Techne DB-700A Calibration procedure
Can some one help me with the calibration/ adjustment procedure for the Techne DB-700A Dry block calibrator.
Do it a service centre
Posted on Jul 11, 2013
SOURCE: Canon LBP-5000 Printer and Calibration
I solved this problem.
You need to bring your printer to some service, and perform cleanig of the printer's optic instruments, which are most probably coverd with dirt, and printer just can't recognize catridges, and can't give you the best print quality.
Just take it to the people who refill toners, or to some official service, they'll know what to do. I had the same problem as you, and today I can't recognize how better print quality is, and more importan, printer is not asking calibration any more.
Posted on Jun 02, 2010
shawn38
  • 200 Answers
SOURCE: Hi, Have a Kyocera KM4050 copier/scanner/printer
First you have to get into the maintenance mode. It is important once in there you don't make any changes other than the one I tell you or you could damage the machine.
To get into maintenance mode do the following:
Press the STATUS KEY
With the numeric key pad key in 10871087 (if done correctly the display will change and say ENTER MAINTENANCE ITEM)
Enter 201 with the numeric key pad (follow the steps below):
1. Press the start key.
2. Select the [INITIALIZE].
3. Press the start key.
4. Press the center of the + keys. Be sure to press three + keys displayed in order. The touch panel is adjusted automatically.
5. Press the indicated three + keys, and then check the display.
6. Press the stop key. The screen for selecting a maintenance item No. is displayed.
Completion
Now to exit maintenance mode key in 001 with the numeric key pad
Press the Start Key ( you should be back to the status screen, press copy key to go back to the copy mode)
Remember do not go to any other maintenance mode or make any other changes.
Posted on Feb 19, 2011
itdude4321
  • 13 Answers
SOURCE: Zebra S600 printer continues calibrating
The factory default settings for the S600 is to auto calibrate every time the printhead is closed and every time the power is cycled. If the media sensor is not positioned correctly for the media you are using the label size will not be detected during a calibration. You mentioned the media has no markings, doe sthe media have a space between the labels? If so, the media sensor may not see the gap in the labels adn therefor is not calibrating properly or not calibrating at all. Check the media sensor position. I have found that the media sensor must be at least 1" from the inner wall of the printer so it doesn't see the edge of the backing in oder to read the size of the labels.
Posted on Feb 02, 2008
  • 30 Answers
SOURCE: NO CALIBRATION SHEET
Hello, you can print a calibration sheet from the front panel of the printer. Hit menu on the panel of the printer and scroll down to calibration printer and hit ok. Then hit ok on print calibration page and it should proceed to print a calibration page. After it is done printing, it will tell you to scan the calibration sheet.
Posted on Mar 12, 2008
itdude4321
  • 13 Answers
SOURCE: Calibration
If the media sensor is positioned correctly and the printer is set for an autocalibration on power up and printhead close a manual calibration is not really needed. However, here is the information that is the easiest way to run a manual calibration.
Manual Calibration
With the printer at a ready state, press the MODE button two times or until the CALIBRATE light comes on.
Press the FEED button.
Once this is complete press the MODE button four (4) times to save these settings.
Posted on Mar 30, 2008
My 2007 checy impala read "calibration complete" what does that mean ????
CALIBRATION COMPLETE
Refer to Electronic Compass Calibration do you have an owners manual ?
Compass Calibration
The compass direction will show CAL if it needs to be calibrated. Before calibrating the compass, drive the vehicle to an area that is magnetically clean (free of large metallic objects).
  1. Turn ON the ignition.
  2. Before calibrating the compass, make sure the compass is set to the variance zone in which the vehicle is travelling. See Compass Magnetic Variation Adjustment below.
  3. Press the vehicle information button until the PRESS TO CALIBRATE COMPASS screen is displayed.
  4. Press the set/reset button to start the compass calibration.
  5. The DIC will display CALIBRATING: DRIVE IN CIRCLES. Drive the vehicle in circles at less than 8 km/h (5 mph) to complete the calibration. The DIC will display CALIBRATION COMPLETE when the calibration is complete.
Oct 02, 2016 | 2007 Chevrolet Impala
My subwoofer will not work with my receiver.
I had a similar problem where the subwoofer was working during calibration but not on TV viewing. Here is what I found:
  • That some listening/surround modes did not support the subwoofer.
  • Some receivers only support subwoofer with digital inputs.
  • Might also want to double check the speaker config and make sure it's has the subwoofer enabled.
  • I assume you're using the sub-pre-out to drive the powered subwoofer.
