Question about Hotpoint WB17X5113 Stove Surface Burner Unit Receptacle REPAIR PART FOR GE AMANA KENMORE AND MORE
Can I replace a kenmore stove burner with a GE burner
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 118 Answers
It depends on the Kenmore Model. Kenmore is the brand name for models sold by Sears, but they are not all manufacturered by the same company. They are made by Frigidaire, GE, Whirlpool, Amana, Samsung, LG... just to name a few. If you can post a model number of your Kenmore, I can give you the options for which elements will work for your machine.
Posted on Oct 09, 2013
Kenmore gas range 790, not getting gas to the stove top, oven works, all 4 igniters fire when any knob is used. Is this a safety shutoff and how do I fix it?
Burner Spark Electrode Replacement - Kenmore Gas ...
? 2:23
www.youtube.com/watch?v=U0VcfMJPaiY
Nov 12, 2010 - Uploaded by RepairClinic.com
+Tony Eatinsky If the electrode is not damaged than the spark module ... I have a kenmore gas stove ( 362.7555190) that won't ignite unless I use a match. ... I have a Kenmore Elite 5 burnergas range top, it auto light continually sparks? .... You most likely will need to cut or grind off the screws and get new ...
kenmore model 790 gas range. the gas stove top burners ...
www.shopyourway.com > Manage My Life > Questions
kenmore model 790 gas range. the gas stove top burners stopped sparking. ... NOTE: I do not recommend measuring voltage unless you have experience and feel ... if the spark module is getting 120 volts when the burner knob is turned to the ...
Oct 19, 2015 | Kenmore Kitchen Ranges
How to fix la germania burner?
Guess you mean a kitchen appliance not a cd/dvd burner! The only way to help you giving some advice about how to fix ut is if you tell us the problem you need to fix.
Describe your burner: is it a gas burner or an electric burner?
Had you repaired something similar before?
In any case, watch some youtube tutoriasl to repair a burner
Cooktop Range burner not heating burner light is on GE Hotpoint RCA...
GE Hotpoint RCA Gas Stove Repair Burner is not working JGSP44BEY3BB
Prego Project Fix GE Stove Burner
Stove Oven Range Burner Repair Diagnostic GE Hotpoint Kenmore Sears RCA...
Aug 19, 2015 | Computers & Internet
Where are the fuses for the Sears Kenmore stove to elements located on Model C880 675080L0
Most likely no fuses. Either the element or the switch that turns it on is bad. If lighat comes on when you turn on burner the switch is probably ok and the burner went bad.
Jan 02, 2015 | Kenmore Sears Electric Range Surface...
All pilots ignite when 1 gas knob is used on one burner
All igniters will spark when you turn on any burner but only the one you have turned on will allow gas through to ignite.
May 04, 2014 | GE Kitchen Ranges
Surface burner on electric smooth top range not heating. When turned on, the left rear burner does not light up at the dial or on the surface. How can we determine if replacement is necessary or there is a...
I have a GE Spectra smooth stove top and it has two burners in one, The problem is that the inside burner is not working. I need to find out how I can get into the stove to see how to fix it. Does anyone else have this problem and how did you fix it?
Jan 24, 2010 | Kenmore Kitchen Ranges
GE electric stove problems, our stove has 3 small burners and one big burner. When we use the big burner at medium heat it does fine then all of a sudden it starts glowing bright red and burns whatever is...
Replace the infinite heat control switch for that burner. (the burner switch that you turn with the knob to select the temp setting) If you list a full model number (usually behind the lower drawer panel on the frame of the range) I can look up the part number for you. It is not a very difficult repair.
Oct 11, 2009 | Kenmore 95592 / 95594 / 95595 / 95599...
GE range two large burners do not work. The two small burners work OK. One of the large burners has an obvious break in the calrod. Could it have blown a fuse or circuit breaker inside the stove that...
Burners went bad, Replace them. You may also have to replace where they plug into. Come problem with electric stoves. Easy fix! You can purchase at lowes, homedepot, or any appl repair parts store.
Aug 22, 2009 | GE JBP30 Electric Kitchen Range
The back burner of our Kenmore 30" electric free standing stove model # 911.94401301 is not working the coil is working it will heat up I am curiouse if it is the plug under the hood and is this...
This IS something you can fix
There are three likely causes, in most common occurence
there are fuses in the rear control console that blow
the socket does wear and require replacement
the temperature controller wires come loose, or the control fails.
check first for fuses
second swap the cables from the controller of the burner that doesnt work, to another controller to test if it is the controller or the socket.
  • swap cables with power disconnected and do NOT leave bare cables unsecured even while testing, better a live repairer, than a live wire
if the burner then works the controller is dead
if the burner still does not work, the socket is dead
the local parts store, or even a hardware store, will have the parts, even if branded frigidaire or ge or generic instead of kenmore, (Sears service is expensive and slow) many models of stove use the same socket, element, controller, clock, circuit board
Sep 10, 2008 | Kenmore Kitchen Ranges
Problem with Kenmore Electric stove
I have kenmore stove mod.790-95660103 you turn on any top burner . T he small one inside the big burner comes on Roy
Nov 24, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Hotpoint WB17X5113 Stove Surface Burner Unit Receptacle REPAIR PART FOR GE AMANA KENMORE AND MORE Logo
73 people viewed this question
Top Hotpoint Dishwashers Experts
AcmeUK
Level 1 Expert
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
