Question about Samsung SHR-5162-250 16-CHANNEL DIGITAL VIDEO RECORDER
Default password reset to default
WRT310N
Hello I found the following info about the default settings on your router (you can reset your settings to the default ones by pressing the reset button on your router or the back of your router device):
Link is: http://pcsupport.about.com/od/linksys-default-passwords/a/wrt310n-default-password.htm
WRT310N Default Password & Other Default Login Data Version Default Username Default Password Default IP Privileges All [none] admin 192.168.1.1 Administrator
Jan 28, 2012 | Linksys WRT Computers & Internet
Forgot my password and cannot reset?
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your
router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Sep 06, 2011 | Computers & Internet
Need password to my netgear router n 300
what is the model #?
Most netgear routers default to a username of "admin" and password is either " admin ", "password" or it is just blank. Those are the defaults unless someone changed it.
If you cant get in you can hold down the reset button on the back for 30 seconds (while it is plugged into power) and that will set it back to factory default settings then one of the above should work.
If this was a help please give me 4 thumbs up as I am trying to build up my rep on this site!
Mar 02, 2011 | Computers & Internet
I lost my password to my netgear, to hook up my second computer?
You don't need a password to hook up a second computer - just plug it in. You only need the password if you want to change the configuration of the router.If that's the case, the default user ID for this model is 'Admin' and the default password is 'password'. If you have a non-default password you will have to reset the router to factory defaults and then login with the default ID/password.
To reset to factory defaults, press and hold the Reset button until the Test LED turns on (about 10 seconds). Release the Default Reset button and wait for the router to reboot
Feb 19, 2011 | NetGear WGT624 Wireless Router
What is the default password for lemon mobile?
lemon duo it717
reset factory settings
Apr 06, 2010 | Cell Phones
How do you reset a password?
Easy, reset the router itself, should have a tiny pin hole in the back that has a button that you must compress, just google reseting your model.
If you have any problems let me know.
Apr 03, 2010 | NetGear DG834G Router
How do I reset a Xerox Phaser 4500 Centreware password to factory default.. or what is the factory default password? I have on which has been changed and nobody seems to know the PW anylonger
this should restore it to default.
By default there is no username or password required to access CentreWare Internet Services. If a username and password have been configured for CentreWare Internet Services and you do not remember the username and / or password, reset the printer to factory defaults (NVRAM reset).
To reset the NVRAM, go to the front panel's Main Menu:
  1. Select Troubleshooting, then press the OK button.
  2. Select Service Tools, then press the OK button.
  3. Select Reset NVRAM, press the OK button.
  4. Select Reset NVRAM and Reset Printer NOW, then press the OK button to reset all the settings to their factory default values.
Mar 03, 2010 | Xerox Phaser 4500 Printer
Default password is incorrect or reset doesn't work
The default ip is 192.168.1.1
default user-name and password for the 5 models of 3com are as follows.:
1.
3com default ip: 192.168.1.1
username: n/a
password: admin
or
2.
user-name: adminttd
password: adminttd
or
3com default ip 192.168.1.1
user-name: admin
password: n/a
or
user-name: n/a
password: PASSWORD
OR
5
user-name: root
password: !root
ok try
this
Note that at time you will need to set your local ip of your pc from which you are acess the device to the same range...
That is for example 192.168.1.10
Good luck
uttam
Feb 26, 2010 | 3Com 2816-SFP Plus (3c16485-us) 16x1000...
My motorola router is unidentifying my username and password. How do I reset my Username and Password ?
For the motorola router's default username is "admin"; The router's default default password is "motorola".
If it is a Motorola-Cablerouter then default username is " cablecom"; The default password is "router".
Reset the router to Factory Defaults if the password is not working and re-configure it .
Nov 23, 2009 | Computers & Internet
Forgot my password
Most of the NETGEAR devices have the following default username and password except ReadyNAS products and Fully Managed switches:
  • Username is always admin
  • Password is password or (for older devices) 1234
If you have changed the default password and have forgotten the password, you may need to reset the NETGEAR device to factory default settings.
Write down configuration information such as IP addresses, security keys, opened ports and services, etc., that you modified. (The default username is admin and the password is either password or 1234. Try these before resetting the router.)
  1. Press the reset button on the back until the test light blinks. This takes about 10 seconds. (To avoid accidental resets, the small button is recessed. Use a pen or paperclip to access it.)
  2. Release the button.
  3. Wait for the router to reboot.
  4. Log in with the default password. If the router configuration was not cleared, try these additional steps AFTER the router has finished rebooting.
  5. Unplug the router's power.
  6. Press and hold the reset button. While the button is held down, reconnect router's power.
  7. Continue to hold the reset button for 20 seconds after reconnecting the power.
  8. Wait for the router to reboot.
  9. Log in with the default password.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 26, 2009 | NetGear RangeMax WPN824 Router
Samsung SHR-5162-250 16-CHANNEL DIGITAL VIDEO RECORDER Logo
16 people viewed this question
Jerry Greenberg
Jerry Greenberg