  • Have your tried a CD or FM radio station to see if you're getting the sub output from these sources?
Jan 08, 2015 | Yamaha RX-A840 AVENTAGE home theater...
Out of stock
Morrisettepa: This error occur when the labels are not detected, 1. the label is out of sensor, 2. the label sensor is dirty or blocked. Clean it, adjust in correct position and perform a sensor calibration. Press and hold FEED button by 5-6 seconds and release it. In display you can see CALIBRATION SUCCESS, if not, then repeat the quick calibration.
Sep 15, 2011 | Datamax DMX-I-4208 Label Printer
Datamax prints ten or so labels then skips one (leaves it blank) then continues on
First check the sensor is free of any label debris. Then follow instructions below:
Standard Calibration is appropriate for most media types. During the process, the printhead assembly can be raised for visual access to the media and media sensor. In addition, displayed sensor readings can be used to indicate the best position over the media, which is helpful when using small, position-critical TOF notches or marks.
Three readings are required:
.No Media
.Lable Backing
.Backing plus lable
Step Operator Action Displayed Message Comment
5 Press the key. SENSOR CALIBRATION
PERFORM CALIBRATION
You are beginning the standard
calibration procedure.
6 Press the key.
Remove the media from the
Media Sensor then press any
key.
REMOVE LABEL STOCK
PRESS ANY KEY <yyy>
This sets the parameter for the
'empty' value.
Where 'yyy' is a numerical
value representing the current
sensor reading.
7 Proceed according to your
media type:
Die-cut stock: strip the media
from the backing and then
reinsert it into the sensor; adjust
the Sensor Eye Mark over the
center of the backing.
Notched stock: adjust the
center of the notch.
Reflective stock: Adjust the
center of the facedown black
mark.
Continuous stock: go to Step
8.
Press any key to continue.
SCAN BACKING
PRESS ANY KEY <yyy>
Or, for reflective media:
SCAN MARK
PRESS ANY KEY <yyy>
'gap' or 'mark' value.
sensor reading: useful in
locating the best sensor
position.
ã Note: Never position the
sensor over a perforation when
recording a sensor reading.
ã Note: Do not move the position of the Media Sensor after it has been adjusted.
8 Position the label (and backing,
if any) under the Sensor Eye
Mark.
ã Note: If using preprinted
media, ensure the label area
under the sensor is free of
preprinted text, graphics or
borders.
SCAN PAPER
PRESS ANY KEY <yyy>
'paper' value.
sensor reading.
Maintenance and Adjustments
5-3
Standard Calibration (continued)
9 Observe the display. GAP MODE
REFLECTIVE MODE
Or, for continuous media:
CONTINUOUS MODE
The calibration was successful.
See note below if another
message was displayed.
10 Exit upon successful
calibration: Back out of the
menu tree by repeatedly
pressing the key.
If using gap or reflective media,
press and hold the FEED key.
The printer will begin
advancing media; allow at least
one label gap (or mark) to
advance under the sensor.
READY
The printer is now ready to
begin printing.
Aug 09, 2011 | Datamax DMX-I-4208 Label Printer
Good morning. my printer will not calibrate. Could you please help me out?
Perform a Manual Calibration:
Perform a media and ribbon sensor calibration to reset the sensitivity of the sensors so the
media and ribbon are detected more accurately. If you change the type of ribbon or media,
your printer may operate better if you perform this calibration.
Calibrate Media and Ribbon Sensors
Use this procedure to adjust the sensitivity of the printer's sensors. In a
printer that has the Thermal Transfer option installed, both media and
ribbon sensors are adjusted. In a Direct Thermal printer (no Thermal
Transfer option installed), only media sensors are adjusted, and the LCD
displays for ribbon do not appear in this procedure.
Important • This procedure must be followed exactly as presented.
All of the steps must be performed even if only one of the sensors
requires adjustment. You may press the left arrow at any step in this
procedure to cancel the procedure.
How to select this parameter:
1. Press ENTER to start the calibration procedure.
The LOAD BACKING/REMOVE RIBBON prompt displays.
2. Open the printhead.
3. Remove approximately 8 in. (203 mm) of labels from the backing,
and pull the media into the printer so that only the backing is between
the media sensors.
4. Remove the ribbon (if used).
5. Close the printhead.
6. Press ENTER.
The message CALIBRATING PLEASE WAIT displays.
The printer adjusts the scale (gain) of the signals that it receives from
the media and ribbon sensors. On the sensor profile, this essentially
corresponds to moving the peak of the graph up or down to optimize
the readings for your application.
