Question about Motorola Mobility Defy Cell Phone
Defy DAW370 Hi, I have an DEFY washing machine(DAW370)and it seems that the drain pump is constantly operating. When I start the machine on a normal wash cycle the drain starts and pumps water straight back out. Even a short while after I have paused it or hit the power button the pump continues to run.
    Top Expert:
  • 12,223 Answers
Time to replace timer/electronic control board and fix it.
You can get part from www.repairclinic.com
God bless you
Posted on Jul 11, 2013
SOURCE: how can i physically remove the mini sd card from
- Remove the battery cover.
- Turn the phone over so it is face down with the headphone jack at the top.
- With your finger nail, lift the top edge of the red flap so it hinges upwards... the bottom edge is fixed.
- You can then slide the SD card to the right and lift it out.
- Fitting is exactly the reverse.
BlackBob
Posted on Dec 01, 2010
  • 19 Answers
SOURCE: how is possible to delete
Try this:(this will clear all the data and restore its original settings )
  1. From the main home screen, tap menu
  2. Tap Settings, then Privacy
  3. Tap Factory data reset
  4. Tap Reset phone
  5. Enter your password if required, then tap Erase everything to confirm.
Posted on Feb 01, 2011
  • 79 Answers
SOURCE: manual for motorola defy screen replacement
http://www.motorola.com/staticfiles/Support/US-EN/Mobile%20Phones/DEFY_with_MOTOBLUR/US-EN/Documents/Static_files/DEFY_UG_US_68014009001A.pdf
Posted on Mar 19, 2011
casouzaj
  • 1118 Answers
SOURCE: how can i turn the
Do you mean you want to turn your carrier's data plan off? If so, go to 'Menu > Settings > Data manager > Data delivery', and uncheck theses checkboxes: 'All mobile data', 'Background data' and 'Data roaming'. Press the back button 3 times, to return to the home screen you were in, prior to start changing settings.
Hope it is what you are looking for.
Anyway, please, let me know if I can help you any further.
Regards, Carlos
casouzaj
  • 1118 Answers
SOURCE: HOW CAN I SEND SONG
Search the market for 'Bluetooth File Transfer', by Medieval Software. After it is intalled, launch it, and go to 'Menu > More > Settings > Sharing service (FTP)', and make sure the 'Enabled' checkbox is ticked. Press the back button once, and do the same thing for 'Receiving service (OPP)', Notice that you can make both services (i.e. FTP and OPP) independent from the file explorer function. On each of those pages, make sure that 'Start at boot' is checked, and 'Stop when close' is unchecked. Of course you can play with other settings too, like notifications, user interface, language, etc.
Press the back button until you get to the directory containing the file you want to send out (e.g. /sdard). Tap and hold over the file. A context menu will come up. Slide your finger up and tap over 'Send via Bluetooth'. You'll be prompted to choose the device from a list...
Hope you are able to sort your problems out soon.
Regards,
Carlos
Posted on Mar 31, 2011
Defy twinmaid 800 spinner rotate very slow
Wiring diagram for a defy Twinmaid 800 washing machiine?
howtomendit.com > Household Appliances, Washing Machines Free repair help - wiring diagram defy twinmaid 800 washing machiine. ... machine spins very very slow sometimes and sometimes it doesn't spin help please.
Jul 24, 2015 | Washing Machines
Why would my Defy 600 Automaid drum stop spinning?
The pressure sensor might be faulty. Something is telling the control that it is too full of water so the pump starts to empty it to avoid flooding. This is usually the water level or pressure switch.
See manual for your unit at this site.
http://www.defy.co.za/images/Manuals/BEKO_BOOK.pdf
Pre
Sep 05, 2014 | Washing Machines
Defy DDW 169 manual
My Defy DDW 169 Dishwasher won't go beyone draining on starting a wash cycle. What is the problem with the machine?
Dec 18, 2013 | Washing Machines
I have defy laundromaid electrologic 720, it does not stop draining the water?
My Defy electrologic 720 goes into washing mode ,but not filling up with water.
Dec 05, 2013 | Washing Machines
Our defy automaid 600 daw 322, will wash, but will not spin or rinse
My Defy Automaid 600 spin and drain without washing but only drain and do not spin with washing in (i have put only 1 t-shirt in - and still don't spin)
Jan 23, 2011 | Washing Machines
Defy Laundromaid 1300 has a serious leak. I've checked the filter, and there is nothing in it to cause it to leak. We had a Defy techinician come out and he also cannot find the leak. Please advise...
water pump is not functioning properly, when in spin cycle water in drum pushes up and over the top, symptom is water leaking out the bottom which indicates a leak but its actually the water pump not pumping out all the water. Gets air trapped in the pump which results in air lock and no head for the pump to function properly. Fix is to lower your drain pipe to same level as pump when in spin cycle so that the water runs out freely this will not solve the problem but will allow you to continue washing until you have the problem sorted.
Dec 26, 2010 | Washing Machines
Defy automaid instruction manual how to use
click the link below for defy automaid manuals and instructions guide:
thanks and plse do not forget to accept the solution.
Apr 03, 2009 | Washing Machines
Defy automaid won't spin
Put the machine on its side and check the wires to the pump. i found one of the wires broke off the lug on the pump side. Could be from all the vibration from the drum. The machine will only spin if the drainage is working.
Good luck.
Mar 10, 2009 | Washing Machines
Motorola Mobility Defy Cell Phone Logo
93 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
