Try taking out the sim card and put on the phone and enter this code *2767*3855# it will reset everything on your phone .
Fitcom ' Tech Blog
Testimonial: "thank you for the answer. the codes * and # are not available at this point.. i can only type lettres 1-9 or SOS. so this solution does not work!"
Follow this steps and fix it. God bless you
Step 1
Press and hold the power button for 10 to 20 seconds.
Step 2
Release the power button and tap the "Power Off" option under the
"Device Options" menu that appears. Tap "OK" to initiate the shutdown.
Step 3
Press the power button again to restart the device.
Testimonial: "thank your i tried to do this but the phone simply turns off and on. no device options or power off appears..! you have to understand that this is a really old model phone, but there has to be some sort of solution for this problem, like to reset the phone lock??? "
SOURCE: Forgot K700i Phone Lock Code [Please Help]
GO FOR THE flash process ,but ur data would be lost. if possible try to take backup of ur contacts and messages
SOURCE: phone lock code-samsung s3500
try this code removing your sim card . *2767*2878# . i dont know if it will work on the new models , but there is no harm in trying.
SOURCE: I forgot the Samsung Impression
SECURITY CODE:
If
you are talking about the security lock code to enter into the phone
then once it is lost nothing can be done except flashing the mobile .
Because if anybody can give the security code created then who ever who
steals your phone can get into it and get your valuable information.
So as safety precaution to avoid that they have designed it such that if
you forget the security lock you have to reset the mobile memory by
flashing the mobile at an authorized service center.So while flashing
the mobile all the data in the mobile memory will be lost and you can
again start using the mobile.
Hi
The default Security code is 12345.
If you
changed it and forgot the security code please contacts your device dealer. They
will provide you the default security code so that you can use your phone.
This
security lock prevents thieves from being able to make use of stolen handsets
that is why it can only be unlocked by authorized device dealers.
Thank You
