Question about Nokia 6300 Cellular Phone
Not charging charger
Charger not support
    Top Expert:
  • 12,223 Answers
How to charge it
Hi Stacey
How to charge "what model" Cell Phone
iPhone & others usually charge from the USB cable that it comes with.
Plug into any USB port (5v DC)
Some chargers supply more current which can give a faster charge. iPad chargers supply 2A where as iPhone chargers are 1A
Sep 13, 2015 | Cell Phones
My tablet was in use, needed charging, it shut off. Now it won't charge or come on
It sounds like there's a problem with the charger. The wire on the charger is rather delicate. So is the port on your tablet where the wire plugs in. There may be a break inside the wire. If you dropped your tablet while the wire was plugged in and it hit the floor on the charger plug, the charger plug could have damaged the charging port in the tablet or the wire itself could be damaged.
Find someone else who has the same tablet and ask to switch chargers to see if either of them still work on the other tablet. If your friend's charger starts charging your tablet without a problem, then the problem is a a broken wire in your charger. If neither charger will charge your tablet but both chargers charge your friends tablet without a problem, then the problem is with the charging port on your tablet.
Mar 17, 2015 | Tablets & eReaders
RCA tablet wont charge
Possible charger damage.
If you know someone with a charger you could use, you should first plug their charger into your unit to see if it works, if not, plug your charger into their unit.
If your unit will not charge with new charger, you may have serious damage, if the other will not charge with your charger, your charger is broken.
Jan 13, 2014 | Tablets & eReaders
Meos dvd92b not charging
Hello:
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Dec 29, 2012 | Cell Phones
Wont charge
First Option:
Second Option:
Sep 09, 2012 | ZTE Avail Bluetooth Music 3G GPS Android...
Wont charge
First Option:
Second Option:
Sep 09, 2012 | AT&T Avail
Can i over charge my mobility scooter go go pride
Yes you can overcharge a battery, it all depends on the charger your using. Most chargers are single stage chargers. Most scooters come with a single stage charger. My scooter has a built in single stage charger What this type of charger does is output a constant 24v @ 4amps.The problem is batteries amperage requirements decrease as the battery charges. An overcharge will occur when the battery is charged. It requires very little amperage to maintain a charge on a fully charged battery. A single stage charger like mine will output 4amps regardless of the state of charge of the battery. Batteries bring charged with single stage chargers loose their electrolyte. What happens is overcharged batteries break down the electrolyte into oxygen and hydrogen. So overcharging will cause a battery to "boil-out" its electrolyte. Batteries don't work without electrolyte. In the old days there were only single stage chargers. That was the state of the art back then. So to cope with the constant overcharging batteries had refill ports where you could replenish the electrolyte using distilled water.
Scooter batteries are far and away different from the lead acid of the 1970's. Scooter batteries are sealed, they are deep cycle, they use a glass mat soaked in gelled electrolyte. These glass mat batteries optimize the electrolyte used so they can use allot less of it. These newer batteries have a lot more power in a lot smaller package but they have a draw back, they must be charged properly. You can absolutely can not charge these batteries with a single stage charger. Actually you can charge with this device but you will loosed electrolyte each time you charge.
I use a three stage charger 24v @ 5amp. This charger s different from a single stage. Its what they term a "smart charger" it monitors the state of charge of the battery. As the battery charges it turns down the amperage. When the battery is fully charged the amperage is turned low enough were the charge is maintained. The entire charging process is designed to preserve electrolyte. In short this type charger will not overcharge the battery.
Click here to see the charger i currently use.
http://www.amazon.com/Sealed-Battery-Charger-3-Stage-Fan-Cooled/dp/B0051WHAU0
Jul 30, 2012 | Health & Beauty
I am using sony ericsson z550i it is not getting charge can u plzzz give me a solution
Dear,
first of all try cleaning the pins of your charger and mobile charging socket with petrol or kerosine oil.
then see if it works,
if still the problem persist, then their may be the fault in your charger or mobile charging socket. Or electric socket where you put your charger for charging!
try charging your mobile by putting your charger in different switch board, if still it wont work, then try charging your mobile with different charger, if your mobile is getting charge, then get sure that problem is in your charger,
its time to buy a new charger.
original charges cost=900
duplicate charges cost=100
regards!
Aug 17, 2011 | Sony Ericsson Z550i Cellular Phone
Nokia 3110c Charger not supported
First Option:
Second Option:
Dec 29, 2010 | Nokia 3110 Cellular Phone
My sony erricson K750i wont charge?
try your charger with another phone to be or try your phone with another charger to be sure the charger is good.
If the charger is good, then the next thing to check is your phone's charging port. Some times, the charging port for K750i is usually dirty, have dust, or may be rust and won't contact the charger well because of this, thereby, not making the phone charge.
Get a metal and use it to scratch all the areas of the charging port, then fix in your charger to see if it will charge.
If it still does not charge, then it means, you have to get another charging port.
You also have an option of using a desktop charger to charge your phone.
Good luck.
Apr 20, 2010 | Sony Ericsson K750
Nokia 6300 Cellular Phone Logo
43 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
