Question about Sony Xperia Z
Settings i go to settings and go to my xperia then i press the talk settings for low vision and i cant go back to normal operation
    Top Expert:
  • Sony Master
  • 12,223 Answers
See this steps and settings.
  1. From the main home screen, tap menu
  2. Tap Settings, then SD card & phone storage
  3. Tap Factory data reset
  4. Tap Reset phone
  5. Enter your password, then tap Erase everything to confirm
Posted on Jul 11, 2013
If any cameras on night vision the pic soo fuzzy u cant see, NV off it goes back to visible?
At night can you see the red led's ? If not they are not working. Make sure in camera settins if there is a option to enable night vision. If you mean at night it is fuzzy cloudy then it could be led's are bouncing light back creating a hazy whitish image. Or lens is dirty on the inside which it happens. Last is low end low quality cameras
Aug 28, 2015 | Vision Home Security
Tip
Solution to the HP Purple Web Cam Issue
This document is located on HP's web site concerning purple tint on certain web-cams.
This document pertains to certain HP Notebook PCs with Windows 7.
When using an HP ENVY 15 notebook PC webcam in low light conditions, images on the webcam may have a purple tint.The ENVY 15 Series webcams include night vision technology that is designed to operate in normal lighting conditions and optimized to operate in low and zero light conditions.The webcam night vision feature includes two Infrared (IR) lights located on each side of the webcam and behind the display panel bezel.
Low to zero light conditions will cause the webcam IR lights to activate. The IR lights provide illumination for low and zero light conditions and help prevent fuzzy images that are typically associated with operating standard webcams in low and zero light conditions.
Turn off the webcam IR lights. While some degree of purple tint may be present under low light conditions, turning off the webcam IR lights will reduce and in certain cases eliminate the purple tint.
  1. Select Start > All Programs > HP > HP MediaSmart > HP MediaSmart Webcam .
  2. In HP MediaSmart Webcam, select Settings > Display > Advanced Settings , and then click the Camera Control tab.
  3. Select the Low Light Compensation check box, and then click Apply .
  4. Click OK .
NOTE:Disabling the webcam IR lights will cause display images to appear darker in low and zero light conditions.
The webcam IR lights are also available on other webcam programs.
Refer to the software Help for additional information.
This document will be updated if additional information becomes available.
on Jul 28, 2010 | Computers & Internet
Pin code cant open
There's no way to fix this, hence having a pin in the first place.
You need to use the PC companion suite to wipe the phone and install the system from scratch.
You can still access the memory card by removing it and using an sd card adapter allowing you to take off any data you need. (hopefully you do regular backups and the relevant file/s will be on your memory car, ie tel/numbers and contacts/emails etc, so when you restore your phone you can import everything back onto the clean system).
http://talk.sonymobile.com/t5/Xperia-pro-Xperia-neo-V-Xperia/Hard-Reset-Forget-Screen-PIN-CODE/td-p/242824
Nov 06, 2013 | Sony Xperia miro ST23i Smartphone -...
Need to reset sony ericsson xperia 10x cell phone
1ST IS : 1-Turn off your Sony Ericsson Xperia
2-Remove the battry and replace it back in
3-Press anda hold down the left and right silver buttons just under the screen
4-With the stylus,press in the hole on the right side of tehe battery
5-After 10 seconds,you will be prompted to press the R key on your silide-ou keyboard
6-If successful press the Space Key on your slide-out keyboard to finalise changes 2nd IS :
1 From the Xperia 10 Home screen, tap the applications bar.
2 Tap Settings > SD card & phone storage > Factory data reset > Reset phone.
3 Enter your screen unlock pattern.
4 Tap Erase everything.
Done! Now, You can reset your Xperia X10 to its factory default settings.
This is a soft rest its never hardrest, pls we someone to give haedrest solution,-even when there is password, which can be removed easiy
Aug 08, 2011 | Sony Ericsson XPERIA X10 Cell Phone
Need to set the time on Avalon EZC Talking Watch
Here is a link to the instructions on how to set the time on your talking watch. It says that it is a one button operation and easy to do. Good luck! http://www.assistech.com/tw-avalon1-usermanual.pdf
Jun 09, 2011 | Avalon Ezc Voice Series Low Vision Talking...
Hello. I tried to reset my new Sony Ericsson Xperia X10 in line with he user guide. I went from Settings to SD Card & Phone storage settings, but from there I cant find the 'Factory data Reset' option...
Mar 25, 2011 | Sony Ericsson XPERIA X10 Cell Phone
Cant send&receive mms on xperia x10 mini
sir you need mms settings for sending and receiving messages. so kindly contact customer care executive and get settings for it. save it as default. then it will be normal sir, this will solve your problem sir. thank you
Jan 09, 2011 | Sony Ericsson XPERIA X10 Cell Phone
What is low vision?
Low vision is a term describing a level of vision below normal (20/70 or worse) that cannot be corrected with conventional glasses. Low vision is not the same as blindness. People with low vision can use their sight. However, low vision may interfere with the performance of daily activities, such as reading or driving.
Nov 23, 2010 | Health & Beauty
I need to set the talking part of a gts avalon ezc voice 3 button 1push 1 pull out to set anol 1 flush with case to push
Enter "www.pocketwatchsite.com/opencase_singer.txt" in your search engine and you should arrive at a site headed "opening pocket watch cases" .
This would seem to be what you need!
Feb 25, 2010 | Avalon Ezc Voice Series Low Vision Talking...
Sony Xperia Z Logo
44 people viewed this question
Top Sony Cell Phones Experts
richie46
m_suresh
Level 1 Expert
Are you a Sony Cell Phone Expert? Answer questions, earn points and help others
