Question about RCA Televison & Video
Rca lcd tv power surge lighting
My RCA L42FHD37 was apparently hit by lightning surge which seems to have come through HDMI cable attached to DVR provided by Direct TV. The TV power supply comes through a good surge protector that apparently worked as advertised. No other equipment run through the surge protector had been affected. After the event, the TV was emitting a humming noise and there was a faint green light at the bottom of the set instead of a brighter blue or green light as is the case when the TV is operating normally. The screen was completely blank and there was no sound. Is the TV likely "fried" or could there be a relatively simple fix such as replacing the power supply board?
    Top Expert:
  • RCA Master
  • 43,980 Answers
The power supply is a likely place to find what's causing the problem
Posted on Jul 11, 2013
  • 279 Answers
SOURCE: No audio, no video
Most likely the power supply. In most models, if the lamp goes out you will still get sound. However, the power supply is not a single piece swap. I would suggest getting a voltmeter, and check the voltage where the power cord meets the power supply. Then follow the circuit pathways, checking after each component, until you find a break in power. You are getting power to that light, so some power is getting through. However, the light works on much less voltage than the rest of the television, so probably there is a capacitor or transformer that's gone out.
Posted on Sep 04, 2007
  • 1153 Answers
Can you find out what Led is not on or which comes up and goes out? Most of these sets have convergence problems. Or Power Regulators.
Posted on Sep 23, 2007
SOURCE: Power issue, clicking noise, turns off
The clicking is the power on relay closing and opening. This happens because the TV has several built in safety systems that will detect and over voltage and over current load situation.The power supply starts up for an instant, senses and overload of either or both kinds and then the safety switches trigger a cutoff. When this happens the power supply will not start up again because another circuit called a latch keeps it disabled. By unplugging the AC cord and trying to start it again releases the latch until the failure triggers it again.
On these TVs the power supply is rarely the cause of the shutdown. Something further down inside the TV has failed. Replacing just the power supply will not fix the problem. The most common reason there would be an overload would be in the high voltage circuit that lights up the 3 CRTs, next would be the coils around the CRTs that bend the beams to make the picture. This is normal circuit aging and wearing out. Unless you are very skilled with trouble shooting TVs I would recommend having a service center look at it. An authorized JVC shop would be your best choice because they will have access to the manuals and bulletins and have probably had other similar JVC units thru their shops.
Posted on May 17, 2008
yambo
  • 230 Answers
SOURCE: 61" RCA DLP won't turn on after power blip
Hi, thank you for visit fix ya.
Do you havve problems with power supply capacitors.
Replace this:
2200uf 25V, 220uf 25V ( bowed or vented). Located beside power transformer.
Thank you
Posted on Jul 26, 2009
StorminP
  • 64 Answers
SOURCE: Power Surge at Home
This time it came in on the cable, the clue was the cable box also blew. So if you had a cable surge supression device...for HDTV, I think you would have survived the second surge.
I do have the technology. It is a F-connector type and will handle HDTV signal.
Posted on Sep 17, 2009
Hello. I have a RCA flat screen tv that lightning hit it through the cable wire but the tv was plug out. Is there by any chance the tv can be repaired?
lightning provides HUGE power surge to electronic components. it is very likely that your TV is now a paperweight.
call a tv repair shop in your area and have them take a look. Usually the initial evaluation is no charge, but call and see.
Jan 10, 2015 | RCA Televison & Video
I have picture but no sound through my hdmi connection. I tried a hdmi to vga converter but have the same problem.
When using VGA, you will need to run another cable from the audio out of the other device to the red and white RCA connectors on the back of the TV labeled Audio Input (left & right).
Sep 08, 2013 | RCA L42FHD37 42 in. LCD HDTV
Can a tv working normally after been stuck by lighting
In most cases no, depends on level of surge. I've seen cases where a surge came in through an HDMI cable and take out the HDMI port on a TV, everything else worked. I've seen cases where a surge damaged multiple boards on a set. So again it depends how how big of a surge, and whether the surge comes in through the power cable or an video/audio input.
Sep 07, 2012 | Toshiba 40WL753B Regza Wl 40 Inch Full Hd...
I have a Samsung LCD TV model #LN46B301FUZA, a dish VIP622DVR a pioneer VSX-D307 reciever and a Pioneer DV-414 DVD player that I am trying to get hooked up. The Dish tech hooked up the TV and DVR using a...
I can't find your TV model to have a look at the manual. Normally you'd use a 3-plug RCA cable (Red, White, Yellow) to connect the audio and video outputs of the DVR to an RCA input on the TV. Then, hoping you have RCA OUTPUTS from the TV, you'd use a 2-plug RCA cable to take an Audio OUT from the TV into one of the receiver's Audio inputs (assuming you want to play TV sound through the receiver.
If you have no RCA inputs on the TV, you can get an RCA to HDMI Converter from Amazon for $10-$15 to convert the output of the DVD player from 3-plug RCA to HDMI, then put that into one of the HDMI inputs on the TV. Likewise, if you have only an OPTICAL audio output from the TV you can get a converter for that -- Optical audio to RCA stereo -- and put that into your receiver as an input.
Jan 20, 2018 | Pioneer Computers & Internet
Blue power light is on the tv cant turn it off
Unplug the TV wait 10 Seconds and Plug it back in. Should work fine
Sep 26, 2009 | RCA L42FHD37 42 in. LCD HDTV
Lightning Surge, RCA 32V432T, will not power up
Throw TV AWAY,these tvs had alot of problems without lighting hitting them,It probably played out FBT flyback transfomer CK hori out put Transistor if shorted replace FBT also.
Aug 06, 2009 | RCA D52W19 52" Rear Projection Television
Powers on - no output to TV
Ok, this is general hardware failure. This will need to be repaired by a Sony tech asap. the central board is malfunctioning at this time. Contact Sony asap.
Jun 20, 2009 | Sony Playstation 3 (PS3) Console
RCA LCD 42Lfhd37 Unusable signal
have you tried calling to the store you purchased it from and seeing if they will print you a new receipt. alot of stores will do this for you. also some times the store will cover the tv under manufacturers warranty and will send someone out to your house.
hope this help
please feel free to ask if you have any other questions.
Apr 06, 2009 | RCA L42FHD37 42 in. LCD HDTV
"Unusable Signal"
Ok. PCB means Printed Circuit Board.
It looks similar to the picture down below. A part must have gone bad on your PC board. So, the RCA shop ordered a replacement PC board to fix the problem. It's an interchangeable part. All newer TV now have PC boards, which each one hold a different function.ebc3c7f.jpg
Mar 13, 2009 | RCA L42FHD37 42 in. LCD HDTV
Televison & Video Logo
56 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
