Question about Gateway 4530GZ Notebook
How can I fix the loose power jack?
My laptop's power jack is loose and i have to take the power in and out to get it working. What's the best way to open the laptop (i can't get it open just under the lid!!) and fix this problem?
  • 1 more comment
  • smeck Dec 17, 2007
    Does anyone know how to get Gateway service manuals? I have a 4530GZ with a loose power jack. I haven't been able to find a service manual on Gateway's site...
  • patidar27 Dec 19, 2007
    I have the same problem after my son dropped the laptop.
  • Anonymous Jun 04, 2008
    i am looking for a reapir service manual for the 4530gz gateway laptop
    any help is greatly appreciated
    thanks
    john
The last 2 screws to separate top from bottom are located ynder the 3/8" wide clip on plastic piece above your function buttons. Center screw and right hand side. Be careful of ribbons, plug-ins and wires that attach to both sides. I strongley suggest not doing this if you are not mechanically inclined. You could very easily cause damage to your laptop.
Posted on Feb 02, 2008
How can i fix my loose power jack
Posted on Nov 10, 2008
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 153 Answers
You need a service manual, most likely you can download it from the manufacturer's website. open the laptop and inspect the power jack to see if the solder points have come loose, or if the jack is broken. if the solder has come loose, you can resolder it. if the jack is broken, you have to replace it look on ebay for a replacement jack. look for a qualified repair technician to do the work if you are not experienced or comportable doing it yourself.
Posted on Aug 27, 2007
6ya staff
SOURCE:
DC power jack pushed in
You will need a good fix it person to open up the laptop shell to retrieve the jack and reset it properly.
Mar 10, 2014 | HP Compaq Presario CQ60-417DX
Hi when plug in my ac adapter into lenovo x61 the tablet will not turn on i try it on other computer and it will on what happen?
LOL, sounds like your tablet has seen it's better days. See why HP got out of the Tablet business? They are nothing but trouble.
Apr 08, 2012 | Lenovo Tablets & eReaders
Gateway kav60 not charging. i have to wiggle the cord and sometimes it refuses to charge.
I guess you've got a broken laptop power dc jack or power cable.
Symptoms of a broken Laptop DC power jack:
- The laptop only operates when you hold the DC power plug in a certain direction (DC jack is broken or loose).
- The laptop only runs on battery power (no power is getting through the DC jack).
- The laptop gets no power at all.
- The laptop will not charge the battery.
- The laptop switches from AC power to battery power intermittently due to a loose or broken power jack.
- The laptop suddenly shuts off.
- The DC jack may feel loose.
- Sparks come out of the back of the laptop when you insert the power plug into the DC jack.
Apr 21, 2011 | Lifetime Gateway KAV60 Replacement Laptop...
Powerjack is loose when plugging in charger.no power,no lights battery can not be charged.
In order to fix this problem, you will have to fully disassemble your laptop to get access to the motherboard & the power jack. If the power jack is not broken but only loose, you can re-solder it to the motherboard. Otherwise, you will need to buy a replacement power jack (usually less than US$ 10), de-solder the broken power jack, & then solder in the new one.
When this is done, re-assemble back your laptop.
Nov 27, 2010 | Acer Aspire One PC Notebook
Battery not charging !!!. replacement of new batter also has the same problem. and old batter suddenly started charging by meddling with the cable for once. and then again the same problem. would it be...
Looks like either the power jack of your adapter is experiencing a bad connection. Check if the power adapter's cable near the jack which plugs into the laptop is not severely bent.If this is the case, then you will need to replace the power adapter.
If this is not the case, check the DC socket where you plug the power jack into the laptop. This socket might be loose or broken. If this turns out to be the case, then your laptop needs to be disassembled in order to re-solder or replace this socket, depending on its condition.
Aug 28, 2010 | Dell XPS M1530 Notebook
How to fix power jack on asus eee 1005hab notebook pc. the adapter is fine but the connection into the power jack on pc is very loose. won't get a connection.
Best bet would be to dismantle and make some sort of "Hamshack" connector,soldering if neccessary or even glueing the dam thing if the case is broken or damaged.
Aug 09, 2010 | ASUS Eee PC 1000H Laptop
When you move the computer working under external
issue with the ac jack. It has a loose connection. you will need to open up the laptop and remove the board to re-solder the AC jack.
Jun 02, 2010 | Acer Aspire 3000 Notebook
How do you fix or replace a faulty power jack for inspiron 6000?
I PERSONALLY DONT THINK THAT ANY DRIVER IS GOING TO HELP YOU REPLACE UR POWER JACK,YOU WILL HAVE TO GET TO AN I T SPECIALIST,CAUSE UR JACK WILL HAVE TO BE REPLACED,AND IF YOU TRY AND DO THIS YOU WILL VOID THE WARRANTY ON THE MACHINE
Jul 03, 2009 | Dell Inspiron 6000 Notebook
No power going into power jack
You would be better off phoning small pc repair stores and getting the best price to replace it
not a good idea to fix it yourself
the cost usually runs between $60.00 - $100.00
I know people that fixed me themselves and believe me they have ended up with problems
Jan 13, 2009 | Computers & Internet
Hi there
This sounds like you may have a loose/broken jack on the machine. Take a small screwdriver and check to see if the jack is loose. If so, there's your problem, if not, then the problem will be in the power management system on the motherboard, and you will need to take it in for a professional diagnostics in order to track down the exact problem component.
Sep 02, 2008 | Toshiba Satellite A135-S2276 Notebook
Gateway 4530GZ Notebook Logo
1,644 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Thomas F. Schneider
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
