Question about Samsung Galaxy Cell Phones
Handset is getting warm and getting turn off after few minutes
    Problem Solver:
  • 7 Answers
Pls help me find it
Posted on Jul 11, 2013
Pairing a tracfone with Mazda hands-free Bluetooth....constantly get beeping and requests from A T and T .....
The car's built-in phone seems to work well, but the handset beeps every few minutes with another 'request'.
Mar 04, 2014 | Computers & Internet
Manual for Panasonic Handset KX-TGA560B
For the KX-TG5672, you should press and hold the Intercom button until the charge indicator flashes. Then press the button to assign the handset # 1, 2 or 3 (keypad 1, 2 or 3). Then press OK on the handset and wait for the handset to beep. These steps must be done within a minute from when the charge indicator flashes. It's best to have the base and the handset close together when you register the handset.
Panasonic has the manual for the TX-TGA560 available here: http://service.us.panasonic.com/OPERMANPDF/KXTGA560-MULTI.PDF . (This manual covers both the KX-TGA560B and KX-TGA560M.) The manual for the KX-TG5672 is available here: http://service.us.panasonic.com/OPERMANPDF/KXTG5671S.pdf .
If you still have a problem, try removing the battery from the handset and disconnecting the power cord from the base (from the wall and the base itself). Wait a few minutes and then reconnect the power cord and the battery for the handset. (Make sure that the base has power and the adapter is warm.) Then try registering again.
I hope this helps.
Jan 03, 2012 | Computers & Internet
Phone says searching
Bring the handset that says searching into the same room as the base and see if the handset stops searching. Next unplug the handset batteries (yes from all handsets) and the base power cord (from both the base and the wall outlet). Wait a few minutes and then reconnect the batteries and base power cord. Next try to de-register and then re-register the handsets. (If you add a comment with the phone model, I'll help you with this step. Uniden has the manuals for their phones on their site: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl .)
If this doesn't help, next try a new battery (and make sure that the battery is fully charged) for the phone. (If the phone is under warranty, contact Uniden. Note: batteries lose their ability to hold a charge over time. This includes the time on the shelf in the package.)
If a new battery doesn't help, then there is something wrong with the handset. Decide if it is worth having the unit fixed if the phone is out of warranty.
I hope this helps.
(I'm assuming that both handsets are cordless. If you have a corded/cordless model, then check that the base has power before you go farther with the above diagnostics. The power brick should be warm. We had a cordless phone on a power strip (UPS) that got turned off. The handset was searching for a signal that wasn't being sent. If you have power to the base, try sending the Find Handset message. The problem could be either the base or the handset not sending and receiving the signals between them.)
Dec 11, 2011 | Uniden DECT 6.0 Cordless Phone
My oil fired hot water heater provides only sporadic hot water. For example, when I am home alone it takes 2 minutes to get luke warm water in the shower, then it is only warm for a few minutes, then...
It sounds like your thermostat on the water heater isn't working properly. try turning it up higher and if this doesn't work I would have a service techy look at it.
Mar 24, 2011 | Water Heaters
I have a SKPE Phillips phone VO1P8411B/37. In an effort to fix the phone I de-registered it. When I select REGISTER, it comes back with 'Registration failed'. I tried to put in the default code of 0000...
Firstly, unplug the base unit, then remove from this base unit the ethernet cable and most importantly, unplug the telephone line! Then remove the batteries from the 2nd handset. Keep everything unplugged for a few minutes, then plug the power into the base unit, wait 1 minute, then plug in the Ethernet cable and wait 5 more minutes. Do NOT plug in the telephone line just yet. After the 5 minute wait, put the batteries back into the 2nd handset and then follow the registration instructions from the manual (copied below)...
Make sure you have configured the language, country code, and area code of your
phone before registering additional handsets.
1. Press "Reg.". Register shall be highlighted.
2. Enter the system PIN (Default: 0000). Use "Clear" to correct typing errors.
3. Press "Enter" to confirm.
• Your handset starts searching for the base.
