Question about Pool & Spa
Is it safe to do a back flip off a diving board?
    New Friend:
    Problem Solver:
  • 10 Answers
It's safe as long as you are making sure to leap back as far as possible. Before you try it you should get some practice without the board just to make sure you are getting far enough away.
Posted on Jul 11, 2013
Is it safe to let my three year old use our waterslide alone?
I think that depends on which slide you have. Is it very high? Does it have high walls or is it tubular? If it is tubular I would say there is no problem because your child will not be able to fall out the side.
Jul 11, 2013 | Pool & Spa
Battery replace for Citizen Cyber Aqualand NX
My Cyber was working fine and reporting a full charge, but when diving, it would stop working and go into safe mode. I sent it in to Citizen and they replaced the cell, now all is good again.
Mar 06, 2013 | Citizen Promaster Cyber Aqualand Nx Dive...
What are the possible lengths for residential diving boards?
residential diving boards can be anywhere from 6 to 12 feet in length
Jan 28, 2013 | Pool & Spa
Can i adjust the spring on my diving board?
for home diving boards, the fulcrum is usually unmovable because giving too much spring can be dangerous. on professional diving boards, the fulcrum can be adjusted to be more or less springy
Seiko M705 - 5A10 series divers watch. Time is Frozen
Have the batteries checked and an "AC" done to it. These watches generally have several batteries and the die off can be slow and only fail partially. The "AC" or all clear function will reset the circuit board and bring all your functions back.
As with any dive watch, be sure that you take it to a watch maker/technician that can reseal and pressure test the watch to insure it is safe for diving.
Sep 18, 2009 | Watches
How do i install a dive stand for a diving board can i use red head concrete bolts to mount it to the deck
im not sure what red head concrete bolts are but typically you drill a hole just smaller than the bolt into the concrete with a concrete drill bit then screw in the bolts. make sure to not over tighten or make the hole too big you could break off the head.
Sep 15, 2009 | Sr Smith 8' Frontier III Diving Board -...
How and why scuba gauges give a diver critical information while scuba diving?
Scuba gauges give a diver three very important pieces of information: 1. Time 2. Depth 3. Air Consumption This information enables a diver to stay within safe time and depth limits and avoid running out of air. There are many different devices on the market to help with this, from simple gauges to complex digital consoles. Time If a diver is not using a dive computer to monitor their nitrogen, they dive according to approved dive tables. To use dive tables properly, a diver needs to track their downtime. This can be done with a good dive watch. Two things make a good dive watch: water resistance and a rotating bezel. 1. Water Resistance. Good dive watches are rated to a depth in meters or feet (e.g. 200 feet) or a pressure rating in atmospheres (e.g. 4atm). Even though most divers probably won’t dive below 130 feet (the recreational dive limit), a good dive watch should be rated to 200 feet. Note: There is a difference between “water resistance” and “waterproof”. A “waterproof” watch is what you would wear in the shower, but would probably start leaking at 15-20 feet. 2. Rotating Bezel. A bezel is an adjustable ring on the face of the dive watch with a pointer indicator. At the beginning of a dive, the pointer on the bezel is aligned with the minute hand where it stays though out the dive. At the end of the dive, you compare the difference between the bezel and the minute hand to find out the length of the dive. The bezel should only move “counterclockwise”. It is possible to accidently move the bezel during a dive. Because of this, watchmakers make sure any accidental movement will turn the time in a conservative direction, making the dive longer rather than shorter. Depth Another important part of scuba gauges is a depth gauge. A depth gauge enables a diver to keep track of their depth even if they cannot see the water’s surface. Gauges can be either an analog (needle-and-dial) device or a digital device. Both work in the same way. They measure the surrounding water pressure and convert this into an accurate reading of your depth. Another feature of a good depth gauge is a maximum depth indicator. This tells a diver their maximum during a dive and must be reset after each dive. Air Consumption Another equally important part of scuba gauges is a submersible pressure gauge (SPG). This is connected to the first stage with a high-pressure hose and measures the pressure of the air in the tank. The SPG is much like the gas gauge on a car. At the beginning of a dive, a diver starts with a full tank. This should be about 3000 psi or 200 bars. As the diver breathes during the dive, the gauge will move slowly downwards. This allows the diver to have enough air left in the tank to: 1. Make a slow, safe ascent 2. Make any necessary decompression stops 3. Inflate their BCD once at the surface 4. Breath from the regulator if the surface conditions are rough A submersible pressure gauge also allows a diver to stop diving with air still in the tank. This keeps contaminants from entering the tank due to no air pressure. Wrist Depth Gauge Scuba gauges come in two basic styles. Stand alone gauges or gauge consoles. Stand alone gauges such as a wrist mounted depth gauge or a submersible pressure gauge attached to the first stage of a regulator are great backups when using digital gauges. Gauge consoles allow divers to have all their gauges in one place. Although less easy to read, analog gauges sometimes give slightly more accurate readings than digital gauges, particularly at shallow depth. Submersible Pressure Gauge Choosing Scuba Gauges When choosing scuba gauges, remember to look for: 1. Easy-to-read numbers 2. Luminescent dial or back lighting options 3. Rotating/swivel mounting 4. Easy disassembly for cleaning or replacing parts 5. Good warranty
Dec 01, 2008 | Aeris Max Depth Analog 2 Gauge Console
Need to replace flip lcd housing
its pretty simple
1. remove 4 screws in the back of phone.
2. remove back cover
3. unclip lcd connector from main board
4. remove main board
5. reassemble with new flip
Nov 22, 2008 | Motorola Mobility i560 Cellular Phone
How deep can I dive with this watch
Per "Sector" all of their watches are "water resistant to a minimum of 300 feet". Note that they do not say "water proof".
Aug 20, 2007 | Sector 450 2653450035 Wrist Watch
Pool & Spa Logo
883 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
