Question about Dometic RM2652 Refrigerator
Dometic DM2652 3 yr old Keystone Passport, Dometic DM2652 fridge always plugged in at home quit, there is power at the receptacle 120, propane full, all fuses are good, 15 amp, 3 amp and 5 amp on board, there are no lights on anywhere. No Light in fridge, no lights on display, is there a reset button or any other ideas?
    Top Expert:
  • Dometic Master
  • 7,897 Answers
Bad control board
Posted on May 27, 2016
  • 19 Answers
SOURCE: Dometic RM2652 Refrigerator Problem
Check the flu at the back is clean
Posted on Nov 18, 2008
  • 9 Answers
SOURCE: Dometic refridgerator won't stay lit on Propane
A bit more info is needed. What model #, and how old is it? In back, does it have a computer board (underneath a green or black plastic cover, appros 4" x 6")? Im guessing that it does, ('cause you get an error message,) Make sure that you have a good 12 volts going to the board at all times, and make sure that the glass fuses on the board are not blown. If that checks out, than its a real good bet the you have a defective board. For Americana models, you're going to need a Dometic board, and for other models, an aftermarket board will usually do. Althoiugh the OEM ones have a better chance of fixing your problem.
Posted on Jul 26, 2009
  • 10 Answers
SOURCE: i have a dometic rv fridge. it works on the 120
I'm not sure what the problem may be but you could try calling All Seasons RV Appliance Parts & Service. There number is 1-800-344-0673 they have helped me in the past. That and there tech calls are free so it wouldn't hurt to give them a call.
Posted on Feb 16, 2010
motor1258
  • 6674 Answers
SOURCE: 3 way dometic RV fridge RM2612 won't work on propane or 12 V
Check any fuses/circuit breakers in harness from battery. That battery should supply 12 volts dc to fridge lugs/terminals at bottom of fridge on outside behind vent.
If battery is good and hooked up properly but no 12 volts to fridge, then you will have to trace back to battery for broken /bad wire. If you want to test quickly, just run 2 jumper wires from battery to those 2 lugs marked + and - Battery + to + (pos)at fridge, and - battery to -Neg at fridge. That should allow you to run it on propane or 12 volt. Remember, running it on 12 volts will kill that battery pretty quick, unless it's being charged. When you are plugged in, the converter supplies the 12 volts to your fridge, as well as should be charging your battery.
Posted on Jun 22, 2010
motor1258
  • 6674 Answers
SOURCE: My dometic fridge, (3 Way) for the past couple
Have you tried running it without the fan? I know it sounds funny but it has to get hot (outside the fridge) to get cold inside. Shut fan off and see what happens. Also, keep in mind the more items you put in it that are already cold, or frozen, the faster it will cool inside the fridge. Also take a look up the back of the fridge, with outside cover off to make sure no big wasp nests or similar up there. May need to remove cover at roof and look down if you can't see too good from back of fridge vent.
Posted on Jun 24, 2010
I need to download manual for keystone passport 2008 285rl
make sure battery disconnect is on not off make sure fuses are good in converter and blow out fridge LP system and hot water heater burners cob webs and make sure LP is on and LP detector is good
May 08, 2016 | Keystone 2008 Passport 285RL
I have a dometic fridge that will not work on 120 or propane. all fuses are good. No lights inside fridge or on outside.
possible there is a restriction in the system. to repair turn fridge around and it should sit on the top for 24 hours. next step turn to normal position ,make sure it is leveled and check
May 21, 2014 | Dometic RM2652 Refrigerator
Fridge not coming back on.
bad board or check for fuse
Apr 21, 2014 | Dometic Refrigerators
My dometic rm2652 check light comes on after a the refrigerator is turned on with either gas or electric. What could be the problem?
First things to check would be the receptacle that fridge is plugged in to at back for power to it. You may have tripped breaker as well. Either way, you need to confirm that you have AC (hydro) voltage going to fridge, as well as test for min 11-12 Volts (DC) to back of fridge where the DC voltage connects. The check light coming on tells me you have 12 Volts DC, but just confirm. With propane on, make sure you have propane to stove etc, then try starting fridge on propane only setting, and listen or watch outside at burner for ignition. Let me know if you see it sparking, or hear it sparking.
Mar 24, 2012 | Dometic RM2652 Refrigerator
I have a dometic rm 2652 in a 2003 travel trl. The propane side works. The elect side quit working. There is power to plug. The lights for auto and fridge inter. also work. The two fuses are good.
Unplug hydro plug to fridge. Remove cover on circuit board. Follow wires from heating element, to terminals on circuit board. ( probably J7 and J8 ) . With an AC volt meter or multimeter set to AC voltage, turn fridge on hydro, and leave door open on fridge so that it calls for cooling. To be sure it's calling for cool, try gas first, when it's starts, you know it's calling for cool, then switch to AC operation. Now test for voltage at the 2 terminals that the heating element were/are attached to. If you get 100-120 VAC, then replace the heating element. If not get back to me and I'll walk you through a couple more tests.
Jan 26, 2011 | Dometic RM2652 Refrigerator
Fridge works on propane but will not cool on electric. unit is a dometic american 10 years old.
Are you familiar with the location of your heating element for 110-120 VAC.
DO you have a multimeter, or AC voltmeter, and know how to use it?
Jun 07, 2010 | Dometic RGE400 Top Freezer Refrigerator
My rm2552 fridge wont run off of 120 volt power but runs fine on propane any ideas?
I have a dometic rv refrigerator its gas/electric it worked 6 months ago. But can't get it to work now.
Sep 02, 2009 | Dometic RM2652 Refrigerator
Jul 26, 2009 | Dometic RM2652 Refrigerator
Dometic RM2652 Refrigerator Logo
158 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
