Question about Garden
Lt155 john deere overrevving
Over revving just put carb kit in. I think it the governor .
  • 53 Answers
Check the springs and linkages to insure they move smoothly, also check the spring tension.
Posted on Jul 15, 2013
  • 3 more comments
  • tomcleveland Jul 15, 2013
  • 127 Answers
SOURCE: my john deere lt155 has a punctured tyre, how do i
in the center of the rim remove plastic cap remove c clip retainer then pull rim and tire off the machine
Posted on Jun 30, 2009
wilsodfarm
  • 986 Answers
SOURCE: 3020 carburetor ? john deere gas tractor, 3020
those carbs are real simple you will not have any problem
Posted on Jul 29, 2009
bbreton
  • 437 Answers
SOURCE: need instructions for changing a drive belt on a John Deere LT155
I have googled LT155 and came upon john deere LT155 lawn tractor(noncurrent). It took me to John Deere's site. I put in your model number and it had several catagories. I would try the alphabetical list, go to B and look for traction belt.
Good day.
Posted on Oct 14, 2009
rwvanlue
  • 486 Answers
SOURCE: John Deere Gx75, kawasaki 9hp motor- oil in carb!
A very common problem with the GX series with Kawasaki engines. The carburetor 'inlet needle' sticks open and fills the crankcase with fuel. When checking the oil, it can be difficult to see the gasoline and the level appears to be OK. Remove the dipstick and smell the oil, you may detect a gasoline smell. Also, drain the oil, and you may find much more fluid than you expect.
The solution on newer mowers was to install an 'in-line' shut-off valve to keep the fuel from syphoning into the carburetor. The inlet needle and seat in the carburetor is NOT replaceable, so a new carburetor is the ultimate solution, but VERY expensive. Installing and using an in-line shut-off valve is more affordable.
Also, this situation is common when machine is transported on a trailer, as the bouncing causes the needle/seat to leak. When transporting, always turn off the fuel supply to the carburetor.
Posted on Nov 08, 2009
SOURCE: need wiring diagram for lt155 john deere riding
need wiring diagram for john deere lt 155
Posted on Jul 28, 2012
Manual for John Deer LT155 wiring an scymatics
I wish people would learn how to use GOOGLE!!!!
VERY FIRST THING ON A GOOGLE SEARCH, IN IMAGES!
john deere lt155 wiring diagram Google Search
Please be patient, the website below seems to be very slow.
John Deere LT155 Wiring Diagram
Jul 26, 2016 | Cars & Trucks
John Deere riding lawn mower model LA115. Light tension long spring came loose on carb. Where does it hook up to
I need more info. I need engine make, model, code, date of manufacture, etc. It sounds like a governor spring. Is it wrapped around a linkage going from carb to governor on engine? If it is, it goes in the same hole the likage goes. But to be sure get me the info above and I will check for you.
Aug 01, 2013 | John Deere Garden
John deere lt155 lawn tractor shuts off when it gets hot while mowing, could this be electrical?
I had a similar problem lasy year.
Try this:
As soon as the machine seems to be stalling, loosen the gas cap.
If the engine continues to run, clean the gas cap vent hole(s).
Gary
Jun 26, 2011 | John Deere Garden
Need wiring diagram for lt155 john deere riding mower
Aug 26, 2010 | John Deere Garden
Need instructions for changing a drive belt on a john deere LT155 lawn tractor. When mowing up hill the forward motion is slipping even though i am not loosing traction. if i come off the pedal and start...
Good day.
Oct 14, 2009 | John Deere Garden
Engine revving - sounds like an airplane engine
more than likely its a clogged jet in the carb. pull the carb off and flip it upside down. take the bolt out of the bowl and pull it off. use a flat head to unscrew the jet in the tub in the middle. clean out the high idle jet on the side and replace in reverse order.
Aug 18, 2009 | John Deere 22 In. Rear Tire Chains
Garden Logo
69 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
