Question about Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television
MITSUBISHI BIG SCREEN MODEL #VS55707
IT WILL COME ON, BUT AFTER 2 TO 3 MINUTES HORIZONTAL LINES APPEAR AND THEN SHUTS OFF THE LONGER I LEAVE IT OFF I GAIN A FEW MORE MINUTES,,,,,,,,,,,,THANX FOR ANY HELP I CAN GET ON THIS.
  • 1 more comment
  • ADRIANO Aug 30, 2007
    thank you very much, that took care of the problem..........
  • kiddjus Nov 23, 2007
    Horizontal lines appear on the screen, they usually go away once the TV has been on for a bit. When they are bad, you cannot watch the TV. Mitsubishi VS55707
  • robin974 Dec 09, 2008
    Have problem with horizontal line also. They eventually go away after about an hour then only apear occasionally.
    Genius:
  • 1,153 Answers
1. CHECK C2P08 100 UFD 16 V OFF PIN 3 OF IC2P03 (3.2 VOLT REGULATOR) ON THE SIGNAL PCB. IS the set shutting off or the hor. lines?
Posted on Aug 27, 2007
Big screen mitsubishi vs55707,IT WILL COME ON, BUT AFTER 2 TO 3 MINUTES HORIZONTAL LINES APPEAR AND THEN SHUTS OFF THE LONGER I LEAVE IT OFF I GAIN A FEW MORE MINUTES,,,,,,,,,,,,THANKS FOR ANY HELP I CAN GET ON THIS. ALSO TURN ON WILL SHUT OFF SOME TIME.
Posted on Jan 18, 2009
73' Mitsubishi has magenta splotches moving around screen and eventually getting larger until whole screen is covered.
bad main digital board. It's the bottom board on the left, try Encompas Parts to get digital board.
Nov 27, 2011 | Televison & Video
VS-50111 and horizontal lines appear and shuts off
hello i have the service manual which i'll send for free along as you leave me a fair rating thanks
regards
shaun
May 31, 2010 | Mitsubishi VS-50111 50" Rear Projection...
Mitsubishi big screen won't stay on!
Its very possible you have a failing resistor r2200
Nov 22, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Constant horizontal lines
Good Day, valscot;
The most common problem with model i some caps on the signal board, CHECK C2P08 100 UFD 16 V OFF PIN 3 OF IC2P03 (3.2 VOLT REGULATOR) ON THE SIGNAL PCB.
good Luck big IRISH.
Aug 14, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi #VS-45605
We had a blue cone on the screen. We have adjusted the sharpness, contrast, and cross hairs. The cone has almost completely disappeared, but we still have blue shadows. Could this mean a blown color tube?
Any suggestions would be greatly appreciated.
Aug 13, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi VS-45607 45" Big Screen
Good Day, Delano1981;
It may cure the problem but I would suspect the 9 Volt source
CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND
IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH
ARE ON THE SIGNAL PCB.
This should resolve your TV"s condition.
Good Luck, big IRISH.
May 27, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Problem with my big screen
CHECK OR REPLACE C2P08 100 UFD 16 V OFF PIN 3 OF IC2P03 (3.2 VOLT REGULATOR) ON THE SIGNAL PCB.
Sep 15, 2007 | Mitsubishi WD-62327 62" Rear Projection...
No Blue. Horizontal Lines.
Not to me, but it also depends on if you could do this yourself or not. And the area you are in sometimes is responsible for the cost being high.
Sep 02, 2007 | Mitsubishi VS-50705 50" Rear Projection...
Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television Logo
415 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
