Philips 60PP9202/17F motherboard
Where can i get a motherboard for this tv?
Philips lcd tv;s motherboard solution
What is the problem with this set? Provide more details please. Visit the site named 'Electro-help' for more details. Click this link. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. Some times, the ads attached with each posts, both at the right and bottom, might help you to find the availability of spare parts. There are more than 870 posts to different brand TVs now.
Sep 27, 2012 | Philips 32PFL3505D 32 in LCD TV
How to install saa7134
Open your CPU casing then install your pci capture card to one of your motherboard PCI slot you can Find it just read the slots of your motherboard they have a label on it some times PCI slot of a motherboard support multiple PCI slots just connect it on one of that slot..After installing install the installation software CD which is included in the package.
Jul 07, 2011 | Philips SAA7130 TV Tuner/FM Radio/Video...
...WANT DRIVER AND SOFTWARE FOR
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
http://download.driverguide.com/driver/SAA7130HL/Philips+Consumer+Electronics/d589691.html
http://members.driverguide.com/driver/detail.php?driverid=589691&action=winfo
hope this helps
May 30, 2011 | Philips SAA7130 TV Tuner/FM Radio/Video...
I have a Phillips FLATTV model ... Problem with the Philips Flat Panel Televisions I have a Phillips FLATTV model 42PFL7662D/ 05 I have no picture, the audio is OK, I have had a hissing noise for about 2...
Try with that...
http://www.filestube.com/3c4e959f7e53ba6703e9,g/PHILIPS-42PFL7932-LC420WU5-V2-CIRC.html
Symptom:
Sound but no picture.
Cure:
Master or Slave inverter is defective.
It can be that the driver IC is defective or MOSF
inverter transformers, or 470uF 35V C
Replace driver IC BD9897FS or MOSFET's.
996500046243 IC BD9897FS
996500046242 Mosfet FDD8447L
996500046241 Zener KDZ100V
Oct 18, 2010 | Philips Televison & Video
I'm looking for a philips tv 32 PFL5332D/37 main board unit motherboard. Where can I purchase one?
If you don't find the part from a third party vendor by googling the model number, you'll have to call the manufacture, Philips, to obtain that part.
Jul 18, 2009 | Philips Magnavox 51MP392H Rear Projection...
Need code for phillips big screen lost manual for jumbo remote
Code 002 for Philips TV Code 003 for Philips TV Code 004 for Philips TV Code 008 for Philips TV Code 012 for Philips TV Code 019 for Philips TV Code 062 for Philips TV Code 068 for Philips TV Code 069 for Philips TV Code 075 for Philips TV Code 076 for Philips TV Code 086 for Philips TV Code 087 for Philips TV Code 088 for Philips TV Code 130 for Philips TV Code 132 for Philips TV Code 134 for Philips TV Code 167 for Philips TV Code 183 for Philips TV Code 196 for Philips TV
Jul 12, 2009 | RCA RCU600M Remote Control
Fail to initialize hardware_tv tuner card problem
check on line, they may have a updated version of the driver.
Jun 15, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
Tv turns on and off need motherboard
why not buy the circuit and solder it back in? a tv shop would have them and may carry them as part of their stock.all you need to do it unsolder the old part take it to thema dn show it to them they will know what you need then
Jan 08, 2009 | Philips 9P5034C 50" Rear Projection...
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
