Question about Admiral Gas Dryer AGD4675YQ
Glow ignitor How do I check the amp draw
  • Admiral Master
  • 3,289 Answers
To do this safely, you'll need a "clamp-on type ammeter" or "amprobe" . They look like this:
The nice thing about "clamp on type ammeters" is that they do not require physical connection to or disconnecting of any wire(s). Instead, simply set the scale for the most current you expect to see, clamp around ONE wire and adjust the scale as needed & read the meter for the most accurate reading.
There are available in various sizes and by other manufacturers - that offer a wide range of prices. Amprobe is the name of a particular company that invented this years ago - and makes this one - and other electrical test equipment. A search for images of "Amprobe" returns these.
Posted on Jul 11, 2013
98 Jimmy has a power draw it kills the battery within 12 hrs if you pull the 50 amp fuse for the int batt draw goes away any ideas
Yes Steve I do , that fuse supply's power to the I/P fuse block inside the vehicle . It powers AUX/PWR fuse #13 -20amp , RDO/BATT fuse #19 - 15amp ,MIR/LKS fuse #7 - 5amp , CTSY/LP fuse #8 - 15 amp , CIGAR/LTR fuse #2 15 amp , PWR/LKS fuse #14 15 amp , HDLP/SW fuse #1 - 10amp .Do you know where the I/P fuse block is ? You would need to do a parasitic draw test ! This involves hooking up a amp meter in series with the negative battery post an negative battery cable . Pulling each one of these fuses till the battery draw stops ! How To Perform Parasitic Draw Test EricTheCarGuy check out Eric the car guy's video on the subject !
Sep 14, 2015 | Cars & Trucks
Air compressor
Usually, motor will draw lower amperage when tank is empty then draw most when about full. High amp draw is caused by long cord, weak capacitor, leaking check valve or blown head gasket/s. If gaskets are bad, the head of the compressor will be very hot and take much longer to fill. If the motor (is too small) is not correctly matched to the pump, the motor will draw max amps. To correct motor to small, use a smaller pulley at the motor. Using a smaller pulley will turn the pump less rpm giving the motor a break lowering amp draw. Good luck
Mar 24, 2014 | Ingersoll Rand Air Tools & Compressors
Water heater thermostat tripping
thermostat is either getting weak or the element is going bad and drawing to many amps. check the amp draw on the element to see if it is drawing more than the thermostat is rated for.
Dec 11, 2013 | Water Heaters
Xg300 parasitic draw, located the 2 fuses that have the draw on them, how do i fix it
parasitic draw should remain at 50 milli amps or less or .05 amps this needs to be checked with an amp meter with the battery terminal disconnected and the power drain going through the amp meter keep in mind the circuits your testing may take up to an hour or two to fully go to sleep there is no easy way to test these multi circuits it takes years experience to troubleshoot these
Nov 15, 2013 | Hyundai Cars & Trucks
Ice-O-Matic Electrical Problem
Have you checked the amp draw? sounds like it is pulling too many amps. machine may need a good cleaning. check compressor amp draw and condenser motor amp draw to specks. and how long is the cord the longer the cord the lower the voltage go's and amp draw go's up.
Jul 22, 2013 | Kitchen Appliances - Others
When I turn it on, the heating element glows, but there doesn't seem to be any gas flowing through. I checked the valve, and it's open. Does this oven have a pilot light that needs to be lit?
The glow you see is actually the ignitor, it has taken the place of the out-dated pilot light. It is likely that your ignitor is partially burnt out and the safety valve is not opening. A good bake ignitor draws just over 3 amps and the safety valve will not open until it reads this 3 amp draw.
If the glow you see is a dull orange, it is likely that the ignitor is bad.
Apr 15, 2011 | Microwave Ovens
Will not get cold. hear a clicking noise from back around compressor
That sound is the sound of death....... The compressor is trying to start but can't and the overload is tripping. May only need a new start capacitor or a 3 in 1 start capacitor which replaces the overload start relay and capacitor. If you have a amp meter you can check the amp draw to see if it is drawing Locked Rotor Amps. Look at the name plate on the compressor and it will give you LRA.and see if it is close to it. Then check it again after you replace the start components and see what it is drawing if it has not started and still drawing high amps then the compressor is locked up and will have to be replaced.
Feb 08, 2011 | Maytag MSD2758GEW
Air compressor starts fine,but trips the thermal reset ,motor seems hot. It does it in every receptacal I've tried.
With no air in the tank and amp meter connected to one leg of line, start compressor and note amp draw thru cycle. It should draw low amps at first then reach rated amp draw close to end of cycle(most likely 12-15 amps). If amp draw is normal then replace thermal breaker. Older compressors have thermal breaker incorporated within winding and may not be easily replaced (but not impossible). If amp draw is higher than rated, check capacitor for proper rating and make sure that the in-tank check valve is not leaking pressure back to pump. Good holidays
Dec 29, 2010 | Hitachi EC12 Portable Electric 2hp Air...
Oven does not ignite broiler does ignite burners do ignite
the ignitor should pull 2.8 amps or more. it can lite but not release gas. just beacuse it is glowing doesnt mean its good. check amp draw w/ meter if less than 2.8 amps. change it out. if doesnt glow or draw any amps. check to be sure have 120v. then change ignitor.
Aug 04, 2010 | Kenmore 47702 / 47704 / 47709 Electric...
Car seems to be charging ok but some thing
Check for consumers staying on such as interior lights , radio etc.. To check for current draw, you need an AMP meter. remove the negative battery terminal. Connect one amp meter lead to the battery negative terminal and the other to the earth cable. Hold the cable against the battery negative cable, close all doors and press bonnet switch to closed position. Activate the alarm and wait for it to arm. Once it has armed itself, separate the earth cable from the battery terminal keeping the amp meter connected. read the current draw. Should be less then 100 milli amps. Usually +- 40ma. To check which circuit has current draw remove one fuse at a time and check if current draw drops. A drop in current draw will indicate that the problem is on that fuses circuit. Also check alternator charge rate. To check this hold a volt meter across the battery terminals. with engine off, should get battery voltage. Start the vehicle, battery voltage should rise to 13 -14v and maintain this voltage with the headlights on. The battery itself could be faulty, you would need to do a load test on the battery. Load tester needed to do this.
Apr 24, 2010 | 1996 Audi A6
Admiral Gas Dryer AGD4675YQ Logo
67 people viewed this question
Top Admiral Dryers Experts
gbob59
Sal De
Are you an Admiral Dryer Expert? Answer questions, earn points and help others
