Question about Samsung Refrigerators
Dead Fridge I have a SR-L709EVSS which is flashing F5 on the display. It's not running at all. What is the problem?
Samsung SR-L709EVSS Refrigerator/freezer runs and cooles. Then stops and defrost everything and starts again. Repeats all over again. Did change control card and lcd but still same problem
If you wish to get some details about refrigerator common fault and troubleshooting ; visit the site linked here. Pull up older posts. search with the word "Refrigerator"...
http://electro-medical.blogspot.com/
Jan 20, 2017 | Samsung Refrigerators
I have a samsung SR L709EVSS. It just went dead now power, no lights and no motor running
You can't afford to wait for an answer to fix this problem on this site, we are all volunteers here and answers are sporadic, call a technician ASAP
Oct 31, 2016 | Samsung Refrigerators
What's your question?i have an e5 error code on my sr-l709evss samsung fridge
Try holding the Energy Saver and the Lighting buttons together for 10 seconds. This should reset the controls
APPLIANCE 911
Nov 29, 2015 | Samsung Refrigerators
My Samsung CoolTech Model SR-L709EVSS fridge and freezer works for a few days and then goes off by its self and then works again. What could the problem be?
Only time these units completely shut down is when the defrost timer shuts down all power to the compressor and condenser/evaporator motors. Only the bulb works.
If that timer gets stuck somehow that would explain the complete shutdown and mysterious restart later .
Jul 31, 2015 | Samsung Refrigerators
Error code f5
There is no error code F5. Could you mean 05? That is a flash error
Feb 12, 2013 | Canon Cameras
Samsung sr-l3426bs fridge not getting cold
you would need your fridge defrost sensor replace, check for ice build up within the vents of fridge section,
best to a tec to come and replace it for you,you would need the sensor to be reset on your fridge computer board
cheers
Nov 04, 2012 | Frigidaire FRS26R4A Side by Side...
Flashing freezer temp on Samsung SR S22
how to remove cover from twin cooler samsung sr-s20-s22
Mar 25, 2009 | Freezers
SRL551DP, fridge stops, display on door flashing.
You most likely have a problem in the freezing/cooling circuit. Check your condenser, evaporator fans to see if they are running okay. Most likely it may be the condenser fan.
Dec 17, 2007 | Samsung CoolTech Plus / Basic Bottom Mount...
Refrigerators Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
