Question about Roketa Computers & Internet
Good dayI have a go kart buggy which is chain driven to each back wheel. So I have short drive shaft (+- 300mm). It connects to a sprocket then it passes through the frame and you have the brake disc
Good day I have a go kart buggy which is chain driven to each back wheel. So I have short drive shaft (+- 300mm). It connects to a sprocket then it passes through the frame and you have the brake disc and then the wheel hub fitting. I need a replacement drive shaft. Do you have the part which I need or do you know where I can get this from. On the side of the engine is "Wangye" so I suppose that the make of this Chinese buggy I have. Its a 250cc motor with a CVT box. I have attached pic of it. Regards Haroon Dharsey 082 732 6229
  • 2039 Answers
SOURCE: why does my new bike's back wheel not spin easily?
if brake and aligmen t of wheel is good the bearing ajustment is too tight remove the wheel loosen the nut on each side not too loose just so it turn freely with no play in the wheel let me now pierre
Posted on Dec 15, 2008
  • 101 Answers
SOURCE: starter motor not working on honda cbx 750 f shaft drive
Hi .......... It's only held in place by two set screws, you don't need to strip engine.
Posted on Dec 30, 2008
  • 55 Answers
SOURCE: I have a 1997 Dodge Ram 1500 4 wheel drive. I
i have found that you need to first make sure the cv shaft is moving free in the bearing. soak everything with penitrating oil. you should be able to move shaft in & out a little. the hub is a very tight fit. you need to tap it some from side to side untill you see a little gap between hub and spindel. then place the head of a flat screw driver in that gap and all around the hub, prying back and forth where ever possible. soak, tap and pry all over. be hard on it if replacing, more gentle if not. good luck.
Posted on Jul 18, 2009
  • 138 Answers
SOURCE: Cub Cadet 129- The drive shaft from the engine to
This mis alignment of 1/4" is about normal that is how and why cub put the rubber flex coupling on the hydro... however if there is play in the hyro input shaft then we need to determine what the cause of this is. Good luck
Posted on Sep 07, 2009
Testimonial: "Thank you. Very prompt."
  • 599 Answers
SOURCE: 2005 Chevrolet Silverado 1500HD 4 wheel drive
177 ft lbs
Posted on Dec 09, 2009
I need to know the size of the center hole on a 19 tooth transmission sprocket for an apc mini chopper Thanks
Why do you need to know the size of the centre hole. That one look in great condition. The size is the size of the shaft it fits on, so you measure the narrower distance, which is between the sprocket tooth that is under the middle of your thumb nail, to the second tooth past your index finger. All this links have info.
  • mini chopper sprockets ' eBay www.ebay.com > Search > mini chopper sprockets Refine your search for mini chopper sprockets. ... Mini Chopper Pocket Bike Parts 19 Tooth Front ... 28 Teeth Rear Driven Sprocket L for #410 Chain APC Mini Chopper ...
  • mini chopper sprocket in Parts & Accessories ' eBay www.ebay.com > Search > mini chopper sprocket Find mini chopper sprocket from a vast selection of ... Mini Chopper Pocket Bike Parts 19 Tooth Front Chain Sprocket ... APC MINI CHOPPER 48" THROTTLE CABLE ...
  • I need to know the size of the center hole on a 19 tooth ... www.fixya.com > Forum > Motorcycles > APC ... a 19 tooth transmission sprocket for an apc mini ... on a 19 tooth transmission sprocket for an apc ... rear 28 tooth sprocket for an apc mini chopper.I ...
  • Mini Chopper Sprocket and Clutch - DIY Go Karts www.diygokarts.com/chopper-plans/drive-assembly.html ... a torque converter can be used which effectively gives the project an automatic transmission. ... mini-chopper's clutch ... tooth #35 pitch. This size sprocket ...