RELOAD ALL displays.
7. Open the printhead and pull the media forward until a label is
positioned under the media sensor.
8. Reload the media and ribbon (if used).
9. Close the printhead.
10. Press ENTER.
The printer does a calibration; during this process, the printer
determines the label length. To see the new readings on the new scale,
print a sensor profile.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 25, 2011 | Zebra Z4Mplus Label Printer
How do i calibrate my speedygreen 2000 broadcast spreader
You may check the calibration by using the following directions. First, adjust your micrometer setting to 2. Squeeze the trigger against the handle. The calibration line is a small, raised line embossed on the top of the spreader's shut-off plate. With the micrometer set at 2 and the trigger squeezed against the handle, the calibration line should be aligned with the back edge of the hopper opening.
To adjust the alignment, use a small wrench to turn the black calibration screw at the lower end of the control wire leading from the micrometer rate setting barrel. Adjust the screw until the calibration line and back edge of the hopper meet. If you have any difficulty checking the calibration, contact us and we will be happy to help walk you through the adjustment.
When you are not pulling on the trigger handle, the cable should be loose. When you pull on the handle, the cable becomes taut and the shutoff plate slides open.
If you need further assistance feel free to contact us @ 1-800-543-8873
Jan 24, 2011 | Scotts Company Scotts& Accugreeen 2000...
How do i calibrate the scotts speedygreen 2000
Your SpeedyGreen 2000 Rotary Spreader spreader was calibrated at the factory. However, a spreader's calibration may change or slip during periods of frequent or heavy use.
If you have any additional questions feel free to contact Scotts directly @ 1-800-543-8873
Jan 24, 2011 | Scotts Company Garden
Upper body workout arms on Startrac 6230 crosstrainer are locked in the ''None'' position. How do I switch to ''Pushing'' or ''Pulling''?
You May have to recalibrate Here is the procedure
Engaging Maintenance Mode 1. Press and hold the , and keys together. 2. A beep will sound and the “MAINTENANCE MODE” will display momentarily in the information window. 3. Release all keys. “SERIAL NO XXXXX” will display in the information window.
Modifying the Maintenance Mode The following keys are used to modify Maintenance Settings: Upper and Lower Data Information Window SCROLL keys: Display the next and previous settings. Increase and Decrease Level Keys: Adjust the value of the displayed setting up and down respectively, in increments of 1 unit. OK Key: Updates (saves) the value of the display setting in the Flash
Diagnostics - UB Calibration UB (Upper Body) Calibration (Elite Only) The UB Calibration will set the minimum and maximum range of the upper body arms in which they can move within. You can do a Manual Calibration or an Auto Calibration. Auto Calibration is recommended. To calibrate the Upper Body: 1. Enter the Maintenance Mode (see Settings – Maintenance Mode). 2. Press until UB Calibration is displayed in the information window. 3. Press to enter UB Calibration Mode. Manual Calibration 1. For Manual Calibration press 1. 2. Press the until the upper body arms stop moving (None Position), and then press to save. 3. Press the until the upper body actuator stops, and then press the to save. Auto Calibration For Auto Calibration press 2. The display will automatically raise the arms up, then bring them back down to calibrate the positions.
Mar 15, 2010 | Startrac Fitness Products Exercise &...
CALIBRATING A TANITA KD-200-110 DIGITAL SCALE.
According to Tanita, you must send the scale back to the factory to adjust the calibration. As of September 2011 the cost is $125.00
This is more the scale costs.
Moral of the story. Don't buy Tanita.
Aug 24, 2009 | Tanita 1479V - Digital Pocket Scale /...
Compass out of whack
You need to recalibrate the compass. The procedure is in your owners manual. Here are the basic steps.
First, you will need to verify that your compass zone is set to your current geographic location. Since I do not know where you are located, I cannot tell you the code. They are listed in the manual. (For example, So Cal is zone 5.)
Second, here is the compass calibration adjustment procedure:
Perform this adjustment in an open area free from steel structures and high voltage lines. For optimum calibration, turn off all electrical accessories (heater/air conditioning, wipers, etc.) and make sure all vehicle doors are shut.
1. Start the vehicle.
2. To enter the compass calibration mode, press and hold the button for greater than eight seconds. The display will then show CAL in the display window.
3. Drive the vehicle slowly (less than 3 mph) in circles until CAL indicator turns off. As many as 5 complete circles may be required.
4. The compass is now calibrated.
Dec 19, 2008 | 2005 Ford F-150
190 people viewed this question
jasbo
jasbo
