MTX X Thunder 1000XD Car Amp
Problem for MTX X Thunder 1000XD Car Amp
Humming sound to speakers from amplifier
By jose_rosas15 on Mar 28, 2009
speakers make a humming sound once hooked up to amplifier even if radio is not on, the higher i put the gain up the louder it gets. once i turn the radio on i can hear the bass but the humming sound is still in the background and in between songs can someone help?
Comments:
Mar 29, 2009
- Thanx, heres the thing i hooked up a different amplifier and it worked perfectly fine which gives me a reason to believe that it is something within the amplifier itself but i can be wrong? Thanx in advance any help is appreciated
Best Solution
posted on Mar 29, 2009
Helpful)
etirbynnor
Rank: Guru  Car Audio & Electronics  Expert
Rating: 94%, 273 votes
It sounds like you may have a ground loop issue. I'd start by checking all the power and ground connections. Then disconnect the RCA wires from the amplifier. If the hum goes away then you should try grounding the stereo to a better grounding point, the factory grounds are usually not very good at all. Then try it again, if it is still there try replacing the RCA"s.
If the hum is still there after you've redone the connections and replaced the RCA's, you may need to install a ground loop isolator.
Both www.crutchfield.com and www.sonicelectronix.com sell good ones.
Hope this helps
Comments:
Mar 29, 2009
- Well, you are probably correct. The amp may be defective. When you tested, if you hooked up the different amp to all of the same connections, then the problem cannot be there, It's got to be in the amp itself.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for MTX X Thunder 1000XD Car Amp
Questions and Unsolved Problems for MTX X Thunder 1000XD Car Amp
Do you recommend MTX X Thunder 1000XD Car Amp?
Answer
Answer
i have a nissan avenir 2004 i have just installed a panasonic head unit i have not used wiring... (More)
Answer
I purchased a Sony car steroe CDX-R 550 (without USB) in Apr'09 during new car delivery from... (More)
Answer
wiring color code for sony cdx-gt520
Answer
When hooking up rc cables for subs, I then have a roaring sound come from my rear deck and front... (More)
Answer
how to connect my bluetooth in my honda accord 2003
Describe your Car Amplifiers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Car Amplifier Experts
Top Audio & Video Equipment Repairmen
in , IL
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
