Question about Toro Arnold 21" Recycler Mower Blade 490 100 0026
Toro ph-xt675-3012 carburator not getting gas
Starts with starting fluid then stops running.
  • 37 Answers
SOURCE: toro 421 snowblower won't start
check to see if in line fuel shut off valve is open.If so,sounds like carb is gummed up.
Posted on Jan 28, 2009
  • 33 Answers
SOURCE: Toro lawn mower sputters and stops working after running
fuel delivery probblem might be vapor lock(to much heat getting to fuel lines and carb) may also have dirt in fuel bowl on carb and in tank ,gas tank lid may not be venting . it will be one of these three things
Posted on May 02, 2009
  • 86 Answers
SOURCE: I have a 2006 Toro 6.75 hp GTS lawn mower. I am
Your carburetor needs cleaned,you had gas in it that you drained out and replaced with new ? What engine do you have tecumseh,briggs,? Anyway remove carburetor and take apart get acan of carburetor cleaner and spray though jets in carburetor and blow out jets be carefull not to blow out needle seat !
Posted on May 16, 2009
  • 10865 Answers
SOURCE: toro recycler will run until primed gas is consumed.
The problem is that the gas that sat in the carb all winter glazed it over and gummed it up. Begin by going to any auto parts store, like an aiutozone, and getting a bottle of carb. cleaner. Seafoam is one I use. Add it to your gas, one ounce per gallon of gas. Also, pick up a can of engine starting spray.
Remove the air filter and spray the engine starting spray into the air intake. Pull start the engine and give it additional squirts of engine starting spray until it runs smoothly.
Posted on May 30, 2009
SOURCE: mower will not stay running
cleaning the carb might work soak it in gas foe a lil wile and it may fix the problem
Posted on Sep 09, 2009
My gas blower will only start if I put gas in plug hole. it starts and runs fine then. what is causing this?
Sounds like you have a clog in one of your carburator circuits.I recommend cleaning and or rebuilding your carb.
Dec 04, 2014 | Toro Garden
WONT START TORO PH-XT675-2011 USED ONLY 5 TIMES
You have to take carb off and remove bowl with #10 wrench then look in that tube and unscrew ur jet in that tube and get a sewing needle and push thourgh jet hole .
Aug 26, 2012 | Toro Garden
Toro lawn mower wont start (super RECYCLER)1998 module. I have changed spark plug and air filter.have been using fresh gas from start of season. any thoughts of what my next step should be
Hi. Get a can of starter fluid from your local auto parts store and a helper. Squirt a little into the air intake, start it and have your helper continue to squirt more fluid to keep it running until you clean the gunk from your carburator. J.
Jul 06, 2010 | Garden
pour alittle gas in carburator & then try starting see what happen if it starts & then dies then you have a carburator problem
Nov 09, 2009 | Toro Lawn Mower With Toro Power Tools
I have a 1 year old Toro leaf blower. I have changed the gas and plug and it won't start. I have followed the instructions religiously any suggestions?
if it has been sitting around for a while it may need some help try spray starting fluid in the carburator and it should start even for just a little while but should start then you may have to rebuild the carburator
Nov 04, 2009 | Garden
WANT START
Take air filter off spray starting fluid in the carburator see if it starts if it does its the carburator if it doesnt its probably the sparkplug or not firing
Itsman
Sep 06, 2009 | Toro Garden
Toro recycler will run until primed gas is consumed.
May 30, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Arnold 21" Recycler Mower Blade 490 100 0026 Logo
303 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
