Question about HMF Suzuki King Quad 700 05-07 Swamp Series Slip On Exhaust System
Clicking when slowing down suzuki king quad problems
There is a clicking noise in the front end when slowing down
My 2013 Suzuki 750 King quad EFI will start but if you move the steering it shuts down. Also, when slowing to a stop, the bike stalls. Each time the bike stalls it immediately starts.
Sounds like you have a wire that is ALMOST broken or the insulation is worn off and grounding, or turning is pulling a wire loose from a connection. .. this type of problem is HARD to trace down sometimes... good luck
Sep 04, 2017 | Suzuki 2006 KingQuad 700 4X4
My 2013 Suzuki king quad 750 shuts down when turning mainly at a standstill and slowing to a stop and while leaving from a stop. Runs normal at speed.
Hey Jahn,,
sounds like it might be time for a new spark plug (FIRST) and maybe a carb cleaning by a qualified professional.
Sep 04, 2017 | Suzuki Motorcycles
King Quad 400as 4x4. Why doesn't it start?
Hi, Chip this flow chart is for a Harley but the procedure is still the same, it should be noted that in order to "PROPERLY" diagnosis any electric starter issue it is "IMPERATIVE" that you begin with a fully charged battery 12.5 volts or better and be able to pass a proper load test if necessary, and the usual suspects are:
1. Battery terminals have loose or corroded connections.
2. Battery cables faulty due corroded or broken internal wiring at the cable connector especially the "NEGATIVE" cable which needs to be checked at "BOTH" ends.
3. Battery voltage, 12.5 volts or better,to the main circuit breaker to the ignition switch to the security/ignition fuse to the TSM/TSSM module to the engine stop/run switch to the starter button to the starter relay to the green wire that connects to the starter solenoid has dropped more than 1/2 volt.
4. With a voltmeter connected to the battery, the ignition switch in the on position, the kill switch in the run position, the starter button depressed, starter engagement should not bring voltage below 8-9 volts.
If a lower voltage is produced a proper battery load test should be performed with a load tester to validate battery integrity or battery replacement.
5. Faulty starter relay, check continuity.
6. Faulty starter solenoid, check contact plate and shoes for excessive electrical erosion/etching, refurbish as necessary or invert contact plate and use the virgin backside. Check contact shoes for being loose. Replace solenoid if the negative function is still a final outcome.
7. Faulty starter, bench test starter with a 12-volt battery if negative function check, decontaminate and undercut armature commutator segments as necessary, check segments with an ohm-meter probe each one and the segment next to it for shorts. Have the armature tested with a growler and field coils, and brush plate with an ohm-meter for opens, shorts or grounds. Replace brushes if less than .438" It is generally cheaper to overhaul/refurbish a starter motor than buy a new one.
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
Suzuki LT 4WD Quad Runner Starter Repair
king quad wont start clicks see what have to say please
1999 suzuki 300 king quad starter won turn over just clicking noise
https://www.tradebit.com/filedetail.php/147670434-suzuki-ltf400f-king-quad-pdf-service-repair
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 22, 2016 | Suzuki Motorcycles
Does any one have wire diagram and wire pin out for suzuki king quad lt300
Hi, Anonymous sorry you can't find the first and best tool you ever bought for your Suzuki despair, not for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
wiring diagram 2001 300 king quad
https://www.tradebit.com/usr/mubiz/pub/9003/preview_Suzuki-King-Quad-300-Lt-f300-Ltf300-Lt-f300f-99-04-Official-Service-Repair-Manual.pdf
OEM parts for Suzuki
Suzuki KingQuad 500AXi 2011
2000 SUZUKI KING QUAD 300 LOSES POWER WHEN EXCELLERATE
Hi, Norman for more information about your question and valuable free downloads that you will need please visit the websites below. Good luck and have a nice day.
02 Quadrunner Carb or Ignition Issue
ATV Connection
95 king quad 300 loads up and dies Utility ATV
https://www.tradebit.com/filedetail.php/166275851-suzuki-king-quad-300-lt-f300-ltf300
Feb 21, 2016 | Suzuki Motorcycles
Can't find a suzuki king quad 300
Hi, Norman sorry you can't find the first and best tool you ever bought for your Suzuki despair not for a mere $5 you can download another one. For more information about your issue and valuable free downloads that you will need please visit the websites below. Good luck and have a nice day.
https://www.tradebit.com/filesharing.php/search/0/2000+suzuki+king+quad+300
need PDF manual for 2000 300cc 4x4 Suzuki ATV Forum
KingQuad 300 4x4 Specifications Suzuki Motorcycles
Feb 13, 2016 | Suzuki Motorcycles
Suzuki king quad problems
Take directly to a professional! DO NOT ATTEMPT TO RIDE!! It will just get more expensive!!!!
Jul 05, 2014 | ATVs
I have battery issues. The battery on my king Quad does not last. I am on my fourth battery. I use a battery tender for the winter but just letting the machine sit for a month will run the battery down. I...
Its the King Quad. I have the same problem. Don't expect Suzuki to do anything about it once the warranty is up. They are terrible. I used to love Suzuki, but will never buy one again.
Sep 12, 2010 | Suzuki GSX-R 750 Limited Edition...
Adjust the clutch
to adjust the clutch on suzuki king quad 1999 locate the oil filter on the right side of the bike look for three bolts with a bigger one in the middle of the threethe middle srew will open up a nut and a set screw in the middle loosen the the nut and turn the the adjustment screw while you are in first gear . hope this helps you
Nov 10, 2008 | 2008 Suzuki B-king
HMF Suzuki King Quad 700 05-07 Swamp Series Slip On Exhaust System Logo
63 people viewed this question
Top HMF Scuba Diving & Snorkeling Experts
David Bugden
David Bugden
Bill Boyd
ray gallant
Are you a HMF Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