  • mini chopper parts ' eBay www.ebay.ca > Search > mini chopper parts mini chopper parts 352 listings. ... 28 Teeth Rear Driven Sprocket L for #410 Chain APC Mini Chopper ... #428 Chain 17 Tooth 14mm Pitch Sprocket Part Gear Go Kart ...
  • Sprockets - PartsForScooters www.partsforscooters.com/Pocket-Bikes-Parts/Pocket-Bikes-Sprocket Mini-Chopper Parts; ... 127-19 . Stock 6 Tooth Front Sprocket with M10x1.00 thread size for 47 and 49cc 2-stroke cag style pocket bikes and mini-quads.
  • Mini Chopper Parts ' Mini Bike Parts ' We Ship https://www.gokartsupply.com/chopper.htm Home >> Parts Catalog> Mini-Chopper Parts. Parts For Mini Choppers Seats - Hand Controls - Fenders. ... SPROCKET 60T #35. 7-1/4" 28.50. 04-470. SPROCKET 72T ...
  • Electra / APC Mini Chopper w 49cc PS engine - Pocket Bike ... www.pocketbikeplanet.com/showthread.php?t=84442
    • 20 POSTS
    • FIRST POST: 2014-06-29
    2014-07-26 · Electra / APC Mini Chopper w 49cc PS engine Mini Choppers. ... Sounds like you got a transmission with slag on the internal gears ... do a search as mini chopper parts.
  • mini chopper bike ' eBay www.ebay.ca > Search > mini chopper bike Find great deals on eBay for mini chopper bike and ... 43CC 49CC APC MINI CHOPPER MINI BIKE MONKEY ... 17 tooth sprocket gear Pocket Bike Mini Chopper ...
  • Rawge's Mini Chopper Information Site - Gearing and Sprockets www.rawge.bravepages.com/minichoppers/speedo.htm Rawge's Mini Choppers ... The Simple Mini Chopper Drive ... you can expect from your mini chopper, given the size of the sprocket on your ...
  • Pagination
  • Apr 08, 2016 | APC Motorcycles
    Engine runs but wheels do not move
    This could be a few things:
    1) Your clutch plates may have worn out so that even when the bike is in gear, it will just rev, but no power will be transmitted to the drive shaft (smaller front chain sprocket is the driving gear, larger rear sprocket on the back wheel is the driven gear)
    2) The front chain drive sprocket has come off under the cover on the motor - if the chain is really slack, have a look.
    3) The front chain drive sprocket SHAFT has sheared. (basically, meaning that the shaft has broken into two parts as it couldn't handle the drive power (torque) being delivered through it to the chain drive) With the motor on, listen for grinding noises internally
    when you rev, from the vicinity of the front chain drive cover. If its rough and grindy, the shaft may be sheared. Then with the motor off, take the cover off and leverage the small chain drive sprocket away from the motor with a screwdriver, and see if the shaft can just be pulled out of its sealed opening. Unfortunately with these bikes, the metals used in drive shafts and motors are not always heat-treated or hardened to the standard they should be, so shearing and premature failure can happen.
    4) The gearbox or something in it has blown, unfortunately for the same reason above, quality related.
    Its fair to say that these great little bikes are here for a good time, but not for a long time.
    Apr 11, 2014 | Razor MX350 DIRT ROCKET - BLUE
    Husqvarna Rider 155 No steering Rear end of cable looks okay
    The steering is fairly basic, a steering wheel that turns a steering shaft, on the end of the shaft is a sprocket, around the sprocket runs a short chain, on either end of the chain is a steel cable, both cables run to a quadrate at the underside of the engine, the r/h cable then goes the the l/h fixing and the l/h to the right, so either the locking screw on the steering wheel shaft has come loose and not turning the lower shaft, or the sprocket has sheered from the lower shaft, or the cables are not adjusted correctly, remove the cover on top of the chassis between you feet, you will then see the lower shaft, sprocket and chain, you should see the problem when the steering is turned.
