Question about De Dietrich DOC310 Electric Single Oven
Where is the themostat please
Hi the oven is overheatin and the fan is ok cheers
Tricity Bendix SE556SV lower oven not reaching tempature, new element, themostat and fan
First need to see if supply voltage is correct.
Verify oven probe sensor to the thermostat Is working properly? (usually done by Ohm test)
Thermostast offer an option for calibration?
Also have you verified actual oven temperature with an external thermometer?
Jun 09, 2015 | Ovens
Candy oven broken
Poor quality connectors or crimped wires I would think.
Sep 16, 2017 | Ovens
The oven works fine as in it heats up but when turned off the cooling fan keeps going...used it last night and this morning the fan is still on...turned oven on and it is heating up but as I said the fan...
most ovens use a cut in limpet themostat(sometimes called button stat) typically normally open and closed at 40deg c. it will be this that will be not resetting to the open position at room temp. on rarer models the timer controls the cooling fan. some models of aeg and electrolux have a thermal delaying device located in abulb in the wiring loom. hope this helps
Aug 02, 2010 | Ovens
Oven cuts out as soon as it reaches temperature
not expert on bosch but sounds like cooling fan not working, either fan defective or cut in themostat not working.
Jul 22, 2010 | Bosch Ovens
Fan assisted oven not heating to correct temp
Assuming the fan is working, then are a couple of possibilities.
1- the oven element is not working.
2-the themostat or regulator is not controlling the temperature properly.
If you put your hand in front of the blower fan, you should feel hot air blowing, if you can't, then it is probably the oven element that has failed.
This is located at the rear of the oven compartment behind a removeable cover.
Hope this helps.
Jan 04, 2010 | Baumatic Ovens
Whirlpool oven not heating up, though grill, fan and light still
Hi.
If fan in oven is working o/k, then the prob is most likely the oven element is faulty, and needs to be replaced.
Please rate my solution.
Thanks.
Aug 20, 2009 | Ovens
Delonghi oven grill broken, oven still works?
You will probably find it is the grill element that is faulty, a common fault on your brand of oven, to be certain, you need a meter to test it.
Thanks.
Jul 15, 2009 | DeLonghi Ovens
Please help Fan not working in Neff U1451
Hi, the fan is one part and the bulb another. They are not connected. If the bulb isn't working simply unscrew the bulb lens and replace the bulb. About the fan motor, sometimes they cease up because the build up of grease at the back of the oven. You can try to remove the insid back plate that covers the element and fan, and try to rotate the fan manually. Try to clean it and test again. Last resource, it needs a new fan motor.
Cheers
Feb 08, 2009 | Neff U1721 Double circotherm Electric Oven
Fan not working
Hi, its likely that the fan motor isn't working. (most times is just build up of grease) If you're good with DIY, remove the inside panel that covers the element and the fan, undo he nut CLOCKWISE, pull the oven out, remove the the back cover, remove wiring from fan motor, clean the motor with WD40, and give it a few turns to see if turns freely. Reserve the process.
Cheers
Feb 07, 2009 | Zanussi ZBF360 Electric Single Oven
Cuts out over 100deg Celcius
the oven cut out stat may be cutting out to early first try this, it should be mounted at the top of the oven unit.
Jun 23, 2007 | Baumatic B180 Electric Single Oven
De Dietrich DOC310 Electric Single Oven Logo
124 people viewed this question
Top De Dietrich Ovens Experts
ashburton
Shehu Pro
Shehu Pro
Electro Med Services...
Are you a De Dietrich Oven Expert? Answer questions, earn points and help others
