Question about HP LaserJet M1120 MFP All-In-One Printer
Scanner error 22
My printer not scan continue after 1 or 3 scan please give me solution about this my hp printer name is LasserJetM1213nf MFP please give me reply
    Top Expert:
  • HP Master
  • 45,064 Answers
Please refer this issue to HP for resolution
Posted on Jul 11, 2013
manojro
  • 495 Answers
SOURCE: Scanner Error 12
SCAN ERROR 12, IT'S A MECHANIC PROBLEM. YOU MUST CONTACT A TECNICIAN.
Posted on Apr 17, 2009
SOURCE: HOW TO SCAN FROM SCAN TO BUTTON IN THE NETWORK FROM HP 2727MFP
You need to install the HP Scan software on each and every PC the MFP should scan to. In this software, you can create targets for the "Scan To" button. But: This is only useful when scanning with the ADF, because when scanning from the flatbed, you'd need for every page to hit the "Scan To"-button, press "Scan", wait for about a minute or two until the MFP has found the appropriate PC, and wait for the scan. So network scanning is unfortunately very limited with this machine.
Posted on May 05, 2009
SOURCE: SCANNER ERROR 12
it is a physical brocken piece that supports scanner mechanism.
if you open that plate /scanner mechanism and if you drill that plastic sheet and try some manufactureed alluminium or metal projection and place it in the hole drilled by you and put washer and screew so that that supports ;the scanner mechanism and your scanner /printer works . the scanner mechanism may costs you around 3,000-00 rupees.
Posted on Apr 19, 2010
  • 8 Answers
SOURCE: Printer Model : HP Laser
indicate that the scanner unit are error.reseat the flexible cable in the scanner unit.
Posted on Nov 23, 2010
  • 8 Answers
SOURCE: ERROR SCANNER 22 EN IMPRESORA
REMOVE THE SOFTWARE AND FRESH INSTALL WITH THE DRIVERS CD
Posted on Dec 02, 2010
I have hp pro 400 always give me scanner error 6 and there is a sound inside the scanner please give me help??
Scanners should not have "sounds" inside so my wild guess is that something is broken and you should call to a repaiir resvide to get a diagnosis.
Oct 22, 2015 | HP LaserJet Pro 400 color MFP M475dw -...
Scanner error 12 shows
HP LaserJet M1005 MFP - Scanner Errors 6 and 12 Solution ISSUE: The scan head may not be in the correct starting position.
Updated firmware is available to resolve the issue.
SOLUTION: Upgrade to newer firmware (version20120831 or newer) available on hp.com Support & Drivers.
Select Drivers & Software, enter the product name/number, select operating system and locate the firmware download.
Nov 01, 2014 | Office Equipment & Supplies
Error 22
Go to hp website and look for firmware update. The model M1217 had the same issue which was fix in a firmware update.
Jun 07, 2012 | HP LaserJet Pro M1212nf MFP -...
Scanner error 22 M1213nf mfp
why it is showing scanner error 22 message
Feb 23, 2012 | HP LaserJet M1120 MFP All-In-One Printer
Modelo da impressora,HP laserJet M1120 MFP defeito... ao ligar a impressora no display aparece ..ERRO SCANNER 22..e nao scannea a imagem..... demais funcoes como impressao,aparentemente OK!
little bit I under stood your language, there is scanner error 22, remove flat bed glass, remove scan head, check mechanism observe any breakage, replace it mechanism, if no replace entire scanner head..see the test shot.
Sep 09, 2011 | HP LaserJet M1120 MFP All-In-One Printer
Unable to resolve "scanner error
how can i resolve the error code 22 on my hp laserjet m1212nf MFP?
Jul 23, 2011 | HP LaserJet M1120 MFP All-In-One Printer
Lazer jet M1120 MFP scanner error 22
Hey I'm using a HP LASERJET M1120 MFP. But every time I turn on the machine the screen says "Scanner Error 20". How to fix it up? Thanks!
Nov 03, 2010 | HP LaserJet M1120 MFP All-In-One Printer
Scanner error 6
Problem for HP LaserJet M1120 MFP All-In-One Printer Scanner error 6
Feb 22, 2009 | HP LaserJet M1120 MFP All-In-One Printer
My printer name is HP M5035 MFP LASERJET serial number cncxbo4735.it can't scan or photo copy error code 30.1.19
fixed the problem by removing the scanner cover and sprayed compress air on the scanner light bulb and cleaned it out.Put back together
Jan 22, 2009 | HP LaserJet M5035 MFP Printer
HP LaserJet M1120 MFP All-In-One Printer Logo
196 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