    Dec 22, 2012 | Garden
    Chain noise
    Excessive drive chain noise is caused by the following, lack of proper maintenance, keep it clean and lubed, next would be correct adjustment, most bikes about 3/4" deflection at center run of chain up and down play, next would be a worn out chain and/or drive or driven sprockets, last but not least and very noisy is the chain being stretched, if you rotate the wheel the chain gets loose then tight. Always check the sprockets for excess wear when replacing a chain, the drive sprocket on the engine is hardened steel and wears the least.
    Feb 09, 2012 | Bajaj Pulsar 180 Motorcycles
    I broke a chain on a model No 917.293319 craftmans rear tiller, when i opened up the trabmission the chain on the for the drive tires was on the large sprocket and the only place to connect to other...
    indicates that the shear pin on the driven sprocket failed and the sprocket moved sideways breaking the chain
    sprockets have to in line for operation
    Dec 13, 2017 | Craftsman Rear Mount Tiller
    I need timing marks on 2.2 toyota camry 2000
    1. Remove the fan and generator V belt:
    tdisline_543.jpg 2. TIMING CHAIN (2az-FE Engine):
    Before servicing the vehicle, refer to the Precautions Section.
    Drain the engine oil.
    Remove or disconnect the following:
    Negative battery cable
    Hood Right-side front wheel Engine under covers Right-side fender apron seal Front exhaust pipe Engine moving control rod and bracket Right-side engine mounting stay and bracket Accessory drive belt Engine appearance cover Engine wire Alternator Power steering pump, leave the hoses connected Ignition coils Ventilation hoses Cylinder head cover Turn the crankshaft pulley to set the No. 1 cylinder to TDC compression. Align the groove on the pulley with the timing mark -0- on the front cover. Remove the crankshaft pulley as follows:
    1. TMC made: Use Special Tool 09213-54015 to hold the pulley to loosen the bolt. Use Special Tool 09950-50013 to remove the bolt and pulley.
    2. TMMK made: Use Special Tool 09960-10010 to hold the pulley to remove the bolt. Use Special Tool 09950-40011 to remove the crankshaft pulley
    tdisline_544.jpg Fig. Removing the crankshaft pulley-TMC-2.4L (2AZ-FE) engine
    Fig. Removing the crankshaft pulley-TMMK-2.4L (2AZ-FE) engine
    Crankshaft position sensor Lower oil pan No. 1 chain tensioner Accessory drive belt tensioner
  • Support the engine with a suitable engine lifting device.
  • Remove or disconnect the following:
    Engine mounting insulators Right-side engine mounting bracket Stud bolt for the accessory drive belt tensioner from the block Front cover mounting bolts and nuts Front cover Crankshaft position sensor plate Timing chain tensioner slipper Timing chain vibration damper Timing chain Crankshaft timing sprocket
  • Turn the crankshaft counterclockwise by 90°, and align an adjusting hole of the oil pump driven sprocket with the groove of the oil pump.
  • Fig. Align the adjusting hole of the oil pump drive sprocket with the oil pump groove-2.4L (2AZ-FE) engine
    Fig. Insert a bar to lock the sprocket in position-2.4L (2AZ-FE) engine
    Put a bar in the adjusting hole of the oil pump driven sprocket to temporarily lock the sprocket in position. Remove the nut.
    Remove the bolt, chain tensioner and spring.
    Remove the chain tensioner, oil pump sprocket and No. 2 timing chain.
    To install:
    Set the crankshaft key into the left horizontal position. Turn the cutout of the drive shaft to the top
  • Fig. Align the crankshaft key and drive shaft cutout as shown for installation-2.4L (2AZ-FE) engine
    Align the yellow colored links with the timing marks of the sprocket as shown in the illustration.
  • Insert the sprockets with chain to the crankshaft and oil pump shaft.
  • Temporarily tighten the oil pump driven sprocket with the nut.
  • Insert the damper spring into the adjusting hole, and install the chain tensioner plate with the nut. Tighten to 9 ft. lbs. (12 Nm).