4. Press the top button on the base unit until the two indications turn off.
• If registration is unsuccessful, the signal icon displays steadily.
TIP: IF REGISTRATION FAILED, REPEAT THE ABOVE PROCEDURE.
Like other methods, you must hold down the button on the base unit until the lights STOP blinking. When you have successfully registered your 2nd handset, then plug in the telephone line into the base station. I did the above and it worked! The trick is to be patient and wait the few minutes while everything resets itself.
Aug 05, 2010 | Philips Lands Phones
MY NETGEAR SPH 200D IP PHONE NOT CNNECTIONG TO INTERNET . I GET MESSAGE SYSTEM STARTING UP BUT NEVER WORKS. I DONOT HAVE INSTALLATION CD
Follow the steps below to resolve the issue:
1. Disconnect the power to the base station.
2. Remove the batteries from the handset - leave them out for a few minutes and when you replace them, don't try to turn the handset on: just put it in the charger base and leave it for 15 minutes or so.
3. Plug in the power to the base station and leave it for a minute to settle down.
4. Take the handset out of the cradle and turn it on.
Rate it, if it helps.
Apr 13, 2009 | NetGear SPH200D IP Wireless Phone
Vtech cordless phone appears to be mute
Try the "hard reboot". /1/ Unplug power from base station. /2/ Disconnect battery in each handset. /3/ Wait a few minutes. /4/ Reconnect battery. /5/ Re-plug-in power to base station. /6/ Place handset in base station, and wait a few minutes for it to recover.
You may have to reset time/date and/or the handset ##.
Aug 24, 2008 | Vtech 9009111 Cordless Phone
Cellular phone
Your phone is most probably dead. However, if you are very lucky, the following procedure may help: Firstly, remove the battery and SIM card. Then you need to leave the handset somewhere warm to dry for a few days. (you could try a hairdryer, but don't get the handset too hot)
Finally, re-install the battery and SIM card, connet the handset to your charger and prey...... good luck.
Mar 23, 2008 | Sony Ericsson K600i Cellular Phone
Vtech,5.8 3-phone w/digital recorder, model DS4122-3 None of the phones work they either say connecting or put back in the charger . these are only 2 months old?
To deregister ALL handsets:
Step 1: Press and hold FIND HANDSET on the main telephone base for 10 seconds.
Step 2: When the IN USE light starts to flash, release the FIND HANDSET button.
Step 3: Press and release FIND HANDSET again. The IN USE light will turn off and in a few seconds, all handsets will be de-registered.
Step 4: All handsets will show NOT REGISTERED.
To register a handset (register 1 handset at a time):
Step 1: Place the handset in the base unit or a charger that is connected to a power outlet. If PRESS FIND HNDST 4 SEC ON BASE does not appear on the screen after a few seconds, lift up handset and place in base or charger again.
Step 2: On the telephone base, press and hold FIND HANDSET for four seconds. Release FIND HANDSET once the IN USE light comes on.
After a while the handset will emit a series of tones, the newly registered handset will be assigned the lowest extension number not previously assigned to another system handset (1-4) when successfully registered. Repeat Steps 1 and 2 if the handset does not successfully register to the telephone base within two minutes.
REPEAT THE REGISTRATION PROCEDURE FOR EACH SYSTEM HANDSET.
Make sure the handsets are not receiving interference from other appliances, cell phones, etc.
IF deregistering does not work .. you will need to reset the entire system
Step 1: Disconnect the power to the telephone base.
Step 2: Disconnect the handset battery.
Step 3: Wait a few minutes and then reconnect the power to the telephone base.
Step 4: Reconnect the handset battery
Step 5: Wait about one minute for the handset to re-establish a link with the telephone base and then test the phone again.
You will need to set the time and date again after resetting the entire system.
Mar 11, 2008 | Lands Phones
Vtech M6896 phones do not work
Jan 18, 2008 | Vtech mi6896 Trio Cordless Phone
Cell Phones Logo
12 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
