Question about Ovens
Frigidaire oven pilot light
Good Morning, I have a Frigidaire Range Model # FFGF3053LSH in which the burners will not ignite. When the burner knobs are placed in the "LITE" position, the burners just exert gas but there is no ignition or even "clicking" as if the burner is trying to light. This product is less than 90 days old. But when the oven turns on, it works just fine and heats normally. Could you tell me where the pilot light would be located as I can't seem to find it in the manual?
3 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: kitchenaid gas range model# ykgsc308lso oven
If it takes more than 2 minutes to light then that ignitor is weak. It should be very bright. It has to draw 3.5 amps to open the valve. The valve is good because the ignitor is working the oven control is good, all it can be is a weak ignitor. It should draw 3.5 amps or have measure 37 ohms.
Posted on Jan 14, 2010
ftw1952
  • 10319 Answers
SOURCE: I have Frigidaire Gallery, gas
You need a new spark module as shown in the link provided below
http://www.repairclinic.com/PartDetail/Spark-Module/1483923
When bad you will nor get the range to light. You can light it with a match until you replace this part but be careful doing it that way
Posted on Nov 25, 2010
GAS OVEN WILL NOT GET HOT
see this instructions and fix it. God bless you
  1. eHow
  2. Home & Garden
  3. Home Appliances
  4. Other Home Appliances
  5. How to Troubleshoot a Gas Range Oven That Won't Heat
By Kefa Olang, eHow Contributor
Although gas range oven may prove useful for cooking and baking, they may fail to ignite if they aren't properly maintained and set up. Lighting a gas range often involves simply turning a knob; however, blockages from food particles and debris caught in the burners, improper burner cap installation and gas supply are common problems that interfere with your gas range oven's performance. A few troubleshooting guidelines may solve these problems safely.
Other People Are Reading
Things You'll Need
  • Toothpick
  • Paperclip
Instructions
    • 1
      Check you have gas in your tank if your gas range oven won't heat. Contact your gas supplier if you've run out of gas.
    • 2
      Clean the burners if you have gas but your burners still won't ignite. To clean the burners, lift the burner caps 9b4f010f-be4f-4db6-8a88-4c3fd17e3339.gif
    • 3
      Inspect the small vertical holes on the side of your burners for dirt, food and debris. The gas won't ignite if they are clogged. Scrape dirt, debris and food from the vertical holes using a pointy object such as a toothpick or paperclip.
    • 4
      Reinstall the burner caps properly. If they are tilted or wobbly, the gas may not ignite. Install the caps on the right burners. Some burners are smaller than others, so match the caps to the appropriate burners.
    • 5
      Move the burner knob to the "Lite" position and wait for the gas to ignite. If it ignites, rotate the knob to your desired setting. If it doesn't ignite, contact a qualified appliance technician.
Jul 18, 2013 | Ovens
I have a Frigidaire model FCG30B6Q0JWI-5A gas stove (Made in Costa Rica) and can't get the oven to stay lit. There is no electronic ignition, no pilot, it's just a regular run-of-the-mill light a...
While your holding in the knob after lighting the pilot,their is a thermocoupler that is heating up and will hold automatically what your pushing in, that thermocoupler is defective
Jul 28, 2011 | Ovens
My oven stopped working on my frigidaire range. All top burners still work. What could be the problem?
Can you clarify a couple of things for me please:
Is this a gas hob and gas oven, or is the oven electric?
If it is gas, does it have a pilot light? (and is the pilot light on?)
If gas, does the oven light for a moment and then go out or does it not even light?
Jul 10, 2011 | Frigidaire Ovens
BURNER IGNITION WILL NOT TURN OFF. When turning stove top on, all 4 burner ignitions continue to stay on. They will not stop clicking. Only when I unplug the oven will they turn off. It is a Frigidaire...
One of the switches is stuck,causing circuit to 'think' that you're trying to light a burner. Give each control knob a good 'tap' with the back of a screw driver.If that doesn't free it up, we will have to find the stuck
switch
Jul 25, 2009 | Frigidaire FGB24S5A Gas Single Oven
I need six knobs for a 1950 Frigidaire model RM-45
I have the same model stove for sale. here is my number 678-644-2161 samantha
Jul 23, 2009 | Ovens
Large range burner switch possibly defective
no warranty only 12 mo. The switch is bad call dealer - servicer and order part. should be less than $50
Apr 17, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
My Oven and broiler won't heat but stovetop burners work
I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
Dec 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Oven will not light
Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too. spark-anim1.90x11.gif
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system
Nov 20, 2008 | Frigidaire Ovens
Pilot Light - Frigidaire Model FGF326ASF
Hello jaronwayne
Welcome,
That range does have sealed burners.
Are you sure it has a pilot light and not Electronic ignition?
Where I live , if we call public service they will come out for free and light it for you!
I'm checking that model and I'll get back to you!
Huuum
Oct 16, 2008 | Frigidaire FGB24S5A Gas Single Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