  • Align the adjusting hole of the oil pump driven sprocket with the groove of the oil pump.
  • Put a bar in the adjusting hole of the oil pump driven sprocket to temporarily lock the sprocket in position. Tighten the nut to 22 ft. lbs. (30 Nm).
  • Rotate the crankshaft counterclockwise by 90°, and align the crankshaft key to the top.
  • Install the timing chain vibration damper. Tighten to 80 inch lbs. (9 Nm).
  • Align the timing marks of the camshaft timing sprockets and bearing caps.
  • Using the crankshaft pulley bolt, turn the crankshaft and set the set key on the crankshaft upward.
  • Align the gold or orange colored link with the timing mark of the crankshaft timing sprocket.
  • Using Special Tool 09309-37010, tap in the sprocket.
  • Align the gold or yellow colored links with the timing marks of the camshaft timing gear and camshaft timing sprocket. Install the chain.
  • tdisline_553.jpg Fig. Align the marks of the sprockets and bearing caps to set the No. 1 cylinder at TDC-2.4L (2AZ-FE) engine
    tdisline_554.jpg Fig. Set the crankshaft set key facing upward-2.4L (2AZ-FE) engine
    tdisline_555.jpg Fig. Align the marked link of the timing chain with crankshaft sprocket timing mark-2.4L (2AZ-FE) engine
    tdisline_556.jpg Fig. Tap the crankshaft sprocket in with Special Tool 09309-37010-2.4L (2AZ-FE) engine
    tdisline_557.jpg Fig. Align the marked links of the timing chain with the camshaft sprockets during installation-2.4L (2AZ-FE) engine
    May 21, 2011 | Toyota Camry Cars & Trucks
    The chain keeps coming off.why?
    Chains must not have too much slack in them. There should be about 1/2" (12mm) of vertical movement on the slack side.
    It could be your have a worn out chain.. Look at the drive pinion. The teeth should have a flat top and both faces of the teeth should have the same profile. If the sprocket is very worn, the teeth become pointed and the chain does not sit correctly on the drive chain wheel on the rear wheel, (i.e. there is a gap between the chain and the inside edge of the driven sprocket.
    If you change your sprockets, change the chain also (you must do this as the chain will also be very worn).
    Mar 21, 2010 | 2002 Suzuki GZ 125 Marauder
    Honda vibrations
    This one's a little tricky cause it could be a few things.
    I'll try suggestions in the order of probability
    • Worn out chain & sprockets.(Or chain too tight or has a tight spot) Check this by raising the rear wheel off the ground,in neutral & spin the back wheel. If the chain & or sprockets are worn you'll feel it & hear it when you spin the wheel. If it has a tight spot,set the chain tension at the tight spot & lubricate well
    • Loose engine mounting bolts. If loose re- tighten.
    • Worn front sprocket shaft bearing. to check this(if chain seems ok) Remove the chain(note joining link direction of the circlip. The closed end faces the direction of rotation)Bike in neutral, turn the sprocket shaft by hand. It should turn smoothly.If it is notchy thats not good. It is a major job to change & can be expensive(So i hope its the chain &/or sprockets)
    • Broken tooth on a gear in the gearbox. I hope not as again a more difficult & expensive repair.
    Hope this helps you narrow down your problem
    Regards Andrew Porrelli
    Dec 03, 2009 | 2001 Honda Cityfly
    Yamaha timberwolf starts but when you put it in gear wont move sounds like chain is off but think its shaft driven what wrong with it
    DT 360 is not shaft driven . Its chain driven .
    Now if its making noises and not going anywhere , the chain may have jump the front sprocket and just knocks on the side cover making strange noises .
    check it out and let me know how you go .
    Sep 27, 2009 | 1974 Yamaha DT 360
    Computers & Internet Logo
    37 people viewed this question
    Top Roketa Computers & Internet Experts
    David Payne
    David Payne
    Are you a Roketa Computer and Internet Expert? Answer questions, earn points and help others
