Question about Electrolux Washing Machines
The machine will wash but will not spin the program keeps running but when it comes to the spin cycle it will not spin but the timer keeps going
Nave checked the belt emptied the filter thought it might be the bushes but don't know where they are
  • Official Brand Answer
  • 4,342 Answers
Hi Christine - Often when a unit does not spin, it is because the unit cannot properly drain and dispose of the water and detergent solution. Does the unit make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Posted on Jul 12, 2013
ttech
  • 139 Answers
SOURCE: Maytag A108 27 years old
It sound like Transmission Problems,Bury it and give it a Decent Burial, Dont Forget to Give Thanx.....ttech
Posted on Jul 23, 2007
geemarie
  • 876 Answers
SOURCE: belts slips off
Belt is too loose and probably needs to be replaced.
Posted on Aug 02, 2008
SOURCE: Roper washer wont empty
the pump is not working
Posted on Oct 28, 2008
  • 6 Answers
SOURCE: Washing machine WK61420GB drum does not turn
replace the brushes in the motor ( approx £5 parts)
Posted on Feb 21, 2009
barkencoa
  • 3463 Answers
SOURCE: Washing machine won't complete cycle
If it is a hot and cold fill washer, yes, then it could be a hot water problem related to the valve, or the water supply., if it is cold fill only, then the problem is elsewhere.
Pleas rate my solutikon.
Thanks.
Posted on May 13, 2009
My washer wont go into spin cycle. I hear a clicking sound coming from the timer.
It isn't a timer it is a programmer that is probably faulty.
You can test this by setting it to spin in different program cycles.
If it refuses to spin in any , assuming that they are in different places on the programmer,, that may indicate another , different
fault.
A technician should diagnose your fault fairly easily.
Jun 22, 2015 | Washing Machines
Cold water won't stop before rinse cycle
if it fails to stop running only at the rinse part of the cycle it is probably in the timer as the solenoid valve has to cut the water off when the washer fills for the wash cycle too. fills for wash cycle and cuts off water, washes and drains, refills for rinse cycle and water just keeps running? does this every time you run it? that's in the timer. bad solenoid (water inlet valve) would keep running even on wash fill up. hope this helps.
Feb 25, 2014 | LG WM2688H Front Load Washer
Washing machine washes then will not spin HELP HELP dirty clothes
When you set "the timer to drain and spin only". After "drain" program finished - not pump or motor sound or all sound stoped, the machine is freeze?
The meaning is sometimes, the sensor of water level doesn't working properly. The "drain" program is keeping running.
May 27, 2017 | Washing Machines
Calypso will not advance past wash cycle. I have a Calypso GVW9959K washer that displays no error codes and will run all functions in test mode. Problem is - it will run forever in the wash mode (clock...
If the machine is filling and washing but not advancing then the timer mechanism is not fuctioning. There is no codes so all other parts must be working, likke the pressure switch. You might test the door or lid switch this can sometimes hang these up. to test simply jump across the switch with a jumper wire. Basically
  • If the washing machine fills with water and begins agitating, but the timer does not advance, the timer probably needs to be replaced
  • If the timer does not advance while the washer is in a spin cycle, the timer probably needs to be replaced
  • I am supplying the service manual for this machine. Please be careful when attempting any repair and always make sure the machine is unplugged before starting any repair. This manual include service guides for testing components as well if your capable of these tests. The link will lead you to the manual. These manuals are not easy to come by due to the fact they are meant for service personell who make a living on these so it is inclusive and should help you in you issue.
  • https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2c1e295a88aaaae885256c5d004632a4/$FILE/8178010.pdf
  • May 13, 2011 | Washing Machines
    Kenmore 80 series top load washer. In the permanent press mode the machine will stop when it moves to the rinse mode. I can manually move the time past the midpoint of the cycle it will run for a minute...
    So it will spin and drain when put in the spin cycle right? More than likely it is your timer if you have to keep manually setting. I would check on timer prices and go from there.
    Dec 28, 2010 | Kenmore Washing Machines
    Stops running after wash cycle emptys. the timer keeps running but the rinse and spin cycles do not engage.
    Can you make rinse and spin occur by turning the control by hand to those positions? In any case, suspect the timer control itself, or maybe some of the wiring has come loose from the controller.
    Oct 29, 2009 | GE WDSR2080D Top Load Washer
    Washing machine will not advance through the wash cycle, machine will fill tub and begin wash cycle but will not move on to the rinse cycle. The washing machine will remain in the wash cycle and can only...
    Hi, Your timer motor burnt out, or timer faulty, remove top back panel (back of timer) and check timer motor, if timer motor are built-in (electronic type) you'll have to replace timer, or if timer motor can be remove, replace it, check back of timer, (knob you turn to change cycles or programs) locate timer motor, you can check appliance store to purchase timer motor, or let mechanic check, surely it's your timer motor or timer, check let me know,
    Aug 12, 2009 | Whirlpool WTW5800SW
    Doesnt go through programs
    sounds like you have a bad timer or lid switch. does it finish a cycle but not advance or does it just keep washing or does it wash then stop and get stuck? if it just keeps doing one cycle like wash wash wash you would have a bad timer. if it washes then stops and gets stuck you have a bad lid switch. But then again if you had a bad lid switch it would never spin. What is the brand name of this washer?
    Jun 10, 2009 | Washing Machines
    Washing Machines Logo
    76 people viewed this question
    Top Electrolux Washing Machines Experts
    Tim Whalen
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
