Gli sound systems am-1000
No output to speakers
    Top Expert:
  • 12,223 Answers
Test this God bless you
The speakers are not connected properly. Check the speaker connections. The Mute function is activated. Turn off the Mute function. The volume is turned all the way down. Turn up the volume. Neither set of speakers is selected (if unit has A/B buttons to select sets of speakers). Press either A or B to select a set of speakers. Both sets of speakers are selected, but only one set is connected (if unit has A/B buttons to select sets of speakers). Press the appropriate button to deselect the speaker outputs which are not connected. The receiver is set to TAPE MONITOR (if applicable). Turn off TAPE MONITOR mode. Headphones are plugged into the main unit. Unplug the headphones. The source selector is set to the wrong source. Select the proper source. The impedance of the speakers is less than the rating for the system. Use speakers with the correct impedance rating.
Posted on Jul 11, 2013
How do I hook up the receiver to the subwoofer to the tv
Here's the Owner's manual -> https://docs.google.com/viewer?url=https%3A%2F%2Fwww.paradigm.com%2Fdownloads%2FOM-100.pdf.
There are many ways to connect the system depending on your receiver's outputs and the speakers. Usually, the TV L/R output connects to one of the receiver's inputs. The receiver's preamp sub output goes to the powered subwoofer. The receiver's FL/C/FR/SL/SR/RL/RR speaker outputs go to the respective speakers.
Mar 03, 2017 | Paradigm Audio Players & Recorders
Code to change settings for Small loud speakers to large. Model No HT-F450K to HT-F455K models
Speaker size selection usually is part of receiver set up; the DVD player has nothing to do with it.
Jun 27, 2016 | Samsung HT-C650W DVD Home Theater System,...
I have a 12" d4 type r 1000 rms and a alpine 1000 amp speaker sounds great but smells like something is burning, my amp never over heats or shuts down but the smell is still coming from the sub?
Cut your gain back on the amp. It sounds like they are set too high. Check your install instructions on how to set your gain. If you have a 4 or 5 volt output head unit your will not be at half way. Im running a JL Audio 500 /1 on a skar wwv10 dvc in a ported box. My gain is set about half way & its plenty loud.I have a Alpine 9887 headunit 5 volt output on my RCAsI can take a volt meter & set my speaker output at 45amps & my gain in perfect.
Apr 28, 2014 | Alpine Type-R SWR-1242D Car Subwoofer
When I changed my operating system of my laptop dell latitude D 620 I lost my sound output,what could be the problem?
you might be missing the audio drivers - try locating the audio drive on the dell website using the service tag number on a label beneath the laptop
Oct 02, 2013 | Altinex DRIVER/GLI CARD, 2-IN 2-OUT,...
I bought a new panasonic home cinema model number sc-pt480eb-k. Its supposed to be 1000 watts but the output it doesn't match that output at all even with all the speakers on. What maybe the cause of this...
Hype on the part of the maufacturer's published specs.
http://service.us.panasonic.com/OPERMANPDF/SCPT480.PDF
Look at the Power Comsumption spec on page 22. "90 watts"
According to this post, 45 watts...
http://reviews.cnet.com/home-theater-systems/panasonic-sc-pt480/4507-6740_7-34024832.html
It would be a miracle indeed to extract 1000 watts of sustained power in any form, be it heat, light, motion or sound from a unit that uses anything less than 1000 watts of electricity, assuming 100% efficiency. Not to mention the dreadful 10% distortion level they use to get that figure.
To say it pushes 1000 watts is dishonest and preys on the gullible.
Apr 10, 2011 | Panasonic Audio Players & Recorders
Red blinking light on the volume dial.. why is this happening?
Check if you have make the good settings for the speakers selection.
You need to have speakers connected in the output you selected.
Could be the issue.
Spider Guy
Mar 04, 2010 | Gli Pro A-6600 Amplifier
CAN i purchase speakers for sanyo da 1000
Unless you want the same speakers for cosmetic reasons, you can get a pair of speakers from any Hi-Fi outlet. All you need to know is the max power output of the amp in watts for each channel, and the ohms it puts out. For instance if it says 8ohm 15 watts. You can get a speaker of 8ohms or higher, but not lower. And any speaker above 15 watts.
Actually you can get better quality sound from the speakers as the speakers they often put with these systems are rubbish in terms of hi-fi quality!
PS
Just had a look around the net and the output power in watts is just 8. Couldn't find the ohm rating but most are 8ohm. So any speaker higher than 8 watts will do the job.
Feb 10, 2010 | Sanyo Audio Players & Recorders
What sort of cable I may need to connect my Gli-768 Stereo speaker system,having woofer and tweeter
Cable type is dependent on length of wire, for optimal results. Make sure both speaker cables are the same length, and as short as possible. Under 10 ft you can use 18 gauge wire, and over that length, a 16 wire. Extremely long connections might warrant a 12 wire, but few amplifiers can handle such high resistance without seriously distorting the sound.
Feb 03, 2010 | Car Audio & Video
Problem with speakers, Mac laptop MacBook 13" white
Have you made sure that the sound options in system preferences are all set, and not muted? Open system preferences, choose sound, go to the output tab. Make sure it's not muted or something silly.
If that's not it, and you're mechanically inclined, you can try opening the mac case and see if the speakers are disconnected. Although, I doubt they are unplugged.
Steven
Sep 17, 2008 | Computers & Internet
42 people viewed this question
 Grubhead
Grubhead
