Question about Maytag Refrigerators
Search Fixya...HOW TO INSTALL A FAN #12002738 IN MY MAYTAG REF.
INSTALL ACOMPRESSOR FAN
We have a Maytag Peforma Model PBB2255GES Maytag Refrigerator. It has a bottom freezer drawer. We have water pooling under the right front leg of the freezer.
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 29, 2011 | Maytag Refrigerators
Water is dripping down the back of the inside of the refrigerator. Maytag Admiral LTF2112AR
Leo Ponder
imufo2
Aug 15, 2011 | Maytag Refrigerators
The refrigerator and freezer stopped cooling
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Leo Ponder
imufo2
Jul 28, 2011 | Maytag 26 cu. ft. Wide-By-Side...
Refrigerator not cooling? Freezer seems to be working.
I'm Leo
Leo Ponder
imufo2
Jul 27, 2011 | Maytag (MFI2568AEW) Bottom Freezer French...
The main part of the fridge is heating up becouse defrost system is not melting the frost in Maytag Plus model MSD2657GES
I'm Leo
If this was helpful please rate me
Leo Ponder
imufo2
Thank you for using fixya
Leo Ponder
Please VOTE FOR ME IF THIS WAS HELPFUL.
Please click for article
Jul 26, 2011 | Refrigerators
Frig and frezer won't get cool to proper temp
I'm Leo
This is a common defrost problem, The ice
is not being melted by the defrost system. he fan can't blow into ref.
Also check evaporator fan in freezer
Leo Ponder
imufo2
Leo Ponder
Jul 24, 2011 | Maytag MSD2756G Side by Side Refrigerator
How do you change the defrost controller and the relay .Would really like a how to on this one.
I'm Leo
Leo Ponder
imufo2
Leo Ponder
Jul 24, 2011 | Maytag MBB1954G Bottom Freezer...
The freezer side of our maytag side by side just stopped staying cold, the fridge part seems cool still but maybe not quite as much as before, you can still hear the entire fridge working, we took off the...
Take out back panel of freezer to check for icw build up. The coils should be clean.
Leo Ponder
imufo2
Jul 23, 2011 | Maytag MZD2766GES Side by Side...
The freezer works fine but the fridge is not cold. Fridge set at 8, freezer at 9
I'm Leo
Leo Ponder
imufo2
Leo Ponder
Maytag refmodel number mff2557hew
sounds as if perhaps the fan in the freezer is not circulating air up to refrig sect. pretty common issue, if you pull out freezer door youll be able to hear the fan on the back wall, behind the vent on top sect of freezer. that cover pops right off with a pry of the screw driver.. heres the part number if indded that is the issue 12002744 comes with instuctions on how to install
Nov 09, 2008 | Maytag Refrigerators
Refrigerators Logo
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
