 105 12. Mp Digital Compact...
I can't download pictures to my computer error message says cannot detect camera
It may be a USB port issue or a USB cable issue. Try an alternate cable or a different USB port. Try other USB devices on those same ports to make sure they work. Try using a USB card reader to transfer photos from the card directly instead of plugging in your camera directly.
Jul 04, 2012 | Canon Powershot Sx150 Is 14.1 Mp Digital...
PC cannot detect camera when it is attached by USB cable
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Apr 07, 2012 | Canon PowerShot SX110IS Digital Camera...
I cannot down load my photos from my digital camera on to the computer. I have connected the cord to the camera, switched it on, connected the cord to the computer USB outlet and no message comes up. I...
Sometimes a certain usb port, for whatever strange reason, will not detect. Try a different usb port, and see if that helps. You might have a bad cord, so try a card reader if you have one. You might install the CD that came with the camera, if you have it.
Good luck, and hope this helps.
Sep 12, 2010 | Cameras
Connecting my Rebel to my Laptop
I would highly recommend you to use a fast USB 2.0 compliant Compact Flash card reader to copy photos from your CF card to your PC. This is much faster than trying to copy the files from the camera, as your camera is USB 1.1 compliant (ie. very very slow).
However, if you wish to use your camera to copy files with Windows Vista, you must switch your 300D to operate in PTP (picture transfer protocol) mode instead of Normal one. (in the camera's screen, go to the last tab, and change the option: Communication from Normal to PTP). I am not sure though that the PTP mode will allow you to copy RAW images. You have to check it.
As for the RAW images, I suggest you download and install the Canon RAW codec from:
http://software.canon-europe.com/software/0026049.asp
This codec will allow you to open CRW files directly from the Windows Photo Gallery application. Perhaps if you install this codec first and then try to connect your camera in PTP mode with your PC, to succeed in what you want. Still though, I recommend you to buy a cheap USB 2.0 CF card reader, it will save you hundreds of hours of Camera to PC download time.
Hope this helps.
Jun 22, 2008 | Canon Digital Rebel / EOS-300D Digital...
Cannot download photos
What is ptp utility new to me. I suggest the first thing to do is if you have the software from the disk loaded - you un install it. Restart the computer - plug camera in and set it to upload mode. Windows scanner/Camera Wizard will take you along from there. If it does not change the USB port. Come back with the next move
Sep 03, 2007 | Canon PowerShot A540 Digital Camera
I can't open because it is not a supported file
First off what type of computer are you using? MAC or PC? Second if you are using PC and installed the photoloader software that came with the camera you should be able to connect your camera and then it would open automatically to download your pics. Try changing your camera to PTP and then you can save your pics into My Photos in your My Documents folder. To change to PTP press menu while in the REC mode. Go to setup tab and go up to USB press right arrow & highlight PTP and press set. Then connect your camera and it should open up "Microsoft Camera & Scanner Wizard". From there follow the prompts to load into My Pics.
Jul 11, 2007 | Casio EXILIM ZOOM EX-Z600 Digital Camera
Samsung ST150F Smart Digital Camera Red Logo
341 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
